VetteNuts DD Bezel Install/Review Thread
The only comfort would be that I'm sure this one is going to look even more perfect than the first one when you're done with it I just wanted to point out that wiring a Double Din or Single Din, Pioneer or Kenwood to the Axxess XSVI-2004 is exactly the same because both, Pioneer and Kenwood, adhere to the E.I.A. Standard Wiring Color Code and the extra wires that may be present in a Double Din vs a Single Din installation (backup camera, GPS) are not connected to the Axxess interface at all.
Regarding the following 2 wires in the Kenwood harness:
- Blue (Antenna Power)
- Orange/White (Dimmer Control)
If your Kenwood has a Blue/White (Amp Trigger), splice the Blue/White from Kenwood to Blue/White from Axxess and tape the end of the Blue wire from Kenwood and leave it unused.
Splice Orange/White from Kenwood to Orange/White from Axxess.
I hope that someone can throw some tips regarding the physical installation of the Kenwood headunit. I'm sure you're going to have perfect results!
Thanks for this info! Nice to know that the wire colors should match up again.
"I'm sure you're going to have perfect results!"
I hope your right ;^)
I am not new to car stereo installs. Have done quite a few over the years.
I once worked for a local Car Stereo dealer and install shop way back in the late 60s.......
The hot items back then were 8 track decks. There was no such thing as a ready-made install kit for different cars.
But I did learn that if someone else in the shop had already done a particular type of car their knowledge could save me lots of time and headaches. So I always seek out info before I begin.
The DD install in a C5 is a different animal as the DD decks may all look the same size but seem to have very different front face sizes.
The Kenwood I have on order uses a powered tilting face to access the DVD/CD slot and SD card slot. This will likely mean many trial installs to get just the right height and depth of the Kenwood mount in the Vette's center cage.
Will find out late next week when the Kenwood arrives.
The set that VNutts sells look identical except they are all plastic and mine broke in several places when I tried them. VN did refund the cost.
So I decided to make my own out of strong tie galvanized plates. $3.00 for a pair and wide enough to allow multiple mounting points on the side of the head unit. Took awhile to get them right but the head unit is very stable once mounted and didn't want it to sag in the back end as the thinner/narrower L brackets did. They are not pretty, but they are very strong and rock solid.
I think they're way too expensive as well. I just brought them up in case somebody was looking for something like that.The Best of Corvette for Corvette Enthusiasts
You can clearly see they broke the middle section between the double din and the hvac, they called it cheap and said they use Metra. I told them this kit is worth double of a damn Metra.
Any suggestions on how to get this to mount more flush with the kit? Right now I am so sad, needless to say I am disputing the charge on my credit card since my initial quote was $250 and they charged $450 plus the fact that the work was shoddy and they broke the kit.
Just one problem remains..........my Kenwood stays on regardless of where the ignition is positioned even with no key inserted. I triple checked the wiring and I have the Red lead from the Axxess harness hooked up to the Red lead on the Kenwood. It does not seem to be the RAP as the Kenwood stays on with the doors closed no matter how long until I power it off using the switch on the Kenwood.
Any ideas or help will be appreciated as I would like to get my dash back together.
Thanks in advance,
Jim
Axxess wiring instructions:
Kenwood wiring harness:
Thanks in advance,
Jim
Also, with mine I noticed the instructions I got with my XSVI unit were for a different unit (picture was different was the first hint). This was problematic when it came time to adjust the POTs. After several searches I found the instructions on the manufacturer's website, but it took some digging. After that the adjustment process was pretty straight forward.
Thanks for the info. I "thought" I did the initiation correctly
But I could easily be wrong.
I did not think to try the initiation again.I will give it another try tomorrow using the pull fuse method first as I really don't want to pull the bezel and console again as I got it all buttoned up today.
Thanks,
Jim
I hope your CC company backs you.
I would have contacted the manager and/or owner about how you were treated.
Any shop that delivered that work and charged you almost double should be out of business. You might contact your local Better Business Bureau and file a complaint.
Thanks,
Jim
I tried the pull the radio fuse #5 three times extending the time off each time.
Removed the negative battery cable then removed the console & bezel & Kenwood from the dash and disconnected the Kenwood wiring plug. Left the negative off for 60min. Followed the initiation process each time.
In all cases, the Kenwood remains on after the key is pulled and the door opened every try. And will remain on until turned off at the Kenwood.
Not sure what to try next. I will try contacting Axxess tomorrow.
Thanks to all,
Jim
Update:
I had multiple emails with Metra support. The same tech always answered my emails promptly and I really appreciated that.
But he was sure the issues were with the head unit, not the Axxess unit.
But when I replaced the Axxess unit I was asking about today with a new Axxess unit all the problems disappeared..........
Thanks,
Marc
