Best c5 mod.
Oct 24, 2015 | 11:31 AM
Best c5 mod.
If you could only do one mod to a c5 what would it be?
Oct 24, 2015 | 11:39 AM
Well the problem for me was I couldn't do just one mod! I've done wheels & tires, Audio upgrade, Led upgrade, a few exterior things, the list goes on. The very first mod I did was put an aftermarket exhaust on, stock was to quiet for me.
Oct 24, 2015 | 11:44 AM
Quote:
Originally Posted by
garline14
Yeah, exhaust is high on the list along with a CAI. I've done the tires and upgrade headlights. Mines a 99' so it starts off a little light in horsepower verses later c5's I'd like to fix that issue. Some guys say a dyno tune could get me as much as 30 additional horsepower.
Oct 24, 2015 | 11:56 AM
The elephant in the room is..........
SUPERCHARGER!
Oct 24, 2015 | 12:00 PM
St. Jude Donor '14-'15
Take a basically stock C5 Corvette,
SuperCharge it.
Go from 314 RWHP to 504 RWHP.
It's awesome, reliable, drives (almost) like stock, until you 'ask it for more'... then it's nothing like stock!
You will, in time, need bigger rear tires, more often, though.
Don
Oct 24, 2015 | 12:01 PM
sfc rick
SUPERCHARGER!
Thats interesting, how much does that gain you and what is the appropriate cost.
Oct 24, 2015 | 12:04 PM
Intake airflow and exhaust . . . .then suspension, wheels and tires.
Oct 24, 2015 | 12:45 PM
cmorgan
200rwhp and 10k done right
Oct 24, 2015 | 12:53 PM
ONE BMF
If it costs you 10k then you haven't just done one mod hahahs.
Oct 24, 2015 | 12:57 PM
The ONE mod that I think I have appreciated the MOST and the ONE that I would do IF I could only do one... would be the C6 Z06 shock upgrade.
Oct 24, 2015 | 01:14 PM
73Corvette
Along with the C6 Z06 sway bars.
Those that go for more HP without better handling are (IMNSHO) fools,
Oct 24, 2015 | 01:19 PM
Phanni
That's two Phanni...
Oct 24, 2015 | 01:41 PM
Phanni
That's a good point until I upgraded to the Michelin pilot super sport tires this thing was a handful stock.
Oct 24, 2015 | 01:52 PM
cmorgan
Drag radials. Without traction you are not getting anywhere fast enough.
Oct 24, 2015 | 01:53 PM
I believe in beginning from the ground up and that is why I always start with suspension. My Koni sport shocks is the single best mod I've done. So to answer your question, shocks!
Oct 24, 2015 | 03:07 PM
The PROBLEM with your THREAD is that MODS are like LAYS potato chips
Oct 24, 2015 | 03:16 PM
The OP said ONE MOD, not implying one mod if you only had $200 to work with. He simply wanted opinions on what ONE MOD would be good.
The one mod bunch that only says handling options are OK, but having that Prius screaming at you to get out of the way is going to be a downer.
And saying others are fools is just **** poor manners or jealousy for being too slow.
Oh *&&^^% just never mind....... buy a hood seal.
Oct 24, 2015 | 03:27 PM
Tires. Especially if you are on run-flats...
Oct 24, 2015 | 03:30 PM
Shifter.. I can suffer with a slow stock car but that shifter.. Terrible
Oct 24, 2015 | 04:09 PM
Put a screw in the throttle pedal to keep from hinging.
