Battery cable removal
Old Oct 6, 2013 | 02:50 PM
Outlawtorn's Avatar
Outlawtorn
Originally Posted by LoneStarFRC
Being the "curious type" I'm still trying to figger out WTF "plyers" is/are.
Really? I dont know if youre serious or just taking the ****...However:
Pliers are like vice grips without the locking mechinisim. Hold out your finger and let me give it a twist with my pliers
Old Oct 6, 2013 | 03:17 PM
LoneStarFRC's Avatar
LoneStarFRC
Hey, don't 'splain it to me, 'splain it to LA Boy that dropped his "top". I will however, let you pull my finger, just not with your "pliers".
Originally Posted by laurent_zo6
I took a pair of plyers and started to twist slowly.........
Old Oct 6, 2013 | 11:39 PM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
This L.A. Boy directs you to go to Sears.com and look for:
"Cooper hand tools dura-plyers" and you will have learned something new.
No need to apologize.
Last edited by laurent_zo6; Oct 6, 2013 at 11:42 PM. Reason: Just setting the record straight
Old Oct 6, 2013 | 11:42 PM
LoneStarFRC
Cooper hand tools dura-plyers and you will learn something new.
Good to know Cooper has redefined the spelling of pliers now, and forever more.
Old Oct 6, 2013 | 11:47 PM
laurent_zo6
Next time it might be wise to do some research before shooting off your mouth. My spelling was correct. But as I said previously, no need to apologize. The facts speak for themselves.
Old Oct 7, 2013 | 12:00 AM
LoneStarFRC
Lighten up Sparky, you'll live longer. Glad you found your top though and we also now know Cooper calls one of their tools "plyer". Awesome!
Old Oct 7, 2013 | 01:39 AM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Originally Posted by mrlmd
Why did you want to remove that anyway? Never heard "if it ain't broke, don't fix it?" (J/K).
It's corroded!
Old Oct 7, 2013 | 02:47 AM
LoneStarFRC
Originally Posted by ztheusa
It's corroded!
You noticed that too, eh? Plus that negative terminal bolt looks professionally boogered up too.
Old Oct 8, 2013 | 03:31 PM
laurent_zo6
For the record my name is not Sparky and am not an LA Boy. You thought you could make fun of another CF member's typo and it turned out that the joke was on you. Please abide by the CF rules and show some courtesy to other CF members in the future by not calling them names.
Old Oct 8, 2013 | 07:39 PM
LoneStarFRC
......... You thought you could make fun of another CF member's typo and it turned out that the joke was on you.
Good one! That irony is hilarious.
Glad to see you got some fresh air and you're trying to see the humor though.
It would seem that pretty much the entire hand tool industry is going to have to re-name their products now, however. Looks like they better get started soon 'cause there's a LOT that apparently haven't got the "plyers" memo yet it seems, and they've been doing it all wrong for decades.
Here's some "direction" for you for some examples:
www.snapon.com (Check "hand tools")
www.craftsman.com (Check "hand tools")
www.mactools.com (Check "Shop online" then "Handtools")
http://www.service.kleintools.com (Check "Products")
http://www.stanleytools.com/default....ATEGORY=PLIERS - 37k
www.matcotools.com (Check "Tool Catalog" then "Handtools")
http://www.stanleytools.com/default....axSteel+Pliers - 59k
http://www.protoindustrial.com/en/Pages/default.aspx (Check "Brands" for Proto, Blackhawk, Stanley and Expert)
http://upload.wikimedia.org/wikipedi...ool-pliers.jpg
http://www.primermagazine.com/wp-con...iers_Types.jpg
www.channellock.com (Check "Hand tools")
www.apexhandtools.com/brands/crescent
http://www.skhandtool.com/products/pliers.aspx
www.aikencolon.com/Knipex-Hand-Tools_c_969.html (Check "Knipex" brand, German hand tools)
Btw, a little tip for next time your "top" falls down inside under your battery: There's a small, removable, inspection panel in the lower rear RH wheel-well that once removed, gives access to the area under the battery where things (like your little "top", etc) usually fall. A few 7 mm screws saves removing the battery cables, battery hold down clamp, battery, battery tray and likely having to use a long extendable magnetic, or grasping tool, to reach deep down inside for retrieval. No need to jack up the car either.
Old Oct 8, 2013 | 07:54 PM
laurent_zo6
You can huff and puff all you want and try to misdirect the conversation. The point is you didn't know that Sears sells "Plyers" and you thought that it would be hilarious to make fun of a CF member's typo. The problem was that it was not a typo. I will let the rest of the members draw their own conclusions regarding your actions in this thread.
Old Oct 8, 2013 | 09:34 PM
LoneStarFRC
You can huff and puff all you want and try to misdirect the conversation. The point is you didn't know that Sears sells "Plyers" and you thought that it would be hilarious to make fun of a CF member's typo. The problem was that it was not a typo........
Good grief, you really don't get, do you? "Dura-Plyers" (not "plyers") is nothing more than a trademarked name for a particular unique tool (plier), that Cooper makes. They too are "pliers". Guess you didn't know "Sears" also sells "pliers" too, which happens to be a category of hand tool manufactured by dozens of companies including Cooper.
http://www.sears.com/craftsman-4-pc-...11000P?prdNo=1
I guess if Ford puts their name on a car, it's no longer a "car", because it may say "Ford" on it. Makes perfect sense.
You have a nice life.
Old Oct 8, 2013 | 10:24 PM
  #33
laurent_zo6
What I do "get" based on your long incoherent ramblings is that you have way too much time on your hands and since I have a life to lead I am going to leave you now so you can keep posting more of those.
Old Oct 8, 2013 | 11:14 PM
  #34
LoneStarFRC
.......... and since I have a life to lead I am going to leave you now so you can keep posting more of those.
Promise us, please! No teasing.
Btw, as you're such a "Sears" devotee, you might want to check with them and stock up on some humor and some "grip", in case they're running any special deals. You're running a tad short on both.
