I'm I right?
What I said(if you read my post) was, I think it is "stupid", and "silly" to pay for higher priced products, if one can get the same results with a less expensive product.
It might be a great idea if you remember to make sure the brain is in gear before putting the mouth in motion.
Bob.
If you want to spend whatever money you have foolishly, that is your business.
My only intention was to give a heads up to those who may not be aware a less expensive products works every bit as well as a more expensive one, therefore saving someone some money.
As I said earlier, just because something is higher priced, does not mean it is any better than a less expensive product.
Bob.
At the risk of repeating myself, as I told "blue" above, I don't intend to get into a pissin match with you, or any one else.
I know what works when it comes to detailing, and that is all anyone needs to know.
If you too, want to spend your money on a particular product, that is your business, but I'M telling you that isn't necessary, when you can achieve the same results with a less expensive product.
So with that, do what you want.
Bob.
That could mean 20 years or so.
I have been detailing my vehicles before you were a gleam in your daddy'e eye, and pretty sure, while you were still sh!tt!n your diapers.
I think I am a pretty good judge of the properties of turtle wax.
Again, I NEVER use any kind of soap to clean my vehicles.
The coat of wax last as long as any product you may be using.
After 6 months, the water still just slides off the finish, because the surface is still slick from the wax.
That is the sign of a good wax product.
If after washing, your vehicle "beads", what that tells me is, there is not enough wax on the finish to allow the water to slide of the body.
A good example of that is the couple of pictures above.
The hood of that car is completely covered with water beads.
That is an indication that the finish is holding the water , rather than allowing it to slide off the finish.
Kinda like the old dish washer commercials where without using "cascade", the glasses were spotted, and using it, they came out spotless.
Whatever was in cascade, allowed the water to slide off the glass, instead of just sitting there.
Same principal here with auto products.
If the wax is applied properly, water will not bead, it will slide off the finish.
Problem with water beading is, rain also beads, and ugly water spots are all that remain, and they are an absolute bitch to remove.
There isn't much you can tell me about vehicle detailing, that I don't already know, or have experienced.
Stay with your zaino, chadwicks, 809, or 908, or whatever.
Through experience, I know what works, and will continue to use what it is I use, and along the way, save some bucks.
Bob.
https://youtu.be/cjXGvrlVNP8
It does the same on my vehicles, so does that make your more expensive product any better than what I use?
I think not.
Bob.
Sure, turtle wax works. It takes me much longer to use it though and since my car sits in UV rays 365 days a year, I wanted something that I could apply to upward facing surfaces in 10-15 minutes. Turtle wax simply isn't better than any other cheap wax, and definitely not better than the expensive waxes.
Find me a single pro who uses turtle wax and we'll talk. Until then don't forget to pick up some more supertech oil while you're in Walmart getting your turtle wax.
Bob.
aka Evil Twin suggest I try it. It has looked great with many, many
Concourse and Show trophy's . I still race but sometimes I am
accused of bring a show car to the track! That's before I start to
turn a wheel.
Thanks Bill for the advice. You have to try them all before you settle
on something you like.
PS... do you have any suggestions on alternative methods for gas? Premium is far too expensive and I'm sure there's something else that will give just as good results without paying that crazy high price.
Bob.
Go back and look at them.
You will see that I sir, know a great deal about detailing products, and how to use them correctly.
The only vehicle I have seen on this forum, that appears to have a clear finish close, if not better than mine is the Vette owned by Eviltwin.
That sir is pure dedication plain and simple.
I have yet to see one vehicle on this forum that had Zaino, or Chadwicks applied that has anything close to the mirror like finish on both my vehicles, especially my pickup.
I believe I am old enough, to state with some clarity, I've forgotten more than you, or most people will ever know about detailing vehicles.
I didn't just jump off the turnip truck.
I would venture a guess I have been detailing vehicles, long before you were born.
Bob.
Bob.
Before:
First time with paint correction:
This morning after a quick spray and wipe:
Do as you wish, because I am! I know what my results are and I know how much time I had to invest to get this result. My time is important to me and I don't have as much as I'd like to spend doing what I want to do. If I can use something that costs a little more but saves me time to spend doing other things (with my family), then I'm all for it. My way is no better than any other way. It works for me, gives me the results I want and doesn't consume too much time.
