[Z06] Bolt ons, how much hp?
Old Apr 11, 2014 | 12:23 PM
  #41
emmett77's Avatar
emmett77
Could you please PM the tuner you used....for future reference.
Old Apr 11, 2014 | 12:51 PM
  #42
philadd's Avatar
philadd
Originally Posted by dbgoodwin
Yeah I'm not too terribly happy. I could have saved $1300 and made the same numbers if this is true.
The problem is not with the bolt-ons that you've installed. I would consider other factors. As mentioned, the tune or dyno could be at fault. But unless you did a base run, you don't know if your car was already suffering from this problem before the headers and tune.
Old Apr 11, 2014 | 01:47 PM
  #43
dbgoodwin's Avatar
dbgoodwin
I used mayhem motorsports in Raleigh nc for the tune. I didn't do any base run prior to this, it just seems odd that the car made so much torque but no power at all
Old Apr 11, 2014 | 03:36 PM
  #44
PEETYZ's Avatar
PEETYZ
Have you had it to track or another dyno by chance?
Even a chance to see how it compares to another local car that is similar mods or stock?
Our local Dyno is a dynocom that is about 7% lower than the dynojets in the area.
Old Apr 11, 2014 | 05:42 PM
  #45
Cheesecake 07's Avatar
Cheesecake 07
Zachly.
How's the car feel? After I did Kooks 1 7/8" LT's, OR X, CAI and tune…first on-ramp I mashed it on, it blew off the tires and gave me a holy sh*t second. Super noticeable difference the way it pulled through the gears. My 04's numbers..
363rwhp/355rwtq Bone stock
394rwhp/377rwtq Bolt ons
Same dyno(Dynojet). Under the curve numbers matched or bettered the peak numbers for most of the power band.
Old Apr 11, 2014 | 05:56 PM
  #46
04silverZ06's Avatar
04silverZ06
Is it just me or os there a pattern of stock '04's dynoing higher than other year C5Z's?
Old Apr 11, 2014 | 06:40 PM
  #47
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Here is my 04 Z06 stock Dyno sheet from April 2004.
I don't think its any different than any 2002-2004 Z06.
Old Apr 12, 2014 | 05:00 AM
  #48
ZFORME's Avatar
ZFORME
2004 Z06 w/ 1 3/4 LG Super Pro headers and a Calloway Honker with a conservative tune made 392 rear wheel hp. It was at 360 hp stock.
Old Apr 12, 2014 | 09:24 AM
  #49
04silverZ06
When you guys say you changed the headers - are you all also changing the cats and X pipe or just the headers?
I'm wondering how much of a gain the cats and X pipe are worth.
thanks
Old Apr 12, 2014 | 10:31 AM
  #50
C5Dobie's Avatar
C5Dobie
He was on a mustang brand dyno which typically is the lowest of them all fwiw
Old Apr 12, 2014 | 03:25 PM
  #51
philadd's Avatar
philadd
thanks
Long-tube headers won't bolt up to the stock cats and H-pipe, so they usually come with their own X-pipe, in either catted or non-catted form. You'd be hard-pressed to find someone with LT headers mated to the stock H-pipe, since it would not be a bolt-on affair.
Old Apr 13, 2014 | 12:05 AM
  #52
TGO's Avatar
TGO
01 Z06. Kooks 1 7/8, honker, no cats, FAST, TPIS TB, tune 403.x rwhp and 406.x tq.
Old Apr 13, 2014 | 01:42 AM
  #53
dbgoodwin's Avatar
dbgoodwin
Dyno jet?
Old Apr 13, 2014 | 01:58 AM
  #54
TGO's Avatar
TGO
I have to check the sheet, which is in the car which I am not doing right now...but I don't believe it was a DJ.
Old Apr 15, 2014 | 07:40 AM
  #55
bada's Avatar
bada
On a mustang dyno mine made 355Hp. 1-3/4 headers, Varaam CAI, and tune. Car runs great & pulls hard.
Old Apr 16, 2014 | 09:12 PM
  #56
Supercharged111's Avatar
Supercharged111
Dyno jet?
Don't overlook the FAST, good for 13whp on a stock LS6.
http://www.cadillacforums.com/forums...ke-w-90mm.html
Thread is old, used to have dyno sheets posted.
Old Apr 16, 2014 | 10:46 PM
  #57
D. Lil's Avatar
D. Lil
Search my thread for my dyno numbers.
I think a little has to do with how many miles are on your engine. I have Vararam, Kooks 1 7/8s headers, Kooks 3" catless X, and B&B Bullet exhaust. Made 415 to the wheels and correction factor was almost 0 that day. 407tq I think. 2004 z06 with 16.5k miles
To Bolt ons, how much hp?
Old Apr 16, 2014 | 10:53 PM
  #58
C5Dobie's Avatar
C5Dobie
You think higher miles hurts the engine? No way! Not as long as the proper maintenance was done, some - like my G8 - gain some hp, I ran 3whp & 2rwtq higher on a dyno. @ 110,000 miles as I did @ 72,000 miles when I had headers installed
Old Apr 17, 2014 | 12:43 AM
  #59
TGO's Avatar
TGO
Don't get all worried about dyno numbers. They all read differently. **** I've seen them read differently on the same car without any changes other than rolling it off, and then back on the machine later on.
It's a tool to measure gains. Nothing more. There's way too many variables to consider any reading truly accurate and the machines themselves aren't even 100% accurate.
Get a stock baseline, add mods, measure difference. If you want numbers that really count, take it to the track and get some timeslips.
Old Apr 17, 2014 | 12:11 PM
  #60
philadd's Avatar
philadd
While this is 100% true, his dyno results indicate that there is some kind of problem somewhere, as he made 360whp/385wtq. If those numbers were reversed and he made 385whp/360wtq, I would think that it was perfectly normal.
