c-5 HUD
Old Feb 16, 2017 | 08:32 AM
tazwayneiac's Avatar
tazwayneiac
Default c-5 HUD
hi all, I just picked up another vette...that makes 4...a 80..84..88..now a 04...
on the o4 the hUD is not working and in the car booklet on the fuse block it does not show a fuse for the hud...any suggestions as to what to do next?
thanks
Old Feb 16, 2017 | 09:57 AM
Phanni's Avatar
Phanni
It's likely the mirror has just fallen in the unit. That is the most common failure.
Not a particularly easy fix though.
Old Feb 16, 2017 | 10:42 AM
Are you sure you have the projector adjusted correctly to where it shows a display on the windshield? Try adjusting the buttons to the left of the gauge cluster - there will be one that says page and one that has two arrows for the up/down adjustment.
Old Feb 16, 2017 | 10:47 AM
tazwayneiac
I haven't tried to adjust it
I just know that it wont display so I was trying to find the fuse location
I know where the hud is on the dash..all switchs do nothing...thks for the reply
Old Feb 16, 2017 | 12:47 PM
tazwayneiac
I looked at my buddys c5 and the mirror looks like its where it should be. it has not fallen..i looked in the fuse boxes but nothing is marked for the HUD
Old Feb 16, 2017 | 12:52 PM
Phanni's Avatar
Phanni
Since your buddy has one, ask him to check yours out, it could be as simple as having the intensity turned down or off.
Old Feb 17, 2017 | 01:11 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
Recently there was a thread on the HUD:
https://www.corvetteforum.com/forums...eshooting.html
Old Feb 17, 2017 | 02:04 AM
Rob 02's Avatar
Rob 02
I have a similar issue but I can hear the up-down motor running. My A4 shifter light isn't getting power either. I'm assuming it is something on the back of the instrument cluster.
Old Feb 17, 2017 | 02:50 PM
unlvrebel's Avatar
unlvrebel
Dimmer?
Old Feb 17, 2017 | 07:35 PM
Rob 02's Avatar
Rob 02
Would the dimmer effect only those two components?
If so it seems logical.
To c-5 HUD
