C5 Rear diffuser making progress
Old Apr 6, 2015 | 02:47 PM
  #101
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Originally Posted by Death Dream
Why do people want this so bad? I just don't see it o.O
It looks great to the untrained eye. The problem so far--NO down
force. That's why I have one, that's why track folks turn up their
nose at form not following function.
Granted the Op has not finished this project and I believe he will
be attempting to have downforce.
PS OP----The empty space between the exhaust needs to be filled
in. You loose all your downforce with a gapeing hole in the middle.
The air instead of flowing under your car is blowing out the back.
deflate ing the preasure under your car. You could possibly offer
a bolt on plate to those that need function. Just a idea.
Old Apr 7, 2015 | 04:38 AM
  #102
crazystevex's Avatar
crazystevex
1. Because it looks good.
2. Because no one has been able to do it without it being a gigantic pain in the a$$.
Old Apr 7, 2015 | 08:36 AM
  #103
Stealth02's Avatar
Stealth02
Yes I am addressing the under pan for the ones that are concerned with function. I feel also that there is enough interest for one not so elaborate for the common street car. Probably more so. There are way more C5's that are for enjoyment than acrual ones that see the track. So you have to look at where you greatest market is as well. But I will be making one with the under pan to accomodate both sides. Road pilot I would still like to see pics of your setup. Here is a pic of what I am looking at to incorporate into my panned diffuser. Again thanks for the feedback.
Old Apr 7, 2015 | 09:28 AM
  #104
mre1974's Avatar
mre1974
VERY PROMISING so far. I'm curious if it would be possible for you to do the version with the under trans piece as a removable piece that you can add to the "street" version? That way you could have a modular design that should help in costs to produce and sell. Just a thought.
Old Apr 7, 2015 | 10:55 AM
  #105
MotoJB's Avatar
MotoJB
Ok, then bow out Mr. Buzzkill.
Old Apr 7, 2015 | 11:11 AM
  #106
Sox-Fan's Avatar
Sox-Fan
I'm sure that I'm late to the party, but how is the muffler heat going to be vented, or is it?
Old Apr 7, 2015 | 03:10 PM
  #107
road pilot's Avatar
road pilot
I will try to snap a picture later in the week. Vette will be in the shop up on a lift. Your really doing a fine job. Just for a reference I have
no mufflers or catback. I installed a small Magnaflow muffler
much closer to the collector (I have headers). I wonder if a stock
setup will be to much heat for the glass/carbon pan. At least that's
what I did.
Old Apr 7, 2015 | 03:53 PM
  #108
~STOLEN~'s Avatar
~STOLEN~
i WANT one
lmk what it costs to replicate
you did a fantastic job
Old Apr 7, 2015 | 09:12 PM
  #109
Stealth02's Avatar
Stealth02
I have discussed this issue with a few people. There is enough under draft that flows over the exhaust for sufficient cooling. If this was an issue the C6 would have been designed differently.
Old Apr 7, 2015 | 09:18 PM
  #110
Stealth02's Avatar
Stealth02
Thanks for the feedback. This is food for thought. I may try and make a under pan that will attach to this and look as if molded in.
Old Apr 7, 2015 | 10:40 PM
  #111
mre1974's Avatar
mre1974
I would assume it would also aid in maintenance of the rear if/when needed.
Old Apr 7, 2015 | 11:50 PM
  #112
Chicago1's Avatar
Chicago1
Stop bugging so he can finish!!! lol
Old Apr 8, 2015 | 07:33 AM
  #113
SuperTom's Avatar
SuperTom
Seriously let him finish the original design first. Every time someone starts to make a rear diffuser the racecar guys come in and want a track diffuser. If it can be made with an add on undertray later on that's great but let him finish his original design first.
Old Apr 8, 2015 | 09:11 AM
  #114
Sox-Fan's Avatar
Sox-Fan
But it is designed differently! On the c5 the mufflers are horizontal and on the C6 they are aligned longitudinally. On the C6 the air flows straight over them and out as they are centered in the chassis and aligned longitudinally. The c5 has those two slots in each side of the rear bumper to vent the muffler heat because the mufflers are horizontal and the bumper cover hangs down over them. You have closed the slots.
Old Apr 8, 2015 | 04:58 PM
  #115
Mike94ZLT1's Avatar
Mike94ZLT1
Originally Posted by Mike94ZLT1
So what are you going to do about heat from the mufflers? GM put those slits there to let heat out and people still have problems with their rear bumpers warping, which is why companies like ACI sell braces for them. The C6 doesn't have vents there because the mufflers are not placed right against the bumper.
I said the same thing earlier. GM added those slits on purpose to allow heat to escape, because bumpers were warping from heat. What if you were to add some sort of vent in that area to allow some heat to pass through?
Old Apr 8, 2015 | 05:17 PM
  #116
Stealth02's Avatar
Stealth02
I'm not sure how much heat if any is actually vented through these vents. Wish I could do some wind tunnel test to have an actual visual of the venting and wind drag. I put over 1000 miles on this diffuser with no issues of heat stress on the diffuser or the rear bumper fascia. I will look more into the heat retention as testing goes on. Thanks for the feed back.
Old Apr 8, 2015 | 05:32 PM
  #117
Sox-Fan's Avatar
Sox-Fan
fair enough. Thanks!
To C5 Rear diffuser making progress
Old Apr 12, 2015 | 09:55 PM
  #118
Stealth02's Avatar
Stealth02
Update. I met with the vendor this past week. Have a mold maker coming up in a couple months and will hand it over to him to start the process of reproducing. During this time I will be working on an add on under pan. Also we discussed the various exshaust designs and how to accomodate most all with the same diffuser. This is a challenge but I have a few solutions. I fit and built my diffuser using a B&B quad bullet set up. Excellent for this because there is no oval can behind the vents. If you run a Corsa tigershark which probably has the largest can out there this causes a interference with the diffuser.The Corsa actually sets about 3/4" below the bottom of the rear fascia. I will mold the diffuser as designed and supply templates for trimming per type of exhaust used. Also thinking of an add on piece to cover the the muffler where diffuser was trimmed.
Old Apr 13, 2015 | 06:47 AM
  #119
Arc07's Avatar
Arc07
2026 Corvette of the Year Finalist - Modified
2025 C5 of the Year Winner - Modified
Great news. I can't wait.
Old Apr 13, 2015 | 10:17 AM
  #120
SuperTom's Avatar
SuperTom
I guess a couple months isn't that bad of a wait considering we've been waiting for years
