Which Starter
The long bolt starter was never installed in any model year of C5 from the factory, and that is why you may likely get a "does not fit" message either online, or from some kid behind a counter that only knows enough about most things to read what's on a computer screen, and if it's not on his "computer screen" he's lost.
Most good old fashioned auto parts stores have been run out by the large corporate auto parts and now they are hiring young inexperienced guys or young girls that have never even seen under the hood. The only thing that they know is looking it up on the computer by make and model. If you go in to retrofit something for a street rod they are lost and depend on your own knowledge. Years ago the people that worked behind the counter were grease monkeys themselves and a young guy going in for help could depend on them for their help. The only parts stores left in our area that still have that old way of doing business is Napa and local guys called Hovis Auto Parts.
I never said anything about NOT using the OE starter bolts, just that I am going to add a Nord-Lock lock washer to each one. The knurled section on the OE does not prevent bolt loosening.
Sorry about your issue !
I hope you get it figured out soon !
Here is a post that sounds like your situation.
http://forums.corvetteforum.com/c5-t...sh-lights.html
Here is a write up from Bill Curley.
http://forums.corvetteforum.com/c5-t...ch-repair.html
Hope this helps you out !
Toque
I agree with you 100%. If others don't want to use OEM bolts and not use locking devices then that is fine and I certainly hope they never have a problem. I just happen to be a professional engineer and teach fastener and joint design to new engineers in the nuclear industry among other things so what do I know? Mr. Sam P.E.
PS: If you look at some of the more recent OEM GM starter bolts they have ridges parallel to the bolt length next to the threads. In my experience neither design would be appropriate to secure the bolt/joint but rather assist in proper alignment. Also, if you think about it, how many times of removing and installing a bolt of this design into aluminum would it take before it would not perform any alignment or retention function?
Apologize for any misunderstanding. I wasn't implying that you were advising non-OEM bolts. Just confirming the need to use them. Lock washers or even some blue Loctite as insurance/peace of mind can't hurt.
Check me out.
Check me out.
And the flange head design of many OE bolts are designed to perform the same function of a flat (mostly) washer which spreads the clamping load over a slightly larger area. I think the factory knurls/splines may also have the added time-saving benefit at the factory of helping to hold the two bolts in place at the same time when the starter is being mounted, and help prevent them from dropping/falling out. One thing is for sure, these splines/knurls do NOT prevent bolts from loosening, although in fairness, I don't think the typical starter bolt in ANY car generally tend to come loose in the first place as the clamping force applied, plus the general (depending on vehicle) conditions in which it lives, usually don't see the vibrations sufficient or intense enough to cause loosening.
One thing is for sure though, and that is the consequence(s) of having a loose starter bolt fastener, is such that I will take a page from GMs lead on rear axles nuts on C6 (ZR1s), and use a couple Nord-Lock washers on my starter bolts which, unlike split-ring or star washers, positively prevent loosening. The only requirement is that the bolt tightening torque be 20% higher (resulting in 45 lbft instead of 37) and the use of thread-lube is highly recommended on the bolt itself. The added expense of a couple Nord-Lock lock washers is pennies compared to the potential consequences.
For those that may be interested, look up what Generous Motors uses under the rear axle nut on ZR1 Corvettes which, use the exact same axle nut as all the C5s and C6s. Nord-Lock washers.
I've already purchased a pair for my rear axles, and will be installing them in the upcoming weeks. I will increase the torque setting to 150 lbft and use ARP Ultra-Torque assembly lube on the axle threads.
I had to completely remove the entire H-pipe to get the starter out. The hardest part was getting the front to align back to the exhaust flange, because there isn't much room to wiggle it around.
As a side note, I was able to pick it up at my local Auto Zone only because they were out of them in the warehouse where the online orders are handled. The local manager gave me the 20% off since I couldn't order it online. If you run across this issue the local manager may override the price like they did for me. It was much more convenient.
Good luck and thanks for reading,
Art
Check me out.
