The headlight motors and the rear lights are on separate circuits but they all route through both the headlights switch and the hazard flasher unit. Its probably one of these which is causing the problem.
Will wiring diagrams help?
not very good at diagrams,
not having much luck,thanks so much ,i'll keep working
I think it is number 6 in the passenger floor. I think that was the one that I blew and had the same symptions. If I remember right, it is a red 10A fuse.
