What a PIA!!!
The Pyramids were thought to be 2500 years old, new findings places them at 4600 years old..
Fire has be around for 40,000 years. The First Technology. AS I said...
They don't teach this stuff in College by pulling it out of their ***.
On mine I just had to hit the bolt heads with a hammer to break the threads loose. Then Impact wrench.
The other issue is rust. So if you coat the inside of the rotors ( the vane area ) with a high quality VHT paint, coat the holes, etc, your rotors will look like mine. I detail them once a year. along with my calipers and wheel wells.
The soft pads keep the rotors bright and not discolored by heat soak. What little bit of dust I get is whisked away in about 30 seconds a wheel before I put it away. My rotors are two piece, the centers are aluminum with powder coating, my rotors are bigger than stock but lighter than stock .
Keeping a car nice looking is a matter of focus.. the four corners are critical to keeping a car looking good...
I see guys here all the time posting photos of their wheels or tires, and many times I see, filthy dirty wheel wells. which detract so much from a car that is otherwise clean. You can see the underside of the rear, so its an important focus to keep that clean as well.
dirty
clean
Engine bay, and interior , and the over all look of the paint. My paint is much better than a New car finish. for Me Zaino is the reason. It only takes a one time application a year, it last forever, its 99% optically clear and is UV stable, UV rays can take its toll on the clarity and depth of the clear coat. Been using Zaino for 17 years.
MY car is extremely shiny, and I haven't Zaino'd it in over a year. Been very sick
Installed my stainless vent screens. Super easy and I took the advise of several members and used Velcro so removal for cleaning will be easy. I picked up two packages of oval shaped, low profile self stick Velcro in the craft department of the local Walmart. Cost was less than $5.
Now, for the PIA!!! Yesterday I figured I'd end vacation with doing my pads, rotors and painting my calipers. Jacked the car up onto my jack stands. Removed all the wheels. Removed the caliper bolts and moved the calipers. Now the @!@**$^@%^! part!!! The damn bracket bolts wouldn't budge! Tried a ratchet, hit it with my hand, then a hammer, nothing! Borrowed a cordless impact wrench..... nope! Buddy brought over a compressor and air wrench..... nada!!
Tried a curved breaker bar..... with every ounce of strength I had, FINALLY got them to break loose. Now, I had to this x8 because EVERY !@(*$&@^#$%#@ bolt was tighter than...... well, lets just say they were LOCKED in there! With only 60k miles, I assume they've never been done before.Add to this, while removing the driver rear rotor, the e-brake stuck to the rotor and I somehow pulled the retainer clip that holds the pads to the hub.
Not having a clue how it was on..... I wasted nearly 1.5 hours trying to get THAT damn thing back in place. Just when I quit..... I got it back.
Now, time to prep the calipers and brackets for paint. I got the G2 kit so figured it would be quick and easy. Well, it was easy, but not quick. Cleaning and prep was effortless. Once everything was cleaned and dried, I mixed the paint and reactor and started painting. The little brush supplied doesn't cover a lot of area per stroke. Plus, I couldn't find a comfortable spot to sit, kneel, squat while holding the caliper and trying to paint it. Apply paint to caliper and bracket, move onto the next one. Repeat until I do all four corners. Now, apply second coat, to each corner. Repeat for a THIRD coat.
By this point, my back is killing me from trying to position myself to comfortably paint. It was a good 2 hours to paint all four calipers and all four brackets, three times each (and I didn't paint every surface, only those that can easily be seen). Once I was done, I hobbled around my house looking like a 137 year old. I still ache today and I still have to "sand" off the lettering on the front calipers and install the new rotors and pads, and put it all back together!
Now, I just watched the install video for the Vararam CAI, as I was thinking about buying one. Yeah....... not so sure I'll be doing that!
Oh, pics coming after I get it back together!
