Rear leaf spring bolt snapped.
Old Aug 3, 2013 | 07:33 AM
  #41
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by Zags
Well, I just made it back to the house with the car. Didn't wind up getting a tow. Instead I jacked the car up in the dealership's lot just enough to chain the spring to the control arm. Had no issues along the way, didn't make any friends on the road though since I drove 10mph tops. As it turns out, the bolt that snapped was a factory bolt, original to the car. Not anything aftermarket.
I did wind up having to pay the dealership's "standard diagnosis fee". I'm sure they had to work real hard to figure our what was wrong with it, after I already told them what it was. Not real happy about that considering an oil change takes more work and costs less. But whatever, I'm just glad its back home.
I'll let you guys know how the fix goes...
Not to rain on your parade, but since the spring is made of a composite material, I sincerely hope that you didn't damage it with the "chain"....
Old Aug 3, 2013 | 10:01 AM
  #42
RaW Z06's Avatar
RaW Z06
Old Aug 4, 2013 | 12:39 PM
  #43
jph1972's Avatar
jph1972
Took my Vett out yesterday for a nice Saturday drive and the same thing happen to me fortunately I was only 1/2 mile from the house.
I know the bolt is a grade 8 but does anybody know what the overall length,thread and thread length of the stock bolt is. I was able to find the bushings so I am just going to order the bolts and washers from MC Master Carr.
Old Aug 4, 2013 | 01:38 PM
  #44
Zags's Avatar
Zags
The spring has steel around it top and bottom where the bolt goes through. That's where the chain is wrapped around so I think it's fine. Didn't have to keep it on too long either way, my house isn't far from the dealership.
Old Aug 4, 2013 | 04:44 PM
  #45
leadfoot4's Avatar
leadfoot4
If you're replacing both bolts (which I think you probably should), take a measurement of the bolt that isn't broken and go from there. The OE bolts, I believe, are metric, but I think 7/16" is close to the OD you'll need, and about 7-7.5" in length. Fine thread or coarse thread really shouldn't matter too much, just get the appropriate NyLock nuts to go with the bolts.
Old Aug 4, 2013 | 04:55 PM
  #46
Zags's Avatar
Zags
The stock bolts are M14 and about 6.5" long. Don't know the thread. But 7/16 is too small. M14 is closest to 9/16.
Old Aug 4, 2013 | 05:25 PM
  #47
leadfoot4's Avatar
leadfoot4
OK, I stand corrected. I seem to recall a C-3 thread where somebody mentioned 7/16" bolts, and maybe that's what stuck in my mind...
Old Aug 4, 2013 | 06:46 PM
  #48
o2bnkc's Avatar
o2bnkc
Originally Posted by meflyfrc
Thanks and the bolts are on their way. Least I can do since I've gotten so much help and ideas from this forum.
Old Aug 4, 2013 | 06:50 PM
  #49
o2bnkc's Avatar
o2bnkc
What's the name of the chevy dealer? Would love to spread the word where NOT to go if traveling through Oklahoma.
Old Aug 6, 2013 | 08:00 PM
  #50
Zags's Avatar
Zags
Well guys, I came home and found meflyfrc's bolts waiting for me on the door step. Its about an hour and a half later now, and I'm done. That counts the time it took to get out tools and put them back up once I was finished.
Here's a pic of the old snapped bolt. You can see how half of it is shiny and half is rusted. Looks like it snapped about 1/2 way through a long while back, right where the nut would sit. Then just finally decided to let go on me last Monday.
The new bolts are definitely longer than the stock ones, and it sits about an inch lower in the back now. At least I have excuse to drop the front now right?
Thanks for talking me out of letting the dealership work on it!
Old Aug 6, 2013 | 09:03 PM
  #51
jph1972's Avatar
jph1972
I replaced mine as well today. I ended up getting the stock bolts from the local dealer. Only took about an hour and I replaced both sides. Makes me wish I replace entire spring probably would have only took a half hour more.
Old Aug 6, 2013 | 09:12 PM
  #52
bumble-z's Avatar
bumble-z
Good job guy's & you can't beat the cost of free labor.
Old Aug 6, 2013 | 11:09 PM
  #53
meflyfrc's Avatar
meflyfrc
Excellent, glad to help. They are aftermarket lowering bolts, stronger than stock. Enjoy
Old Aug 7, 2013 | 07:00 AM
  #54
leadfoot4's Avatar
leadfoot4
Welcome to the DIY club!!
Now I better go check the condition of my bolts.............
