Unexpected acceleration
He's got one I've never had or heard of. On a few occasions engine unexpectedly revs up. I heard it happen once He had just put it in park (yes, its an A4) in my drive way. I thought he was just gunning it up for fun. He said no, didn't touch the gas.
He told me today it did same thing. His foot on the brake and in gear and in traffic and was pulling against the brakes Said it went back to idle pretty quickly. Sounds dangerous to me.
Has anyone heard of a problem like this and what might be the fix?
Are C5's accelerator by cable or by wire? Haven't seen an authoritative answer to that.
Thanks for any help and advice.
Since it's drive by wire, any failure of the electronics should result in reduction/loss of throttle pedal response and error codes on the DIC.
Maybe there is something mechanically wrong with the throttle pedal assembly. Maybe it was removed and not re-installed properly.
The OP spent hundreds of dollars on parts and NUMEROUS hours troubleshooting.
NOTE! The signals that control the Throttle have an A side and B side (PHASE) The A signal voltage is 180 degrees out of phase from the B signal voltage. The TAC MODULE and the PCM carefully monitor this OUT OF PHASE condition and IF, there is ANYTHING that does not match what the PCM expects the throttle or the accelerator peddle to be, the PCM will put the engine into REDUCED POWER MODE!
When its in REDUCED POWER MODE the accelerator peddle will NOT respond to anything that you do to it and the Throttle motor locks the throttle blade in the last known good idle position. Your lucky to be able to LIMP down the side of the road to a pull off location.
SO,, all that being said,, The OP of that Post up-dated the post saying that; (paraphrased) After all the troubleshooting and parts I think my BIG FEET was accidently pressing the accelerator sometimes when I was pressing the brake!
HOWEVER,,, ALL THAT BEING SAID,,, IF,, Unmetered air is getting into the engine via a VACUUM LEAK, it can cause the idle to raise. That was/is the very first thing that came to mind when I read this post.
Check ALl the vacuum lines and anywhere that un metered air can get into the intake manifold.
BC
BC
Occurs on hard acceleration always shows as (H)istory when codes are pulled. Don't think that could be related subject of this thread "unexpected accelleration". But who knows? When I've driven and rode in car it seems fine maybe stronger than my 2004. Haven't put them side by side.
Wondering if PO did some kind of crazy tune. advancing timing, etc. I don't have tools or knowledge to help him determine that.
