Does anyone else wait when starting your car?
Old Jun 16, 2015 | 07:40 PM
Fcar 98's Avatar
Fcar 98
Although, I have the dreaded "early" 1998 model.
Never have waited for the gauges to settle before starting the car. Have not experienced any problems either.
Old Jun 16, 2015 | 07:49 PM
grantv's Avatar
grantv
I did read somewhere that you are supposed to wait until the dash is done its sweep. Probably here.
Old Jun 16, 2015 | 08:11 PM
mclaugj's Avatar
mclaugj
Me too I read it on the Forum. Wait let things settle down then start the car. Sounded like good advice. Sure can't hurt.
Old Jun 16, 2015 | 08:16 PM
Odinson's Avatar
Odinson
I wait for the sweep and have pretty much waited in all my cars for the fuel pump to prime before starting.
Old Jun 16, 2015 | 08:54 PM
Deneb's Avatar
Deneb
I enjoy watching it, too. Let it idle for a bit afterward and drive her real slow till I feel she ready to be riden. Corvettes have a real life quality that reminds me of the west and riding horses in some abstract way.
Old Jun 16, 2015 | 09:34 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Sometimes yes, sometimes no, most times yes !!!!!
Old Jun 16, 2015 | 09:39 PM
caroutisine's Avatar
caroutisine
I get in and just hit the key.
Old Jun 16, 2015 | 09:57 PM
o2bnkc's Avatar
o2bnkc
I always wait for the fuel pump, too.
Old Jun 16, 2015 | 11:48 PM
scarecrowkc5's Avatar
scarecrowkc5
I get in to start it I turn the ignition on and wait about 15 seconds for all the bells, whistles, pumps etc to settle down and then I fire her up.
Hey ... they have to wait for all the systems to power up in a fighter jet so why wouldn't it work on a c5?
Plus, it's kinda cool ...
Haha.
Old Jun 17, 2015 | 12:31 AM
striper's Avatar
striper
I never do it and at 134k miles still no problems. I'm not fixin' what ain't broken.
Old Jun 17, 2015 | 01:14 AM
Nyt_Muves's Avatar
Nyt_Muves
Default Does anyone else wait when starting your car?
I was taught to wait on all fuel injected cars to give the fuel pump a chance to build proper pressure before starting.
Old Jun 17, 2015 | 02:25 AM
Choreo's Avatar
Choreo
The only thing I wait for is to say a little prayer before turning the key in hopes that the starter will not break a chunk off my engine block again... one new engine is enough!
Old Jun 17, 2015 | 08:49 AM
  #33
VettesGoneWild's Avatar
VettesGoneWild
I also wait for the gauge startup routine to finish with the thought of potential voltage drops and or spikes during cranking could generate false error codes or worse. I have seen in my computer electronics job IC devices work as intended until a voltage variation as little as 1/4 (.25V) or even less off from 5V fail. They are spec'd to run at 4.75V-%.25V but not always the case.
Old Jun 17, 2015 | 09:03 AM
  #34
runner140*'s Avatar
runner140*
I was watching a "froggy" video on YouTube the other day, and he said, always wait until the gauges settle before starting the car.
Prior to that, I never heard that on Vettes.
Old Jun 17, 2015 | 09:23 AM
  #35
darkredlt1's Avatar
darkredlt1
hello Lambert55
My best guess is you have a bad ground.
try reposting in C5 tech
Alan
Old Jun 17, 2015 | 09:34 AM
  #36
TXGS507's Avatar
TXGS507
Call it OCD.. I do the same thing.... turn on the key, wait for the bells, gauges to do the full sweep, then I start her up....
Originally Posted by Psydef
I do this too. No real reason why but I always wait for the gauges to drop back down to zero before starting
Old Jun 17, 2015 | 01:13 PM
  #37
Lee DeRaud's Avatar
Lee DeRaud
Originally Posted by JR-01
Wasn't there a post explaining that the computer scans all the systems during the gauge sweep?
Sort of, but it's more a case of things happening at the same time. The description in the FSM implies that the gauge sweep is strictly an internal function of the IPC. I suspect that whatever scans take place elsewhere take far less time than the gauge sweep and other turn-on bells and whistles.
Also, it appears the PCM and BCM both need to be running and communicating or the starter won't crank anyway. (Theft deterrent runs through the BCM, clutch/neutral enable runs through the PCM.)
To Does anyone else wait when starting your car?
Old Jun 17, 2015 | 01:19 PM
  #38
Lee DeRaud's Avatar
Lee DeRaud
I agree about variation in 5V being a bad thing, but I don't see how waiting another 10 seconds helps. It's not like voltage drops/spikes become less of a problem at that point.
Old Jun 17, 2015 | 03:56 PM
  #39
Rodster21's Avatar
Rodster21
Originally Posted by Steve Guenthner
Always wait for gauges to settle before starting!
i do this also
Old Jun 17, 2015 | 08:33 PM
  #40
ZigZag's Avatar
ZigZag
Seat belt first then turn key and wait for bells and whistles to settle then start. Once in a great while I get the pull key and wait but not very often.
