Help please....
Old May 19, 2014 | 08:55 AM
JM03C5's Avatar
JM03C5
6th Gear
Default Help please....
So I'm on a road trip in my '03 Vette (42K miles) and started hearing a loud thumping or knock from the drivers side rear. Nothing visibly loose or hitting. It is worse when I left off the accelerator, subsides somewhat when I accelarate again. It definitely sounds like driveline. Changes with speed but is always present when moving. I made it home but it was a tense drive to say the least.
Could this be a bad wheel bearing? CV Joint?
I'd like to troubleshoot this myself rather than take to a dealer. Even if I don't do the repairs, I would at least like to be informed.
Thanks for any help.
Old May 19, 2014 | 09:26 AM
3boystoys's Avatar
3boystoys
Hard to tell from here, jack it up and take a peek.
Old May 19, 2014 | 09:52 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Sounds like you have the drive axle going bad and or the rear hub bearing - or both!
Both are an easy fix, not hard to replace - my money is on the CV/Drive Axle!
Is your Vette a A4 or MN6?
Thanks,Matt
Old May 19, 2014 | 10:59 AM
JM03C5's Avatar
JM03C5
6th Gear
Thanks,Matt
A4
I love my Vette but have to say I'm not overly impressed with the engineering design quality. Had to replace both power window motors at 30k, the shifter cable broke at 35k and left me stranded and now bad rear bearings at 42k?
Old May 19, 2014 | 11:37 AM
bj1k's Avatar
bj1k
Thanks,Matt
Jack it up and a visable check will probably show something when you move the wheels and axles.
Old May 19, 2014 | 11:57 AM
Corvette_Ed's Avatar
Corvette_Ed
Jack your car up lately? Your mother-in-law would like to get out from under the car.
On the bright side, you won't have to worry about being invited to her house this Christmas.
Old May 19, 2014 | 12:23 PM
onlyavette's Avatar
onlyavette
A4
I feel bad for you but it just sounds like bad luck to me. I now have 98k on mine and so far it has only needed all of the idler bearings replaced. There are more c5's without these kinds of things happening than with.
Old May 19, 2014 | 12:50 PM
Sox-Fan's Avatar
Sox-Fan
shifter cable?
Old May 19, 2014 | 10:02 PM
Post up what you find. Hope it is a relatively easy fix.
Old May 19, 2014 | 10:10 PM
El original's Avatar
El original
Sounds exactly like a loose wheel...but you made it home without loosing it. Should have checked immediately incase the wheel nuts were missing. Doesn't sound like it will be a problem diagnosing this problem.
To Help please....
