[Z06] Cant shift at high rpms!!!!!
Old Oct 25, 2013 | 02:35 PM
zeevette's Avatar
zeevette
It's probably not the MC....the Spec clutches are known to need to be shimmed, when installing the new slave. Man, you must be really good at tearing out the TT by now.
Old Oct 25, 2013 | 03:03 PM
racebum's Avatar
racebum
the spec clutch he no longer has in there?
Old Oct 25, 2013 | 03:45 PM
PRE-Z06's Avatar
PRE-Z06
Originally Posted by kid_c6
It has a stock clutch with A stock master and a stock slave when the problem first started , then I put a new spec. 3+ clutch with a new master and a new slave. The problem didn't go again so I added a tick master on it. The problem was still there so I took out the spec clutch and bought a new replacement c5 z06 clutch with a new gm slave and gm master. The problem continued so I figured I would give the tick a chance.
GM tolerances can vary from the back of the crank, block, both sides of the bell housing, torque tube and slave cylinder...did you take any measurements with clutch installed to see if yours are all off in the wrong direction causing issues?
Old Oct 25, 2013 | 04:32 PM
racebum's Avatar
racebum
while we wait for his reply what's the general advice with your clutch kits? i bought a level 1 c5 direct fit kit and they mentioned no shims were required and no shims came in the box
haven't installed yet, probably will over winter
Old Oct 25, 2013 | 06:35 PM
PRE-Z06's Avatar
PRE-Z06
99% of the time they work without a shim, but in a vette being that it is such an extensive process to swap a clutch I always recommend measuring to prevent having to tear it back apart as there are rare cases where one is needed.
Old Oct 26, 2013 | 12:58 AM
kid_c6's Avatar
kid_c6
Cruising
Update guys!! I kept on adjusting the tick further and further until it let me shift at high rpms. I did the rev test and had it adjusted so it didn't creep forwards but that wasn't enough. I adjusted it further and now I'm enjoying the car again! The peddal still feels a little goofy at high rpms but it's disengaging and engaging correctly. Thanks for all the help and support! Thanks!
Old Oct 30, 2013 | 06:57 PM
FourG63 97GST's Avatar
FourG63 97GST
interesting, thanks for the update
