Rear leaf spring bolt snapped.
Old Aug 1, 2013 | 11:23 AM
Zags's Avatar
Zags
Default Rear leaf spring bolt snapped.
Hey guys, first post here.
Monday I was driving home from work, when I pulled up to a stop sign and heard "BANG"... Turned the car off immediately, got out and found the passenger's side sitting on the rear tire. Looked underneath and saw the rear leaf spring bolt had snapped. Called for a tow and had it taken to the dealership.
Here it is on the tow truck.
Looked the part up online, and was expecting it to be a $150 job or so. Well, I got a call from the dealership this morning telling me they wanted $681. After the shock wore off, I told them I'd call them back.
That seem reasonable to you guys? If I bought or rented the tools, I think I might even be able to do it at home. Or is there something I'm missing that makes this worth $681?
The car is a bone stock 1997 Coupe with 126k miles.
Old Aug 1, 2013 | 11:42 AM
Johnz02Z06's Avatar
Johnz02Z06
St. Jude Donor '14
First off, welcome to the Forum!
The only reason I could see it being that much is if you need a new spring or shock or other part because it was damaged when the car "fell" onto the wheel. The bolt may have flew up and hit something too...I would get details on what the $681 is for before saying "ok" to the repair
Old Aug 1, 2013 | 11:47 AM
oldC5's Avatar
oldC5
Good luck with the repair and if you need springs I just took mine off . I added pfadts. My springs are in excellent condition with only 15,000 miles on them.
Old Aug 1, 2013 | 12:00 PM
bumble-z's Avatar
bumble-z
WOW!!!!
I agree with post #2.
I'm sorry I thought they were going to fix the broken bolt for $68.
Get your car out of there?
Does your fender hit the tire ?
Is anything rubbing?
How far are you away from home from the shop to your house or where you can work on it your self?
Fix it your self.
Really an easy job.
You need to take a close up picture of the other (good side) so we can see if you have after market hardware .
(longer bolts) After you get it out of there!!!
Old Aug 1, 2013 | 12:03 PM
Zags's Avatar
Zags
The $681 was just to replace the bolt. He told me if I wanted to replace the spring, it would be an additional $971. Shocks would be an additional $400ish, I don't remember the exact number.
I don't believe the car had ever been lowered. I'm the second owner, and the lady who owned the car before me wasn't exactly the tuner type. Heh.
Old Aug 1, 2013 | 12:06 PM
oldC5's Avatar
oldC5
Run my friend run. They are crazy. $$$$$$$ WTF
Old Aug 1, 2013 | 12:17 PM
Vette Moto's Avatar
Vette Moto
From what I can tell, it seems like you would just need a new bolt and washer to fix that. Honestly, I don't see how the leaf spring could have been damaged from this. It may have scraped the pavement at the most.
the process to install the bolt is quite easy. Any DIY on changing lowering bolts can get you through this. I actually have a set of rear lowering bolts sitting somewhere after I replaced them with Zip's lowering kit
Old Aug 1, 2013 | 12:26 PM
Zags's Avatar
Zags
Fix it your self.
Really an easy job.
Doesn't rub if I take it super slow (like barely easing on the clutch at idle, then coasting slow), that's how I crawled into the nearest parking lot. But it's probably worth paying for a tow again. The road to my house is pretty rough, and the tow only cost me $40 the first time.
I'll take pics of the other side when I get a chance. It's looking more and more like I just need to get it out of there.... Glad I'm not the only one who thought the dealership was crazy.
Old Aug 1, 2013 | 12:31 PM
Johnz02Z06's Avatar
Johnz02Z06
St. Jude Donor '14
I agree with others here...get it out of there!
If you cannot do it yourself then call some local shops or give me you your location and I will call some for you if you need help.
If you can do it yourself and need advice the forum will help
The guy in the post below "temp" fixed his when the tow truck came...maybe I should throw one of those bolts in my trunk!
http://forums.corvetteforum.com/c5-g...o-tonight.html
Old Aug 1, 2013 | 12:33 PM
Black 02's Avatar
Black 02
I hate dealerships so much. I don't understand why they have to be such scumbags. You can buy a lowering bolt kit for less than $50 and get it fixed in an afternoon. If you just want a stock bolt I'm sure someone on here would even offer you one for the cost of shipping.
Old Aug 1, 2013 | 12:35 PM
Black 02's Avatar
Black 02
Where are you located?
Old Aug 1, 2013 | 01:08 PM
Zags's Avatar
Zags
McAlester, Oklahoma. I just called the dealership and told them not to work on it. If I can find some bolts it looks like I'll have a weekend project.
Old Aug 1, 2013 | 02:28 PM
ZigZag's Avatar
ZigZag
Good luck with your project, nice screen name btw.
Old Aug 1, 2013 | 02:48 PM
hamhead's Avatar
hamhead
This is retarded and why I hate dealerships.
I could train a monkey to repair that in under an hour. All that is involved is getting the car in the air, take the load off the suspension, and threading a bolt through a hole.
Old Aug 1, 2013 | 04:01 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
If you haven't figured it out already, you should be looking at about $25 at MOST, for two new grade 8 bolts (might as well replace them both), two new nylock nuts, and 4 flat washers. HOWEVER, you most likely lost the rubber spring cushions that are part of the deal also. I'd recommend Energy Suspension polyurethane cushions as replacements.
For $618, I'd do this job 2-3 times a day for a couple of weeks, and retire....again!!
Old Aug 1, 2013 | 04:58 PM
Zags's Avatar
Zags
I've been calling all over town trying to find a bolt. So far, no one carries grade 8 bolts that are long enough. Closest I've found is 100mm. Couple places left to try before I break down and buy them online though.
I picked up the old broken bolt which still had the rubber cushions/bushings on it. I planned on just reusing them, unless you guys think that's a bad idea. Edit: This is assuming the dealership didn't throw the old one away. I left it siting in the passenger floorboard.
Originally Posted by ZigZag
Nice screen name btw.
Thanks! You too
Old Aug 1, 2013 | 05:12 PM
oldC5's Avatar
oldC5
Buy new bolts and rubber spring cushions. One already broke , why take a chance. They are not that expensive. I would also check the fronts . Good luck .
To Rear leaf spring bolt snapped.
Old Aug 1, 2013 | 06:46 PM
Zags's Avatar
Zags
Well, I struck out here in town. No one carries bolts that large. Where do you recommend buying online? All I can seem to find is used bolts or extra long lowering kits.
Old Aug 1, 2013 | 06:51 PM
leadfoot4's Avatar
leadfoot4
How about Grainger Industrial Supply or Fastenal?
Old Aug 1, 2013 | 07:01 PM
Zags's Avatar
Zags
Don't have a Grainger around here, checked with Fastenal and he said they could order it in some time next week. Figured if I have to order something in, I may as well pay expedited shipping online and get it here faster.
