Headlight Questions
Old Apr 16, 2015 | 03:14 PM
JTW1984's Avatar
JTW1984
2nd Gear
Default Headlight Questions
My passenger side headlight has a larger gap between the top of the closed light and body than the driver's side. I can fit my index finger inside. Can't do that on the driver's side. Carfax said the car had never been wrecked. I can't send pics now. Could someone post a pic of their hood with both headlights down??
Old Apr 16, 2015 | 04:23 PM
frsr06's Avatar
frsr06
The headlights are both supposed to be flush with the hood and front bumper when closed. Your problem is caused by either missing or worn out little plastic/rubber stops that are on the headlight bucket. The little rubber stops set the travel of the light bucket and if missing allow the light to over travel or recoil because it would have hit metal to metal rather than metal to rubber. Had the same problem on mine. There are 4 rubber stops on each light.
It's called Insulator and the part number. C5 Insulators / Bump Stops Part # 16524060 - See more at: http://www.corvetteactioncenter.com/....8MsL00M4.dpuf
I paid about $4 each - your should be able to buy them at Cultrag - one of out best vendors here on the CF
Old Apr 16, 2015 | 04:24 PM
MAC5's Avatar
MAC5
Check the link below about the same subject, pic of 98 located in post #6 Hope it helps.
https://www.corvetteforum.com/forums...bly-cover.html
stu12dozen's Avatar
stu12dozen
The headlight covers should fit flush with the body. Have you tried to raise and lower the headlights manually (see owner's manual)?
C5's came with plastic gears for the headlights. They are known to wear out and then fail to operate properly. Bronze replacement gears are available from a couple of our vendors and not a big job to install.
https://www.corvetteforum.com/forums...orialized.html
Old Apr 16, 2015 | 05:42 PM
RVETT42's Avatar
RVETT42
Its one of two things rubber bumpers or head light cover on top is out of adjustment.
To Headlight Questions
