Quickjack
Old Mar 28, 2018 | 11:38 AM
  #81
Quickshift_C5's Avatar
Quickshift_C5
The only issue I have with this is that it doesnt seem to lift high enough to pull out the drivetrain. I can't imagine working under the car to get everything loose and removed to pull the transaxle out the back. I had to raise my car up 24" to get the clearance needed.
Old Nov 4, 2018 | 12:40 PM
  #82
CMach5's Avatar
CMach5
Originally Posted by Fast one
The top of the handle is 34" from the ground including the 2" caster wheels, the vertical bar is 1" x 1/2" aluminum tubing.
Thanks for posting! I'm going to copy this setup. Anything you'd suggest modifying?
Just ordered from costco for $1190 (includes tax & delivery).
Old Nov 5, 2018 | 11:26 AM
  #83
Fast one's Avatar
Fast one
I would add a basket for the spacers like K9Leader did.
Old Nov 5, 2018 | 11:59 AM
  #84
JHrinsin's Avatar
JHrinsin
I really like the cart that C6Z06Silverbullet uses with his;
https://www.corvetteforum.com/forums...post1598193263
Old Jul 26, 2020 | 12:07 AM
  #85
JOHN RICCIARDI's Avatar
JOHN RICCIARDI
the quick jack lifts the entire car at one time as high as approximately 2 feet; it is not suppose to used to lift one side at a time according to the manufactures guidelines. I have a quick jack 7000 lbs which i used with my vette several times and i'm very happy with this product.
