I have a set of the Chinese ACA headlights. I took them over to the Lightwerkz shop and had them look at them. Once I get the low beam receptacles removed from the assemblies, I will go back to their shop and purchase the parts I need to complete the conversion. It will be their adapters and a set of bi-xenon Morimotos. The final assembly should duplicate the best on the market at half the cost. I too can't justify the super expense of other products. I have too many things going on. I'm in the middle of a restoration and working on two vehicles at once is not easy. Lightwerkz is less than an hour's ride from my home.
I don't guess you tested the beam pattern before sending them off to get modded? I'd love to hear from someone who actually bought these with one of the HID kits to chime in. I will say, I'm willing to spend UP TO what JWM is asking for these things if it's truly a better product. I'm a little leery that they're just throwing a premium price on it to make people think it's better though.
I gave you a cost breakdown above. The generic Mini H1s are bi-xenon and are generally around Morimoto Mini H1 5.0 levels of performance (currently Morimoto is on 7.0). A bit more expensive option for projectors are the Supers from Lightwerkz or Acme from TRS, again around 5.0 performance but you get more of a guarantee than generics.
Well, it wouldn't be the first time I've hacked into headlight housings a bit. I'll consider the option.
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
Originally Posted by _zebra
most are halogen projectors - even the Taiwanese ACA versions (with the H9 low beam), however, they're a lot better than stock regardless, and even putting your own HID kit in them won't be the worst thing in the world. not good enough to satisfy lighting snobs by any means, but not dangerously blinding either.
THIS!
I have the ACA version with my own HID kit and they are 10x better than stock. No issues over 5 years later.
Just to clarify, you're running one of the ebay housings, and then put HIDs in it without changing the projectors? If so, can you post pics of the beam pattern?
Radioflyer is probably the best light modifier on the Corvette forum. I have no personal proof or frame of reference, but I’ve followed his design process whenever he shares it, leading me to believe that his product is more thoroughly engineered than any of the others and offers the most top notch options an build quality. Could that explain the price? I don’t know. From what I know of George, his products are bulletproof, perform better than any alternatives and he backs them 100%.
I’m very interested in further discussion in this thread, to see what others have done since I’m an obsessive DIY’er.
No hacking involved as long as permaseal is not used to seal the projectors to the headlights. Four screws to mount projector to bracket (bracket doesn't come with screws). Unscrew four screws to remove original projector and use same four screws to mount new bracket + projector.
I have done a Morimoto FX-R 3.0 retrofit into ACAs. Total cost was about 650 with about three weekends of work. The Morimoto universal LED fog lights also fit almost perfectly into the C5 fog light brackets.
Doesn't sound too bad. I assumed there would be some cutting involved. I'll see if I can find a walkthrough.
Not trying to be argumentative here, since I know you do good work. If it cost you $650 to do what you did, why not buy the Radioflyer unit for the same price?
may I ask what you did to mount those projectors to the aca housings?... I have a set of fxr 3.0 (2.5") that I was going to put in my aca housings when I get around to it and from what it looks like they will need some sort of conversion bracket but I haven't been able to find one already made... I believe the only one lightwerkz has is for mini h1 projectors
I did buy Radioflyer and decided they weren't at the level of performance I wanted. Radioflyer uses Acme Standard projectors, which are questionable when it comes to longevity with 55 watt HIDs. The Morimoto Mini H1 7.0 is currently the only projector in the Mini H1 size designed to handle 55 watt HIDs as far as I know. The Acme Standard is at Morimoto 3.0 performance. I didn't like the huge step that the 7.0s have, having done other 7.0 retrofits, so I decided to go all out with the FX-Rs that have a smaller step and sold my Radioflyer units to another forum member. For me, it was worth the effort and cost, since I did do a lot of night driving when winter came. Plus, doing things like this is a hobby for me.
Custom built brackets made from nylon boards. There will be no physical way to seal up the headlights, but I haven't had any problems in two years and the FX-Rs are mostly sealed anyways. I can post pictures later.
As far as I can tell regarding the ACA-type lights I don't think the clear lens has anything to do with the beam pattern. They are all plain clear lenses. The beam, IMO, comes from the light module you install, the Morimoto bi-xenons seem to be one of the best and use low and high beams from one module. Lightwerkz has what you need to mount these to even the Chinese clear ACA's. I will be doing this conversion eventually, but at this time I'm working on another project which is taking up my time. I'm interested in what George does with the high beam reflectors since they are typically aimed too high for actual use. I am under the impression he modifies them somehow to align lower.
You would be correct. The only thing a clear vs frosted lens would do is give you a sharp cutoff with the blue/purple bands vs a fuzzier cutoff without visible blue/purple bands.
I don't think George modifies the high beams. The bi-xenon function takes over the high beams, which is why he uses LEDs as floods.
Are you guys talking about these headlights for $339. I installed LED bulbs in my z06 and they sucks, I was thinking about just installing HID in the stock housing. I never had issues with the way HID looks but LED bulbs never looked bright enough to me.
If it's really as simple as a bracket, and popping out the included projector, and popping in a replacement HID projector, I'm definitely interested in retrofitting these. I'll have to do some research this weekend.
