my first corvette, my first "build" thread
Old Jul 2, 2020 | 03:41 PM
  #641
2k2wranglerx's Avatar
2k2wranglerx
C5 of Year Finalist (performance mods) 2019
Hmmmmm. I'm thinking I'm not going to overthink it. I'll check the cylinder walls with the cam and look it over really well. Then dump it in the car lol.
It came out running. Should be good to go back in. The less I touch with my lack of experience in this area the better lol.
Old Jul 2, 2020 | 07:10 PM
  #642
dskinsler83's Avatar
dskinsler83
Originally Posted by Kingtal0n
okay, Spin the motor using the starter with the plugs out so it doesnt make compression. Use a battery on a charger so you dont kill a battery or the starter. Low voltage will create high current condition in the starter and heat it up, killing it,. So... good voltage, good battery, good starter.
Mount the engine somewhere so it doesnt fall or roll or tumble or whatever. use a chains if you have to.
Take the plugs out, do a compression test with oil in the engine.
Then spin it and check the mechanical oil pressure from the upper rear valley port to verify the 38~ psi I believe should be there minimum.
Finally... NEVER take the engine apart. Do NOT open a good OEM engine. If the engine is OEM inside. You will not want to disturb those bearings or crush. They are probably mint if the engine was never tuned wrong or abused. Better not to find out. This is why you do the compression and oil tests... and a leakdown if you can to find leaky valves or broken rings or something else.
so
leakdown
compression
oil pressure
do NOT dissemble
Replace as many gaskets as you can (rear main front main valve cover etc... ) while its out
that is it
um....it isnt OEM dude
And also thus why I said a Professional lol
Old Jul 2, 2020 | 07:13 PM
  #643
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
If it ran when it came out, personally I would replace the rear main seal, the crank seal, oil pan upper gasket, valve cover gasket and bolt grommets (only if they look like they're leaking - easy enough to do later), and ship it. I wouldn't be opening anything.
You'll be on the road having fun in no time.
Old Jul 2, 2020 | 07:26 PM
  #644
dskinsler83
BUT he didnt see it nor hear it run. It has apparently set some time. Im just playing devil’s advocate here. I went through almost the same stuff he did, bought a new short block then decided to have it fully assembled by professional to long block to hopefully be sure of the out come. Still has some bugs to work out.
Old Jul 6, 2020 | 01:30 PM
  #645
2k2wranglerx
I'm not pulling the motor apart lol. it's going in, getting primed, and we're sending it.
Old Jul 29, 2020 | 09:13 AM
  #646
2k2wranglerx
So my buddy came over about a week ago and helped me pull the old motor.
number 8 decided to head on out lol.
I'm waiting on a couple gaskets/seals and then i'll swap the harmonic balancers and dump the new ls6 in. Then its time to assemble!
i've been slammed with work and family stuff and it's been a million degrees out so progress has been slow.
Old Jul 29, 2020 | 04:41 PM
  #647
tabbruzz's Avatar
tabbruzz
Originally Posted by 2k2wranglerx
Nothing new. i have the new motor ready to go in, and i have the accessories off the old motor and it's ready to come out. next week for sure this is going down lol.
We had to put our dog down on monday and my wife's been an absolute wreck. he helped her through 2 tough post pardums and through some depression with the girls' diagnosis. so i haven't been able to get down to the garage much.
However, parts are arriving lol
Proform valve covers
Coil relocation mounts
FAST 92
LS2 throttle body and wiring adapter
FAST fuel rails
Should at least look the part once it's in haha.
Sorry to hear about your dog and other personal issues.....The car is certainly not priority one.....Good luck with the new engine and install...
Old Jul 29, 2020 | 04:42 PM
  #648
tabbruzz's Avatar
tabbruzz
FAST 92
FAST fuel rails
Sorry to heat about your dog and other personal issues.....The car is certainly not priority one.....Good luck with the new engine and install...
Old Jul 29, 2020 | 08:31 PM
  #649
2k2wranglerx
alright pulled the harmonic balancers and front covers since I'm swapping over my summit balancer. And I'm going to replace the seals.
the new ls6 has a nice timing set and a cam that I think is
238/244 .613 .598 113 lsa
Thats my best guess from the engraving.
Old Jul 30, 2020 | 04:23 PM
  #650
2k2wranglerx
I grabbed one of the BTR chain dampeners too. a guy had one for sale for 30 bucks so why not. I know they're not much more new but it was basically new.
Old Aug 12, 2020 | 08:25 AM
  #651
2k2wranglerx
Alright, so it's ready to go back in. Progress has been super slow because i haven't had weekends to put it in. I've been taking the kiddo's to my parents place on Conneaut Lake. They've been going crazy not doing normal kid stuff.
But clutch is installed, i put a new pilot bearing and new monster modified flywheel bolts. Pulling the old ones out one stripped. that was a pain. I ended up starting to drill it out and then had an epiphany. pounded a spare torx socket into the hole and was able to pull it out (old jeep trick)
Old Aug 12, 2020 | 08:27 AM
  #652
2k2wranglerx
also here's some more LS1 carnage
Old Aug 12, 2020 | 10:43 AM
  #653
dskinsler83
Holy cow that is crazy!
Old Aug 12, 2020 | 11:40 AM
  #654
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
That's just an incredible amount of damage! Glad you have the new motor ready to go. Good luck with everything going forward.
Old Aug 12, 2020 | 01:12 PM
  #655
Toys4Life C5's Avatar
Toys4Life C5
St. Jude Donor '21
Using the actual input shaft like you did to align the clutch will save a TON of frustration.
As close as those plastic alignment tools are, they SUCK....
Old Aug 12, 2020 | 01:32 PM
  #656
MetalMan2's Avatar
MetalMan2
+1... was rebuilding my torque tube anyways, and postponed fully putting it back together until the clutch went in. It's still a good choice to make sure the input shaft has "jiggle room" before starting to tighten the PP bolts.
Old Aug 13, 2020 | 12:36 PM
  #657
2k2wranglerx
So i did the initial PP bolt torque (like 20 ft/lb) then slide the input shaft in and out a couple times. then again at the end made sure it slides in/out easily. Hopefully it goes back in easy too lol. we'll see... fingers are crossed haha.
The question is... Do i put the motor in and bolt to the bellhousing... or do i put the bellhousing on the motor and bolt to the TT... we'll see... hopefully it'll be in this weekend.
To my first corvette, my first "build" thread
Old Aug 13, 2020 | 12:39 PM
  #658
2k2wranglerx
also i've found screaming and shaking the motor violently helps when you can't get it to go together.
Old Aug 13, 2020 | 02:27 PM
  #659
dskinsler83
Id add the bell housing to the engine before sititing it back in. Then bolt the TT to the bell housing
Old Aug 13, 2020 | 04:30 PM
  #660
MetalMan2's Avatar
MetalMan2
Agreed.
I had some challenges getting the TT clamped back to the bellhousing due to the difficulty in compressing the slave cylinder. There's so much anxiety with using the bolts to draw it in...
