Quick Jack
Old Apr 7, 2017 | 11:20 AM
Fast one's Avatar
Fast one
I milled 0.6" off the short rubber pads leaving them 1.5" thick as seen in the photo. Now the jack and pads fit under the car with some clearance and there is enough rubber so the car frame doesn't touch the steel jack frame.
Old Apr 7, 2017 | 02:15 PM
Slick61's Avatar
Slick61
...really like the quick jacks... wouldn't mind having one... tho I went for the simpler, cheaper alternative... picked up a used kwik lift off of CL for $500. Does what I need it to do. Probably could've picked up a used lift in the same price range, but I liked the simplicity of the kwik lift. The "wheels-off-the-ground" capability of the quick jack is nice... and I can do it on my kwik lift as well, tho it's a bit more work. But for detailing & oil changes, the kwik lift fit my budget best... and little-to-no maintenance.
Old Apr 7, 2017 | 02:38 PM
Efx's Avatar
Efx
Not a bad idea. Will look into that!
Old Apr 7, 2017 | 03:26 PM
Sasso1's Avatar
Sasso1
Originally Posted by laurent_zo6
There are several Quick Jacks so make sure discount will work if you order different models.
The one I would be interested in is the BL-5000. For the small price difference, I think it's worth having the extra possible weight capacity...
Old Apr 7, 2017 | 03:55 PM
Fast one's Avatar
Fast one
I e-mailed Quickjact and asked them what the minimum clearance is to lift the car and they said that for a light car around 3500 pounds there doesn't need to be any clearance, it's only for heavier vehicles.
Old Apr 7, 2017 | 05:38 PM
MongoZ06's Avatar
MongoZ06
I've seen Group Buys happen occasionally with the Quick Jack on this forum, might we have enough interest to drum up another one?
I certainly would be interested in getting one.
Old Apr 20, 2017 | 06:11 PM
Sasso1's Avatar
Sasso1
Do we need to contact them directly to inquire? Would a forum distributor consider the group buy?
Old Apr 25, 2017 | 08:47 PM
Shifter6's Avatar
Shifter6
Originally Posted by onehundred
My Quickjack arrived last weekend. I bought the 3500 it was simple to set up and works great. It is a lot more stout than it looks. It was on sale plus I got another $100 off from a promotional code I saw on a tv commercial. It also stores under my c5 when I am not using it.
Hey, what was the promo code you used? With a discount, I will buy one!
Old Apr 26, 2017 | 09:46 PM
onehundred's Avatar
onehundred
Da-Fuzz
I don't remember it was on their television commercial on the Velocity channel. I didn't write it down.
Old Apr 26, 2017 | 10:34 PM
Waldo_2001's Avatar
Waldo_2001
In interested if a group buy happens.
Old Apr 27, 2017 | 07:38 AM
RayCE's Avatar
RayCE
Also interested in a group purchase. ..... If position in the middle of the garage can a stock C5 drive over them without hitting anything under the car. ?? Just wondering since I do not have a large garage.
Old Apr 27, 2017 | 11:11 AM
photonhunter's Avatar
photonhunter
Active Streak: 90 Days
If you leave your jacks on the floor and park by driving over them, what happens when your 'Vette comes in from the rain? There's a good chance the lifts will be sitting in puddles.
The lifts themselves fold up quite flat and they have wheels to easily move them around. Even if you have a small garage they don't take up much space against a wall:
dan k.
Old Apr 27, 2017 | 06:30 PM
  #33
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
I texted company.
Told him Forum members live all over the US so not feasible. He said a coupon code just ended March 31st.
Maybe someone has better luck with getting a discount.
Old Feb 5, 2018 | 03:54 PM
  #34
Sasso1's Avatar
Sasso1
Couple new questions:
1) Is there any reason to look at the BL-5000EXT? I also have a Lexus IS250 as my daily driver and haven't looked at the minimal and max jack points distances, but can't the BL-5000SLX work?
2) My vette is lowered ~ 1.5 inches on stock bolts and cut bushings overall. Will the BL-7000SLX sit too low and I would have to drive onto 2 X 10 plywood to get enough clearance??
Sorry I tried searching the forum and also Google but I'm going to buy one soon and needed advice.
Old Feb 5, 2018 | 04:14 PM
  #35
laurent_zo6
Did you see this on the QuickJack website?:
https://www.quickjack.com/quickjack-...ing-guide.html
Old Feb 9, 2018 | 01:16 AM
  #36
svo's Avatar
svo
Do these lift high enough to remove stock exhaust?
Old Feb 9, 2018 | 08:09 AM
  #37
Efx's Avatar
Efx
Midsection, yes. But if you want to keep your axleback in one piece, no.
But you can always improvise
To Quick Jack
Old Feb 9, 2018 | 10:40 AM
  #38
mre1974's Avatar
mre1974
These look like they would be great for oil changes and basic maintenance. Do you get enough height/clearance to drop the rear cradle and do a clutch job and torque tube service or would I need more 'lift' to do so?
Old Feb 9, 2018 | 01:09 PM
  #39
Efx's Avatar
Efx
Whatever job you can do on jackstands, you can do with quickjack.
Old Feb 12, 2018 | 07:24 PM
  #40
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Anyone know anything about the mugs safety record for these?
