VetteNuts DD Bezel Install/Review Thread
I'm really curious how others might have sanded the sides, while keeping is straights and squared in the corners like original.
I just wrapped some 320 grit around a screwdriver and sanded in there. Fits well now, but after seeing how easily it snapped I do wonder how the plastic mounts will hold up, esp if fastened too tightly.
When it came to actually sanding, I used a metal file which allowed me to keep the sanding straight and not curvy, but I still ended up coming down not perfectly at a right angle and I am just a little bit disappointed about that. In the end it still looks pretty good I guess. Would have been nice to avoid this sanding altogether.
Also there is a picture earlier in this thread of a lip hanging down from the dash plastic that you can trim. I went to freaking Town sanding on that thing until there was basically nothing left of it and now my head unit actually goes far enough up to completely fill the top of the bezel opening without needing weatherstripping like the other guys have done. As a consequence however, the bezel no longer fits perfectly flush up there because the head unit presses on the tabs too much to allow them to get all the way in. I'm also afraid that I might have sanded a little bit on the area where the bezel tabs actually hook in, which I was trying to avoid and you really have to make sure you don't sand or trim that part.
It's a trade-off, I think the not-flushness looks better than having a head unit hanging down inside the opening with a bent divider between it and the HVac. Who knows, maybe I'll come back and change it later.
In the in the end, I think I still prefer the vet nuts bezel over the Metra, because I would rather have a couple janky edges than a purply surface that looks completely out of place in the car.
I think the only way to get the head unit to fit as well as I had originally imagined it would, would be to design a bezel where the HVAC actually gets dropped down a little bit, which would mean removing the support brackets for the HVAC and the double DIN inside the subframe. That's a lot of custom Fab work for the bezel sellers to expect of their customers though.
Sorry, just saw your post. I didn’t need to file or trim the sides at all. I did file the bottom corners just a bit to get rid of the bowing on the piece between HU and AC control but that was it. The head unit is a Sony XAV-AX100.
...Also there is a picture earlier in this thread of a lip hanging down from the dash plastic that you can trim. I went to freaking Town sanding on that thing until there was basically nothing left of it and now my head unit actually goes far enough up to completely fill the top of the bezel opening without needing weatherstripping like the other guys have done. As a consequence however, the bezel no longer fits perfectly flush up there because the head unit presses on the tabs too much to allow them to get all the way in. I'm also afraid that I might have sanded a little bit on the area where the bezel tabs actually hook in, which I was trying to avoid and you really have to make sure you don't sand or trim that part.
It's a trade-off, I think the not-flushness looks better than having a head unit hanging down inside the opening with a bent divider between it and the HVac. Who knows, maybe I'll come back and change it later...
Could you please post some pictures illustrating your descriptions? It will really be helpful. Thanks!
However, I will say this: below is an image of the upper lip I'm talking about sanding.
My concern about sanding that lip is that it's also where the bezel's top 2 tabs click in. However, my concern when I said the following turned out to be wasted concern:
One final major tip I have, and this is what really saved my project: use shims between the HVAC and head unit! I'm using the 3D printed plastic brackets and they don't seem capable of holding the head unit up high. No matter how tightly I screwed in the vertical adjustment screws, it still dropped downward. However, I eventually made some shims out of carboard taped together, 2 cardboard layers thicks, and jammed them between the HVAC and head unit. It was the PERFECT height adjustment, and the cardboard shims are out of eye-sight entirely. This was a huge relief, and the final thing that changed my project from looking ghetto to "that might be OEM"
I'll save that for another weekend, I'm burned out hah
Might be worth a look/test
Or perhaps a pair of metal L brackets could be attached to the sides of the cage to keep the rear of your DD unit at the correct angle/height.
I didn't use the plastic brackets after they cracked on me. I made my own crude metal brackets from a pair of 5" x 1 3/4" Simson Strong Ties that I had several of.
Not pretty, but they will hold the DD at any angle I set them up for and use 3 or four screws per side. No wiggle or drooping of the DD once the proper locations are determined.
I have a Kenwood DNX893S on the way.
I would appreciate any tips you might share about your install.
If you have the time, could you save me some by answering these questions?
Did you have to modify the size of the Vettenuts bezel opening? If so, where?
Did you use the Kenwood metal cage to hold the unit?
If so, how did you mount it to the C5 center cage?
If you did not use the Kenwood cage for mounting, what brackets did you use?
I will be using a Axxess XSVI-2004 Harness Conversion Kit as I am keeping my Bose speakers for now.
So the following questions may not apply if you used a PAX adapter.
I see that the Kenwood wiring harness has a Blue Antenna power wire for the antenna amp. Which wire in the Axxess harness, or anywhere else, did you connect to this blue wire?
I also see an orange/white dimmer control wire. Which wire in Axxess harness, or anywhere else, did you connect to this orange/white wire?
Any other suggestions regarding this install you might share?
Thanks in advance,
Jim
So the following questions may not apply if you used a PAC adapter.
I also see an orange/white dimmer control wire. Which wire in Axxess harness, or anywhere else, did you connect to this orange/white wire?...
It even has a follow-up in Post 2 with a note regarding how to fine tune the adapter for better sound. Also, check Post 10 for extra clarification on some critical splices.
I have read that one several times.
But a DD install is very different from a single din as is a Pioneer case from a Kenwood.
I originally installed a Pioneer DD several weeks ago. Did all the wiring and many trial fits to get the correct height and depth of the unit to the bezel fit. But the Pioneer unit turned out to be defective. So I moved up to a different head unit with the Kenwood which looks like a different mounting system. So I thought that there may be another CF member that has already done a Kenwood DD with the Vettenuts bezel and might be able to save me some trouble shooting time ;^) Never hurts to ask......or so I hope.
