Rear Diffuser install PIC HEAVY!
I went to ACE True Value and gathered all of the mounting hardware. Mine was absent as well. For the vent mounts I got 4- 1/4" × 1.5" long flanged head bolts for the vent mounts. 4-1/4"×2" wide flanged metal washers and 4-1/4"x2" wide flanged rubber washers. For the lower outer fin mounts I believe I bought 2- #8×1"long flanged head bolts with washers. I also bought 2 aluminum storm window brackets to hold the fin secure to the lower part of the bumper near the wheel opening. The four tabs on the diffuser above.the exhaust need to be drilled with either a 1/2" to 9-1/6" hole. Use your exsisting plastic push rivets to secure these four mounting points. Hope this helps.
Question: does this mount using all four of the rear vents, or just two? If the latter, would it be feasible to open up the other two in order to provide some form of heat extraction? If trimmed properly with a mesh grille behind, perhaps some of the heat could escape…?
First, it's a nice product but the install can be frustrating.
Before attempting the install, tap the threads for the inserts in the back. They get filled with resin and partially covered. Test some 1/4" bolts to make sure they thread in VERY easily.
The biggest obstacle during the installation is the exhaust. I have the stock Z06 exhaust and if you drop the exhaust and install the diffuser you won't be able to get the exhaust back over the diffuser.
What you have to do is drop the exhaust, keep it supported, install the diffuser with the mufflers still above the diffuser (but loose and unbolted). You need to leave them unbolted so you can move them around to get your arms behind the bumper. You will have very little space to work with since the mufflers have to stay above the diffuser. This makes locating the threaded inserts in the rear bumper vents extremely frustrating. This is also why it's extremely important that you tapped the threads, otherwise you will fight for an hour trying to start the 1/4" bolts.
I neglected to use any double sided tape during the install, it doesn't stick well to the back of the diffuser anyways.
Lastly, since the carbon fiber diffuser doesn't have any threaded inserts on the outer most fins, I decided to just drill right through the bottom and use a long 1/4" bolt with a nylon finishing washer to keep it all together.
Looks like it would stand out, but with the car on the ground you can't see it at all when standing beside the car. It's obviously hidden under the diffuser.
I think I sort of like how it looks in the pictures, but given the overall mass that is my C5's rear end, I'm just not clear as to why one would do this.
Is this an attempt to copy the looks of late model sports cars?? Please tell me that's not what's going on here.
It's a vanity piece.
I should be getting a Carbon Fiber version soon.
