I admit defeat.
Old Dec 20, 2016 | 11:47 PM
Sounds like quite the ordeal - best of luck with the builder and with whatever decision you go with.
Old Dec 20, 2016 | 11:51 PM
Rob 02's Avatar
Rob 02
What is the lowest oil reading you have gotten? 19-25psi when hot under a high demand is acceptable. You could also be getting an erroneous signal from your sending unit.
I would think that the engine would get real noisy under true oil starvation. The lifters would be causing all kinds of noise. Secondly you have gone through the entire oil system twice. An internal bearing issue or clog would not usually be intermittent. Unless there is a plastic bag floating around in the oil pan.
Old Dec 21, 2016 | 12:05 AM
derz_vette's Avatar
derz_vette
19psi hot at ~1k rpm, using 10w-30. was the lowest reading I ever saw.
Under load... 30~psi at 4-5k rpm (once it started dropping)
I agree it doesn't sound like clearances, because that should be present at all times (although could be the reason for sub-typical oil psi at idle, so it could be present at all times, and the psi drops at high rpm due to it... not sure)
We really have done everything out side the block I can think of.
Old Dec 21, 2016 | 12:33 AM
Rob 02's Avatar
Rob 02
I would check inside the oil pan. There could be a rag, plastic or tape in there from the engine build.
I was wondering too, if the oil sender could be different on the LS3.
I have built several LS engines and there isn't a whole lot parts inside that restrict flow in the way you are describing. And no lifter noise.
Old Dec 21, 2016 | 12:56 AM
derz_vette's Avatar
derz_vette
I guess we will be removing engine regardless so we will pull off the pan and see if anything is in there.
-We are currently running a mechanical gauge where the sending unit is... so not even relying on electronics at this point. (and have used multiple gauges... they aren't broken._
I'll post up a video when i can.
Old Dec 21, 2016 | 01:30 AM
Rob 02's Avatar
Rob 02
That is pretty much all I can think of.
Wish I could have been of more help.
It will be interesting to see what the cause is.
Old Dec 21, 2016 | 04:10 AM
Rob 02's Avatar
Rob 02
I wouldn't complain about 19psi if that is as low as it gets though.
Old Dec 21, 2016 | 08:13 AM
BMan0660's Avatar
BMan0660
If I weren't on the other side of the country, I'd almost trade you my running engine for yours so I could sort it out
Old Dec 21, 2016 | 01:25 PM
typeav's Avatar
typeav
you have to get in line
Old Dec 21, 2016 | 05:20 PM
derz_vette's Avatar
derz_vette
I agree, the idle really isn't an "issue", It is simply the fact oil pressure stops building and starts dropping the higher the rpm above 4k... Don't know what happening inside the block, and its not worth driving the ticking time bomb around :| As others have suggested.. if the builder won't step up and cover some of the labor costs they have incurred on me (they did have a wrong cam gear in there first off) then I'll request a refund, and find another engine I can throw in maybe.
otherwise... toastito vette
Old Dec 21, 2016 | 07:04 PM
derz_vette's Avatar
derz_vette
A video of the issue:
https://drive.google.com/file/d/0B11...ew?usp=sharing
A pic of the oil orings I have - the orange one was in the engine previously, and we used another similar that was included with the TSP pump. As you can see, there is no damage to the oring, and the orange fits the best out of all the orings. I originally thought the black oring was supposed to be used.
If you want me to host these on imgur, just let me know. I don't know how informational they are.
https://drive.google.com/drive/folde...Dg?usp=sharing
In the background of one of the pics, you can see the incorrect cam wheel we removed. I forgot to get a good pic of it.
Old Dec 21, 2016 | 10:46 PM
kp1's Avatar
kp1
I'm wondering if someone didn't install the oil galley plug in the rear of the engine.
Old Dec 21, 2016 | 10:58 PM
  #33
Rob 02's Avatar
Rob 02
^that was on my mind as well but I never ran into that issue. I'm not sure what trouble that would cause but would be a quick fix. It does have O rings that could fail.
Old Dec 21, 2016 | 11:01 PM
  #34
derz_vette's Avatar
derz_vette
I'll check this tomorrow with a boreoscope. Wouldn't there be larger issues if the galley plug was missing? Filter wouldn't be working and would be just stumped with oil. Also - wouldn't it leak out the back? Or is there a back plate that would drain the oil back to the pan?
Old Dec 21, 2016 | 11:10 PM
  #35
Rob 02's Avatar
Rob 02
It looks like this.
Name:  800-811 Oil Galley Plug LS1-900x900.jpg
Old Dec 21, 2016 | 11:13 PM
  #36
Rob 02's Avatar
Rob 02
It is under the rear cover though on LS1/ LS6 (not sure about LS3). It does have an effect on oil pressure.
Old Dec 21, 2016 | 11:18 PM
  #37
derz_vette's Avatar
derz_vette
Yup - I actually have the little billet one from SCC(?) on hand as well... although if it is missing...
I can see this from the oil filter intake port correct? Atleast the end of the barbell.
To I admit defeat.
Old Dec 21, 2016 | 11:52 PM
  #38
Rob 02's Avatar
Rob 02
Apparently it only forces oil into the filter.
I don't think that is the problem. It could be.
Old Dec 22, 2016 | 12:00 AM
  #39
Rob 02's Avatar
Rob 02
I got a feeling the problem is on the suction side of the pump. Either restriction or it is sucking air through a leak. I am assuming you tried more than one filter.
BTW the engine sounds awesome.
Old Dec 22, 2016 | 12:09 AM
  #40
Rob 02's Avatar
Rob 02
The cam retainer plate can be a source for a leak. They are never supposed to be reused and need to be torqued to spec.
