A word caution to those using AGM batteries. Especially since Corvettes sit a lot; an AGM battery that's gone down won't re charge like a regular battery.
To allow an AGM to build up if it sits for a while the only way to recharge an AGM battery is to charge it with another known good battery in parallel. Slow, once it gets past 10.5 volts at a low amperage, you can then charge it on its own. It would be smart(er) to buy a battery charger capable of at least 30 amps that has an AGM mode built into the charger as AGM's actually like being slightly overcharged
I'm running Optima red top. Last one was 5+ years old when one terminal began to leak a little and grow some crystals. Was still holding charge. So, I bought a new red top and have zero complaints.
interesting, 5 years is not a good showing IMO. I had a 'red Top' years ago in my race car and was not impressed. A lot of guys I raced with had better luck with the Yellow top
In the heat of Florida, we're pretty happy to get 5 years out of a battery. Maybe up north that's not so spectacular.
Agreed, most modern day chargers have that built in from what I've seen
"Best" AGM? Probably the original Sears Platinum. Last forever - mine is now 13 years old, holds a charge for weeks on end with no issues. They were Odyssey Extremes rebranded for Sears. The "current" Sears Platinum is from a different supplier, Johnson Controls, I believe. The only problem with Odyssey batteries is that they are very pricey. Even back when I bought my Platinum, it was $200. I believe the same battery now from Odyssey is more like $300.
The "best" is never cheap.
As an aside, the "best of the rest", i.e. wet cell batteries, in my experience at the moment are the Everstart Maxx from Walmart. They last well - I have one I bought a good few years ago in my truck and it always starts on the button and we had another "keeper" in our Turbo Subie. Wish I could get one to fit my generator - that thing is on its 5th battery in 13 years - 2 Diehards, 1 Autocraft and 2 Interstates. Trouble is it's an odd size and choice is limited
I went with an Optima Red Top as my last Red Top lasted 14 years, even after absolutely killing it by leaving the satellite radio on when putting it into storage for 3 month when it was 7 years old.
couldn't agree more. Odyssey from everything I've heard is superb
Quote "Originally Posted by jacktheladView Post
"Best" AGM? Probably the original Sears Platinum. Last forevermine is now 13 years old, holds a charge for weeks on end with no issues. They were Odyssey Extremes rebranded for Sears. The "current" Sears Platinum is from a different supplier, Johnson Controls, I believe.But who makes DieHard batteries?"
Well, many people are confused about the owner and manufacturer of the popular DieHard batteries. DieHard car battery brand is owned by Advance Auto Parts which is an American automotive aftermarket parts provider. Advance Auto Parts bought the DieHard battery brand from Sears in late 2019 for $200 million.
There are only a handful of companies that make batteries. Most of them are just re-stickered. I have a SuperStart from O'reily because I got a discount through work and the replacement option is easy since there's locations everywhere.
I've heard Interstate is/was the largest manufacturer. They used to be made in the U.S.A. (like most things). Don't know if that is still true, or not. I personally like Gel batteries. Had one on a snowmobile, which places a huge demand on a battery. But I've never had an AGM battery. I was surprised to read that GM has returned to top post batteries. Lionelhutz (Peter) has a post somewhere about some side post battery terminals not having sufficiently deep female threads, and there are cases of some guys tightening their battery cables, but the bolts bottom out BEFORE a decent contact is made with the cable. He advised everyone with side post batteries to try moving/twisting the actual cable after its tightened, because the bolt may be tight (actually bottomed out!), but the cable(s) aren't sufficiently tightened!! I am old enough to remember the problems with a top post. Until I bought my C5, I NEVER had a problem with a side post battery. I suspect the design is sound. The variable quality must be due to lack of manufacturing quality control, and/or country of origin. Is there an AGM/Gel battery made with side posts? I think I saw an Optima that had both top AND side mounting, but I'm not sure......
Off topic, but when you look at Sears, and the financial position they're in, it's not hard to see why. They had 2 of the best moneymakers you could ask for as a retailer; Diehard batteries, and Craftsman tools (especially Craftsman). So what do they do? Sell them off!!!
I used to work at Ferrari of Dallas, Odyssey batteries are what we put in older Ferraris that didn't qualify for factory warranty replacements. IIRC, the F430 Scuderia can only take an Odyssey due to it being a bizarre group size compared to the standard F430.
I currently have a Red Top and not too impressed with it, I think I got a bad/old one from Advance Auto...considering getting an Odyssey direct from them.
I don't think the employees at some of these box stores check their more expensive batteries and since no one is buying them as often...my guess is they discharge pretty quick
Anyone hear anything about Deka? I recall them having a good rep but I dunno if they make AGMs...
Probably mine, and I use both the top and side mounts. Also put in a 250 amp alternator to help demands of all my electrical needs.
