winter storage - midwest
Old Nov 20, 2015 | 10:39 AM
ken90004's Avatar
ken90004
Default winter storage - midwest
I'm looking for a winter storage thread. I know there has to be one around. Can anyone give a quick run down on how you store for the winter
We do have mice problems every winter. I've never got them in the cars or the camper, but I was planning on putting moth ***** in the engine, trunk, and floor boards, just in case.
I am thinkig about leaving the battery in, to start it once a week. But is it better to leave the battery out and let it sit until March?
Old Nov 20, 2015 | 01:34 PM
JR-01's Avatar
JR-01
From the research I have done, the experts do not recommend starting and idling over the winter. Idling for long periods is not good for anything. It introduces moisture into the engine and exhaust, clogs the catalytic converter and 75% of wear occurs during startup and warm up. I always put it away hot, cleaned and waxed, full tank of gas, gas stabilizer, over-inflate the tires, park it on a vapor barrier, mothballs, Irish spring and a bucket of Damp Rid in car and under the hood. I pull the battery and put it on a tender in the basement and cover the car. I have done same thing for 40 years and in the spring it's just like it was when I put it away.
Old Nov 20, 2015 | 01:58 PM
jr105's Avatar
jr105
I store mine in Maine where last year the temps hit -25 and all I do is clean and polish, fill the tank, pull the battery and cover it. In the spring I put the battery in and it starts right up. The only thing I need to do is re-sync the keyfob and re-do the radio presets.
Old Nov 20, 2015 | 02:01 PM
JR-01's Avatar
JR-01
My FOB works and the presets are still there after I put my battery back in. Do you have an aftermarket radio?
Old Nov 20, 2015 | 02:35 PM
CalF's Avatar
CalF
I put a 20 oz bottle of Techron concentrate in with the tank below halfful,l THEN fill up so it reaches both tanks.Clean up car and put Bounce dryer sheets inside on floors and behind seat area plus the trunk if a FRC. Moth ***** in a couple of plastic butter tubs under the hood and even a tub or 2 under the car.No moth ***** inside car,the smell will linger.Set mouse traps and D-con out.I put carpet patches or heavy cardboard under tires and a heavy plastic vapor barrier to cover the unheated garage floor.Cover exhaust tips with old tube socks.A good quality battery tender(not charger), so you can leave battery in car.Some folks overinflate tires but i just check them about once a month.Lock it ,cover it and do not run unless you plan on taking it out on the road for a good drive to burn off any moisture.I change oil etc in spring since i only put less then 800 miles a year on it and the oil can't be that dangerous just sitting in the pan.Next spring its like getting a new toy all over again.
Old Nov 20, 2015 | 04:12 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Growing up in Indiana...I guess it would depend on how the car is kept.
If it stays in a relatively climate controlled garage that is going to help a ton.
This is what I did with dad growing up.
-Fill the fuel tank with fresh fuel
-wash the car
-change the oil
-wax it
-parked it on carpet pads
-put some Oder / moisture absorbing packs inside
-put a battery tender on it.
We never started them once they sat but the cars were typically only in there from November to say March. If it is going to be in storage a lot longer than that, then yes you would need to do some other things to it. Same would go with a race car or something that might use a more volatile fuel.
Old Nov 20, 2015 | 04:15 PM
Rico7142's Avatar
Rico7142
St. Jude Donor '16
I pretty much do the same, minus the mouse traps..dont really have a mouse problem where Im at..
Old Nov 20, 2015 | 04:24 PM
JR-01's Avatar
JR-01
I didn't think I had a mouse problem until they ate the wiring on my GMC pickup. One mouse can really ruin your day.
Old Nov 20, 2015 | 04:36 PM
Rico7142's Avatar
Rico7142
St. Jude Donor '16
Thanks!! Better to be safe than sorry!!
Old Nov 20, 2015 | 04:43 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
mine shows what they mean when they say "I put mine up for the winter"
nice and warm !!!!!!!!!
Old Nov 20, 2015 | 07:00 PM
jr105's Avatar
jr105
No, I have the factory radio.
Old Nov 20, 2015 | 07:05 PM
JR-01's Avatar
JR-01
Interesting. I have to do nothing when I re-install the battery in the spring. Everything works as before.
Old Nov 20, 2015 | 08:32 PM
I'm in the Midwest and here's what I do to store my car for the winter:
  • Clean all areas of car, including engine bay, wax car, detail interior.
  • Add a bottle of Sta-Bil and fill gas tank.
  • Put a few extra lbs of air in tires and put a piece of old carpet under each tire to get the tire off the cold cement floor.
  • Put Bounce dryer sheets in engine bay and interior to keep any critters away.
  • Change oil and filter.
  • Hook up battery tender.
  • Put car cover over the car for a long winter's nap.
I do not start the car up unless I plan to take it for a decent drive that would get all fluids up to operating temp and allow any moisture to be eliminated from areas such as the exhaust.
Here are a couple of files that may give you some other ideas, depending on how long you need to store the car.
File Type: pdf
File Type: doc
File Type: doc
File Type: doc
Old Nov 21, 2015 | 09:00 AM
DA1984VETTE's Avatar
DA1984VETTE
I just cleaned mine up as mentioned in the above posts. I filled the tank and added a bottle of Techron. Put the battery tender on and covered it up. I don't start mine either. And she has a cover on her for her long winter nap....Now that long wait till Spring.
Old Nov 21, 2015 | 11:56 AM
It'sOver9000!!'s Avatar
It'sOver9000!!
Chicago suburb resident here; like akapounder, I also literally put mine up for the winter by having her hibernate on the four post lift.
My usual ritual is to:
- Fill the gas tank up and run Sta-Bil
- Clean the exterior and interior
- Change the oil
- Overinflate the tires
- Hook up the battery tender so the battery can stay in the car
Then I throw the car cover on and up she goes for the next 4 - 5 months of hibernation. Just did this last night thanks to snow we're getting hit with right now. With the weather being as mild as it was recently, I was hoping to get at least a couple more weeks out of the year, but... oh well.
Since buying the new house and the lift I haven't used moth ***** or anything, but back when I lived in the apartment where the car was stored in a detached garage where I DID see mice occasionally, I used the moth ***** and never had an issue with rodents. Someone's thread also mentioned using socks to cover up the exhaust tips; I think that's a great idea1 (the woman also thinks it's "cute"... go figure)
Old Nov 21, 2015 | 12:09 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
- Change the oil
is that the SS TrailBlazer you mentioned a while back ? how is that working out for you ???
Old Nov 21, 2015 | 12:13 PM
jhopper408's Avatar
jhopper408
I leave the battery in the car and hook the battery tender up to it. And that's it. I've been doing the same for 40 years.
To winter storage - midwest
Old Nov 21, 2015 | 12:56 PM
It'sOver9000!!
It sure is! So far it's been great with no real issues. Puts a smile on my face every time I turn the key, just like the 'Vette! Now that the snow's here though I'll have a lot more time to spend with her. Gotta try to find an empty parking lot to try donuts for the first time
Old Nov 21, 2015 | 03:55 PM
JR-01's Avatar
JR-01
Whatever works for you. Learned a few lessons in my youth so now I like to take some precautions to avoid any surprises in the spring. I have had a battery freeze, wiring chewed up, mice nesting inside the seats, under the hood and up the exhaust pipe, had a flat-spotted tire once and had to buy a new one and back in the 60s when I was 16 I forgot to check the coolant and cracked a block.......
Old Nov 21, 2015 | 04:09 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
