[Z06] Valve spring replacement
Old Dec 2, 2017 | 08:10 PM
MBVette's Avatar
MBVette
St. Jude Donor '05-'06-'07-'08-'09-'10
Default Valve spring replacement
i just bought all the stuff to do the valve spring job this winter. Anything I should be doing while I’m in there. Not really looking to make it a huge job just if there is something easy to do while it’s apart.
Old Dec 2, 2017 | 08:21 PM
grantv's Avatar
grantv
Seals, yes.
Cam?
Old Dec 2, 2017 | 08:24 PM
MBVette's Avatar
MBVette
I think that just gets into to big is job for me to handle. I’m what I call a YouTube mechanic. I can watch and usually feel comfortable doing things. But cam job is just to much for me
Old Dec 2, 2017 | 08:50 PM
Brian Roberts's Avatar
Brian Roberts
Where did you buy your springs from? I need to do it too.
Do you need a special tool to compress the springs for install? Or is it just a screwdriver and some rags?
Old Dec 2, 2017 | 09:08 PM
Spaceme1117's Avatar
Spaceme1117
Definitely change out the valve seals. Very easy and good insurance. While you are in there...
Old Dec 2, 2017 | 09:31 PM
MBVette's Avatar
MBVette
Yeah I picked those up as well. Seems crazy not to do them while you are there.
Old Dec 2, 2017 | 09:57 PM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
I had the spark plug wires and spark plugs changed also in addition to valve springs, valve seals and valve covers. The reason is that many have had some plug wires break due to age.
Old Dec 3, 2017 | 08:48 AM
MBVette's Avatar
MBVette
I actually did plugs and wires this summer, so Im hoping that I can get the wires off pretty easily
Old Dec 4, 2017 | 08:44 AM
Nokones's Avatar
Nokones
Along with the valve springs I replaced all the cooling system hoses, coolant, and the belt since everything is essentially 15 years old. At that time I discovered the motor mounts needed to be replaced so those were done. Now, the car almost new again.
Old Dec 4, 2017 | 10:39 AM
ArmchairArchitect's Avatar
ArmchairArchitect
Banned Scam/Spammer
From: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
Agreed, but those are not related to the valve spring replacement (ie. "while you are in there" tasks).
Old Dec 4, 2017 | 02:20 PM
glbeauchamp's Avatar
glbeauchamp
I'm trying to picture compressing the springs with a screwdriver and the picture is not good. try this instead:
http://www.jegs.com/webapp/wcs/store...rsistYmm=false. It isn't really that bad of a job. I did it last spring and it was easier than I expected.
Old Dec 4, 2017 | 03:17 PM
MY03C5Z's Avatar
MY03C5Z
Lol, it takes more than a screwdriver. I used an LSx valve spring tool like this one, it makes the job a whole lot easier
Old Dec 4, 2017 | 10:23 PM
StingrayRebel's Avatar
StingrayRebel
I would upgrade the trunnions since the rockers have to come off anyway, straub makes a nice bushing kit... I would stay away from comp or any of the needle bearing kits, they are widely known to prematurely wear the trunnions
Old Dec 5, 2017 | 10:23 AM
PeppyheadVette's Avatar
PeppyheadVette
This might be a dumb question but how will you know if you need your springs replaced? I bought my car with 64,000km (39,000m) and it runs great, etc so I have no idea if it was already done. I didn't get any information with the car or records, but I did obviously get a PPI from the local Corvette shop here in calgary.
thanks.
Old Dec 5, 2017 | 10:44 AM
killian96ss's Avatar
killian96ss
If the springs are original (yellow) replace them. There is no actual mileage they should be replaced at. The problem is the material used to make the springs. There was some contamination that made it into the spring wires during manufacturing and that causes them to break without warning. This can happen any any mileage and even while just idling. If you don't want to pull up a valve cover you can remove the oil fill tube on the passenger side, shine some light in there and see what color the springs are. If they're yellow replace them. If they're blue your good. The problem only applies to 02-03 LS6 Z06. I'm pretty sure the 01 had different springs because of the smaller cam and the 04 got the new upgraded blue springs.
Steve
Old Dec 5, 2017 | 10:52 AM
Spaceme1117
Agree. If you were to upgrade the trunnions definitely go with the Straub kit and stay away from the Comp Cams or similar kits.
Old Dec 5, 2017 | 03:54 PM
MBVette's Avatar
MBVette
ok just watched a video on trunions since I had no idea what they were. Seems straight forward but I dont have a press, so I am probably going to have to skip it.
To Valve spring replacement
Old Dec 5, 2017 | 05:58 PM
Nokones's Avatar
Nokones
Yes, I know that but, since the car is essentially 15 years old and most likely the cooling system hoses/coolant are of the same age and dince he has his head under thr hood, I think this is a perfect opportunity to change the 15 year old hoses.
Old Dec 5, 2017 | 06:02 PM
tmd442's Avatar
tmd442
Default Replaced mine today
Just replaced my valve springs today on my 03 z06 as well as the seals, spark plugs and wires. The car has 31000 miles.
The old springs were not yellow in color sort of gray in color.
I've only had the car for a month and I wanted to start off fresh and have peace of mind.
Next up is the LMC5 then the Elite Eng oil catch can.
Old Dec 5, 2017 | 06:04 PM
MY03C5Z's Avatar
MY03C5Z
Original springs in mine were bare metal with an orange stripe.
