[Z06] Bolt ons, how much hp?
Old Apr 1, 2014 | 11:27 AM
95rtturbo's Avatar
95rtturbo
Originally Posted by JeremyGSU
Nah, this doesn't hold water. Results are typically identical.
Agreed. That comment was totally incorrect.
Old Apr 1, 2014 | 02:14 PM
REVHARD's Avatar
REVHARD
Well, here is real life experience and professionals which disagree that bigger is better.
http://ls1tech.com/forums/generation...xperience.html
Old Apr 1, 2014 | 02:20 PM
95rtturbo's Avatar
95rtturbo
You said a 10 WHP / 10 WTQ difference. That is total BS. They produce close to the same on a practically stock LS6.
Old Apr 1, 2014 | 02:28 PM
REVHARD's Avatar
REVHARD
Not gonna argue any more as people will buy and run whatever "they believe" is better. If you believe a larger header on a pretty much stock bolt on c5 is better then the appropriate 1 3/4 header that's your business.
Old Apr 1, 2014 | 02:31 PM
95rtturbo's Avatar
95rtturbo
LOL. When did I say it was "better"? I said they are about the same.
Old Apr 1, 2014 | 03:00 PM
JeremyGSU's Avatar
JeremyGSU
I would hardly site ONE website comparing headers as the gospel. There are a TON of threads on this. Some companies have tested both back to back and made more power with the 1 7/8's, others not.
They make so similar hp numbers it's ridiculous. Google "dyno numbers c5 Z06" and you will find threads of people posting their numbers.
As I did early, people had almost identical results with similar mods but different size headers than I did. Certainly, not 10 hp+ differences.
The way I understood it when I was shopping around prior to install was 1 3/4 was better for mid-range and around town torque. 1 7/8 would be better for peak hp and high rpm applications such as Road Courses. I went with the 1 7/8 since mine spends most of the time in upper range.
For street driving I would have went with the 1 3/4.
Either way, the difference is negligible between the two until you start making serious power.
Old Apr 1, 2014 | 03:55 PM
95rtturbo's Avatar
95rtturbo
Old Apr 1, 2014 | 04:44 PM
DEnglish29's Avatar
DEnglish29
02C5Z vararam, Texas speed 1 3/4 headers x pipes no cats, slp exhaust & vararam power duct , dyno tuned made 411 RWHP
Old Apr 1, 2014 | 09:05 PM
Dennis Wilson's Avatar
Dennis Wilson
My 1 7/8 ARH gave the most sotp increase from 4500-5000 & up to my redline of 6800 Perfect for my 3.90 Z! Much easier to control wheelspin. Power doesn`t drop off at all before 6800.
Old Apr 10, 2014 | 09:46 PM
dbgoodwin's Avatar
dbgoodwin
My car only made 360rwhp with 1 3/4, no cats, borla exhaust and a tune. I dyno'd with the zip tie mod, but I'm still pretty disappointed with the results. It drives great and all, but definitely not worth the money and time I have invested in it. The car made buckets of torque (385 to the rear wheels). I've seen stock cars produce better number than mine..
Old Apr 10, 2014 | 11:03 PM
robz's Avatar
robz
We made 413 thru 4.10 gears on a Mustang dyno.
Old Apr 10, 2014 | 11:27 PM
C5Dobie's Avatar
C5Dobie
See a new tuner/dyno- that makes no sense
Old Apr 10, 2014 | 11:51 PM
  #33
dbgoodwin's Avatar
dbgoodwin
I went with a very reputable GM tuner.. I was very surprised to see the numbers.
Old Apr 11, 2014 | 08:06 AM
  #34
95rtturbo's Avatar
95rtturbo
I agree, the numbers don't make sense at all. Typically, an LS6 with those mods should make more HP than TQ if tuned correctly (and the HP to TQ ratio doesn't really have anything to do with the type of dyno, unless there is some issue with the dyno).
Old Apr 11, 2014 | 08:28 AM
  #35
chassed's Avatar
chassed
That really blows....
My 04 Z06 made 359RWHP BONE stock...
Old Apr 11, 2014 | 10:08 AM
  #36
C5Dobie's Avatar
C5Dobie
My 03 made 365hp/358hp w/ just a vararam & tune on a VERY stingy mustang dyno, and I agree that especially w/ headers you should be making more HP than torque anyhow, there's something wrong w/ the tune or the dyno or both....but I'd guess more to do w/ the tune because the torque # is still strong.
Old Apr 11, 2014 | 10:50 AM
  #37
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Originally Posted by VPP
Just dynoed my '04 Z06 only 2 weeks ago with 1-3/4" Long-Tubes, Catted X-Pipe, Vararam, Borla Axle-Back + Tune...
Put down 391/379 which I've been told is about standard for our cars. Getting to 400 with these mods is VERY rare.
VPP
Yea 400rwhp with bolt on's is rare (CAI, Headers, exhaust, tune).
Most I have seen are around 390rwhp 380rwtq.
Originally Posted by 04silverZ06
So your saying the larger tubing is actually robbing power with the standard 'hardware'?
LG's ran back to back testing with the 1 3/4 headers, and 1 7/8 headers on a LS6 Z06. Anthony told me they lost a little with the 1 7/8 because they are just a little big for the 346ci. Now if you have a stroker 383ci a 1 7/8 would be beneficial.
Just what LG's told me back in the day ...
Toque
To Bolt ons, how much hp?
Old Apr 11, 2014 | 11:16 AM
  #38
dbgoodwin's Avatar
dbgoodwin
The tuner just told me that the reason for my numbers was that the headers I used (xs power) bottle necked at the collector.
Old Apr 11, 2014 | 11:21 AM
  #39
C5Dobie's Avatar
C5Dobie
OK but think about it - no cats and headers and you're putting down worse numbers than WITH cats and cast irony manifolds? Makes no sense with or without a bottleneck.
Old Apr 11, 2014 | 11:37 AM
  #40
dbgoodwin's Avatar
dbgoodwin
Yeah I'm not too terribly happy. I could have saved $1300 and made the same numbers if this is true.
