Tires
Old Feb 15, 2015 | 07:10 PM
Gretal73's Avatar
Gretal73
2nd Gear
Default Tires
I have a 2003 50th anniversary convertible can I put a 305/35r18 on the rears and how aggressive of a cam can I put w/o having to change to much
Old Feb 15, 2015 | 07:36 PM
stu12dozen's Avatar
stu12dozen
Remember, Google is your friend. IMHO, I feel that instead of mods, your money would be better spent on an English tutor to assist you with grammar and punctuation.
https://www.corvetteforum.com/forums...c5-wheels.html
https://www.corvetteforum.com/forums...-stock-c5.html
Old Feb 15, 2015 | 09:08 PM
That's a rather response - and people wonder why some new members get discouraged and quickly form a negative opinion about this forum.
OP - as far as the 305 tire goes, that should be fine as long as you have rear wheels that will support that width tire. Check with the Tire Rack's web site - pick a tire and then check the specs they list - it will have the recommended wheel width for each size tire.
Old Feb 16, 2015 | 03:23 PM
John Madeja's Avatar
John Madeja
TireRack is very useful!
but as long as he has 18x10.5 rears or larger rims he should be fine I believe...stock coupe rears were 18x9.5 if im not mistaken
To Tires
