Missing Key Lock
Old Apr 30, 2019 | 11:22 AM
Vinny 2001's Avatar
Vinny 2001
Default Missing Key Lock
When i had the Vette out Sunday i noticed the key lock on the driver door is missing and pushed in (my son heard it rattle). only time i had the door apart was when i replaced the speakers last summer. i didn't mess with the lock but who knows. anyone ever have this just fall in?
Thanks,
Vince
Old Apr 30, 2019 | 12:01 PM
ron993's Avatar
ron993
I wonder if someone tried to punch the lock with a screwdriver to break in?
Old Apr 30, 2019 | 01:25 PM
Vinny 2001's Avatar
Vinny 2001
was my first thought but it is really never outside alone. and always garaged. cuts down the chances for that anyway.
Old Apr 30, 2019 | 01:50 PM
C5 4 ME's Avatar
C5 4 ME
Old Apr 30, 2019 | 04:18 PM
knewblewkorvette's Avatar
knewblewkorvette
I have no idea how this could happen except something striking it. We are talking about #38?
Old Apr 30, 2019 | 05:26 PM
Vinny 2001's Avatar
Vinny 2001
yes, #38 and i was thinking the same thing but was hoping for a known gremlin...
Old May 1, 2019 | 01:35 AM
BodymanBob's Avatar
BodymanBob
Default Lock cylinder
As the lock lock cylinder goes into the handle ( from the backside ) it’s supposed to snap into it . There is a tube built into the handle that the lock fits into perfectly. They made a steel spring in a OVAL shape that fits over that sleeve on your handle. So when you push the lock cylinder into that sleeve it spreads out enough to let it in and then snaps tightly around the backside of it. Perhaps someone did push too hard on the key and it slipped past the spring. Can’t imagine it just fell off. Or it was done deliberately, again I’ve worked on cars since 1971. It just might be possible to remove the trim panel on the door and push it back in to the sleeve on the exterior handle. MAKE SURE YOU LINE IT UP CAREFULLY ! It has a notch on it the matches the groove in the handle so pay attention. I normally insert the key into the lock as soon as it’s partway in the handle to keep the cylinder lined up. The key should be straight up and down. Let me know how it works out or if I can be of any help. Good luck
Old May 1, 2019 | 01:48 AM
CalF's Avatar
CalF
Old May 1, 2019 | 06:59 AM
Vinny 2001's Avatar
Vinny 2001
Thanks for this info. I am going to open the door panel this weekend and see what's going one.
Old May 1, 2019 | 11:43 AM
waupachino's Avatar
waupachino
As others have stated, this is the most common way Thieves break into GM cars with these types of handles/locks. Had a thief try and break into my 00 Grand Prix GTP using the same method on both doors, not only did they pop the locks in, but they also damaged the door skin trying to get the lock to to unlock after it was pushed in. Now my GTP has no locks in the handles in order to deter this from ever happening again.
Old May 1, 2019 | 12:55 PM
3sACROWD's Avatar
3sACROWD
After you fix the lock, buy a painted key hole cover. It makes it appear you don't have a key opening anymore and may deter someone from trying to break in.
It is just a magnet and can be removed if you need to use your key to access the car. Makes the handle look a little cleaner IMO and potentially keeps some crud from getting into the cylinder.
Old May 1, 2019 | 11:51 PM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
$20 for a small magnet! Corvette tax in full effect. I like this option better
https://www.corvetteforum.com/forums...le-covers.html
To Missing Key Lock
