2003 Corvette alignment
Old Feb 12, 2017 | 08:42 PM
BayVette's Avatar
BayVette
Default 2003 Corvette alignment
I've posted this previously, but now I need further help. I have an on-going issue with my car's alignment. Left sweeping turns are smooth with little resistance in the steering wheel. During right sweeping turns I feel a slight resistance pulling to the left. I've been to a local shop for an alignment and am still not satisfied (tech gave up).
I live in the East Bay (Alameda) near San Francisco. Can any local members recommend an alignment shop that specializes in Corvettes? I'm willing to travel a reasonable distance.
Thx!
Jerry
Old Feb 12, 2017 | 10:07 PM
6speedsteve's Avatar
6speedsteve
Can you post a photo of the alignment sheet? maybe there is an issue with the alignment they used.
Old Feb 13, 2017 | 09:55 AM
Vanover's Avatar
Vanover
Old Feb 13, 2017 | 01:02 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Have you checked for loose/damaged/worn/sloppy suspension parts?
Like:
Bad wheel bearings?
Bad upper/lower arm bushings?
What shocks are you running? Mileage??
My ZO6 started handling horrible on fast sweeping turns. It would try to leave the highway! Turned out to be weak C5 ZO6 Shocks.
Old Feb 13, 2017 | 02:59 PM
Bluefire's Avatar
Bluefire
Like:
Bad wheel bearings?
I realized that my Gen 1 Pfadt coilovers were worn out on a long sweeping right hand turn at WOT on track. The left rear c/o went into a collapsed/rebound cycle that almost threw me off of the track. Dumped them for Bilsteins & Z06 leafs.
Old Feb 13, 2017 | 07:16 PM
BayVette's Avatar
BayVette
The suspension was checked and it's OK. I appreciate the advice but at this point I need a Corvette specialist near me to address the issue.
Thx all!
Jerry
Old Feb 14, 2017 | 01:52 PM
Bluefire's Avatar
Bluefire
Possibly an intermittent connection on Magna steer connector (power steering rack).
Old Feb 15, 2017 | 04:34 PM
strand rider's Avatar
strand rider
My suggestion is to call a few quality body shops in your area. They sometimes have problems they ca't solve, and send the cars out to a higher skill level . With a few calls, one shop should come up more often. Call that shop and good luck.
IN my area there were two shops on top, almost equal . Then the worker at one shop started his own place and now he has the top spot alone. He only works on cars he digs,mostly race and high performance. Because of the age on my C5, he first checked the wear parts to make sure the work would hold, as he offer no do overs. HE had me sit in the car as he worked, as I usually ride solo, sigh. HE also asked about the usual load the car carries, then went to work with calipers, not electronics, although he uses both, at times. I told him the rear end walked a little bit changing lanes on uneven surfaces at around eighty five mph, so he toed in the rears a bit . I selected a tire wear friendly bias on the adjustment.
It is important to load the suspension for correct adjustments. One extreme example happened with a pick up truck that was wearing through tires very quickly. Turns out the truck was used to deliver newspapers, so the unloaded adjustments just scrubbed the front tries under work use.
To 2003 Corvette alignment
