What octane
I live on the coast and have 87 no ethanol available. Some areas of the country no ethanol is not available.
It is about ethanol vs no ethanol....I could careless if fuel was $10.00 a gallon! I was only trying to help the fuel system!
I once raced drag boats, so I understand the value of quality fuel and I do not need you to tell me what car is for me or not!
4500 miles of a steady diet of 87 octane in my 99, no signs of ill effects, no knock, runs smooth, 22mpg avg per tank of mixed driving, the computer seems to adjust just fine, is it down on power? Maybe, do I care? Not really. it's my daily driver, I'm not too worried about that extra 5-10 hp... Has there been any dyno tests running a stock street car back to back with 87 and 93 octane with no other changes? I'd be interested to see what difference it makes in a 2 valve average compression motor...
Just don't see there's any significant performance benefit to running hi-test in a daily driver
Besides like somebody said, there is so much misinformation on ethanol, people think it's a death sentence for your car. Just look at Brazil, every one of their cars is flex fuel by law, and they don't have any more problems with fuel systems than anywhere else in the world.
" THE LSX engine was not designed to use 87 Octane on a regular diet. in an effort to make it idiot proof we added the disclaimer that you could use 87 Octane to get you to a gas station that had premium fuel.. ( the idea was ) that the car would not blow up over a 30 mile trip to the next gas station. WE tried to make it idiot proof...
we did extensive testing and found that using reduced octane fuel caused internal damage over time to wrist pins, rings connecting rod and main bearings and specifically # 7 piston.
Every time you load the motor with 87 octane, step on the gas, shift gears then call for a load the engine will ping. this detonation before top dead center cause a double explosion.
1) when compression causes detonation ( not ENOUGH octane ) and then a second time when ignition spark fires. causing the rotating mass to prematurely fight the potential energy of the rotating mass. You would have to be plain stupid to allow your engine to detonate on a daily basis.
Pinging is the internal destruction of the rotating mass... over time this will cause engine damage to an engine that can easily see 400K. using 87 octane on a regular basis will cause loss of oil pressure over time and damage to the components I mentioned ..this was found in destructive and non destructive testing of the LSX motor design... WE did this testing because Dave wanted a 200,000 mile bench marked engine.. The first engine on the planet to be so certified.
Like I said, you would have to be an idiot to use 87 octane on a regular bases, unless you detuned the motor so much that the loss of power would be very noticeable. detune to prevent any detonation under any load.
Every time the engine pings in causes timing retard... "BUT>>>> the ping occurs first.. every time. Ping is internal destruction of the rotating mass. NO, the car does not stay in timing retard, once the load is off, the engine goes back to regular timing.. A LsX motor running on regular could see hundreds of individual pings on any given day. every time you demand more HP, to pass a car, go up a hill, make a turn and accelerate.
The sad thing about this is that I have posted thi8s hundreds of times over 15 years here.
Pretty hard to deal WITH STUPID ON A REGULAR BASIS,... BUT I TRIED FOR 15 YEARS.
