Traction control box
Old Dec 28, 2014 | 12:24 AM
lectroglide's Avatar
lectroglide
Default Traction control box
checkin out this 2001 C5 and sounds like the traction/suspension control box is gone bad, question is what would replacement cost run, or is it a DIY job?
Old Dec 28, 2014 | 12:26 AM
jdvann's Avatar
jdvann
What indicates it's bad? DIC or some other light?
Old Dec 28, 2014 | 12:42 AM
lectroglide
Guess they took it in to GM dealer/repair shop and that was their finding, that's all the info available
Old Dec 28, 2014 | 08:22 AM
Phanni's Avatar
Phanni
Since it's a 2001, the box you speak of is likely fixable. Do not let a dealer tell you differently. FWIW, that box is called an electronic brake control module (EBCM). Do a search on EBCM fix and you will see what is involved.
Old Dec 28, 2014 | 02:17 PM
lectroglide
its all making sense now and just rememeberd the ebcm can be repaired after 2001 and up, I think...............thanx
Old Dec 28, 2014 | 02:24 PM
Chicago1's Avatar
Chicago1
easy dyi fix
Old Dec 28, 2014 | 04:19 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When you get the messages on the DIC,, WITHOUT turning OFF the ignition, use the reset button to clear the messages and read the DTCs with the engine running. When you turn the ignition OFF, the EBTCM clears the DTCs and you will not see all the codes that are being thrown.
Bill
To Traction control box
