my first corvette, my first "build" thread
Old Jun 25, 2020 | 09:50 PM
  #621
2k2wranglerx's Avatar
2k2wranglerx
C5 of Year Finalist (performance mods) 2019
Originally Posted by CinciZ06
I purchased a used LS2 TB from a forum member here that claims he is "in the aftermarket industry" and had a source for LS TB take-offs. Turns out it is a junk throttle body and I got fleeced for $225. I purchased one of the re-manufactured LS2 TB's from O'reilly for $295 after a discount code and now I am logging correct TPS sensor percentages thankfully and the tuner can finish getting the idle correct on my car. Just wanted to throw it out there in case it is an easier option for you.
https://www.oreillyauto.com/detail/b...673003/2456017
I would totally do that if they had them in stock lol
Old Jun 25, 2020 | 10:16 PM
  #622
CinciZ06's Avatar
CinciZ06
DAMN - that sucks! I bought mine last Friday - soooooo, maybe my fault? Sorry not sorry? lol. That summit option DSKinsler threw up may work also.
Old Jun 25, 2020 | 10:36 PM
  #623
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
Cinci, can you PM me who that was?
Old Jun 26, 2020 | 12:06 AM
  #624
dskinsler83's Avatar
dskinsler83
That freaking sucks! Are there options to have the messed up one rebuilt?
Old Jun 26, 2020 | 07:14 AM
  #625
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Is there a shortage or something with the LS2 TBs? Why are they suddenly skyrocketing in price?
Old Jun 26, 2020 | 08:28 AM
  #626
2k2wranglerx
yeah since they stopped making them.
Old Jun 26, 2020 | 08:40 AM
  #627
Stingroo's Avatar
Stingroo
Ahhh didn't realize that. Figured they'd still make them under GM Performance Parts or something. Interesting.
Old Jun 26, 2020 | 08:42 AM
  #628
CinciZ06's Avatar
CinciZ06
Fo' Sho'
RockAuto has a rebuild service for them if you search under a 2005 / 2006 Corvette 6.0l, but it's $295! It's the same price as I bought the new one for, which seems crazy.
In the end it's my fault for buying a used part - that's the risk you take when it's what you choose. Every part I put back on the motor was new aside from Injectors, fuel rail (my original), and TB. Two of them I bought from other people, and had to have the injectors rebuilt and the TB is a paper weight. I know better, but both aren't made anymore and it seemed like the best combo. In the end I spent more than if I would have bought FIC injectors and a Nick Williams TB. Not sure how many times I have to learn this lesson in life.
Old Jun 26, 2020 | 02:26 PM
  #629
2k2wranglerx
I snagged a like new unit from AJG87!!!! He's sending that out tomorrow.
pretty pumped that worked out!
Old Jun 28, 2020 | 02:27 PM
  #630
dskinsler83
Hows it coming? Got any further on the original engine? I saw and responded to the instagram photo of piston pieces
Old Jun 28, 2020 | 03:26 PM
  #631
Kingtal0n's Avatar
Kingtal0n
Just a thought you might consider,
When I get a random engine and intent to put it into a car (done this 100+ times over the last 20 years)
Of course compression test it. Pull the heads etc.. as necessary and so forth. You don't need me to tell you that.
but here is something I have been given to doing that nobody ever mentions. Throw some oil in it with the plugs out, and spin it over, verify the oil pressure is good and solid from the back, this will give you the knowledge of whether the engine when it was run last had good oil pressure or not. SOmetimes the o-ring or pickup fails and the motor ran with no/low oil for some time and you would never figure that out because you would replace the pump and o-ring properly without every finding out there was a problem.
Then, once you see good oil pressure for a while, I would spin it in say 20 second intervals for as many revolutions as it takes to fully circulate the oil, send the oil for a $30 analysis right away.
oil pressure confirmation + oil analysis will show if there is some significant residual damage done by previous owners allowing you to potentially avoid making a mistake.
I only do this to expensive engines or engines with extensive mods. A stock engine from say a truck with 150k doesn't need such treatment. But throw a bunch of aftermarket parts in one and you have a huge question mark "how clean was the installation" and ":how much wear and tear occured due to XYZ" and so forth. Can be quickly confirmed using analysis and spot checking as opposed to installing it and finding out it has a knock or something dumb.
Old Jul 2, 2020 | 07:31 AM
  #632
2k2wranglerx
Nothing new. i have the new motor ready to go in, and i have the accessories off the old motor and it's ready to come out. next week for sure this is going down lol.
We had to put our dog down on monday and my wife's been an absolute wreck. he helped her through 2 tough post pardums and through some depression with the girls' diagnosis. so i haven't been able to get down to the garage much.
However, parts are arriving lol
Proform valve covers
Coil relocation mounts
FAST 92
LS2 throttle body and wiring adapter
FAST fuel rails
Should at least look the part once it's in haha.
  #633
2k2wranglerx
are you just using the starter and a battery to spin the motor?
Old Jul 2, 2020 | 11:32 AM
  #634
jrob56's Avatar
jrob56
I would think just pull the fuse for fuel pump and key it. Good way to prime it too before first fire. Never done it with plugs out, but did to move oil everywhere after we swapped a good LS1 into a Camaro that popped its original.
Old Jul 2, 2020 | 11:49 AM
  #635
CinciZ06's Avatar
CinciZ06
With the motor not in the car, I would be very very tempted to disassemble, hone the cylinders and deck the block, I nstall new bearings / rings / gaskets, and reassemble. Then you have a new motor and know exactly what’s inside.
Old Jul 2, 2020 | 12:26 PM
  #636
2k2wranglerx
the motor's out of the car. that's why i was asking. he was saying do this before i put it in.
Install new bearings / rings / gaskets, and reassemble. Then you have a new motor and now exactly what’s insider.
I'm tempted... but i also am tempted to toss it in and send it. it's an evening's worth of work with a buddy to get this in. If it has an issue it's 408 bottom end time with these trick flow heads lol.
Old Jul 2, 2020 | 01:39 PM
  #637
dskinsler83
The more I think about it, Im with Cinci. Id have it taken apart professionally inspected, new bearings through out, honed and decked, then put back together to a full long block ready to go and then drop it in. While you do have a nice set of heads on your hands, I would think they being built and designed for a LS1/6, they would not be that great for the 408. With the money you spent on the new engine and having it professionally inspected and overhauled...you are still less into it than a 408 short block....and it leaves you with a basically new freah engine right there. With the time and money spent on the rest of the car, and all the other stuff, its just a nice peace of mind type thing.
To my first corvette, my first "build" thread
Old Jul 2, 2020 | 01:51 PM
  #638
CinciZ06's Avatar
CinciZ06
And whatever ya do, don’t spin that motor over with the starter, even if it’s on a stand. Short of being on a dyno cradle you will run the chance of it toppling over. Many years ago my old man and I built motors to fund our drag racing / c3 restoration habits and built a fair number of circle track setups. Well safe to say dirt track racers aren’t the sharpest cats out there, and we watched a guy dump his $15k motor that was on a stand on its side in his garage because he wanted to check the compression with the starter while arguing with us about over-revving it to 9000 rpm.
Old Jul 2, 2020 | 02:22 PM
  #639
Kingtal0n's Avatar
Kingtal0n
okay, Spin the motor using the starter with the plugs out so it doesnt make compression. Use a battery on a charger so you dont kill a battery or the starter. Low voltage will create high current condition in the starter and heat it up, killing it,. So... good voltage, good battery, good starter.
Mount the engine somewhere so it doesnt fall or roll or tumble or whatever. use a chains if you have to.
Take the plugs out, do a compression test with oil in the engine.
Then spin it and check the mechanical oil pressure from the upper rear valley port to verify the 38~ psi I believe should be there minimum.
Finally... NEVER take the engine apart. Do NOT open a good OEM engine. If the engine is OEM inside. You will not want to disturb those bearings or crush. They are probably mint if the engine was never tuned wrong or abused. Better not to find out. This is why you do the compression and oil tests... and a leakdown if you can to find leaky valves or broken rings or something else.
so
leakdown
compression
oil pressure
do NOT dissemble
Replace as many gaskets as you can (rear main front main valve cover etc... ) while its out
that is it
Old Jul 2, 2020 | 02:35 PM
  #640
jrob56's Avatar
jrob56
I would not open a factory engine, put it in, prime it with oil, and fire it up. Like you said, the labor to get it in and out on your own is minimal.
