Help valuing this one owner car
Old Feb 13, 2022 | 04:49 PM
  #81
vettedays's Avatar
vettedays
Originally Posted by Mike98SilVert
$31K in receipts? That's pretty high. AC compressor, condenser, freon with labor around $1,900, Balancer with bolt, belts and labor around $1,000, add $300-$500 for water pump and pulleys. Brake rotors pads powder coating and labor around $1,200. Sway bars, end links, bushings and labor around $400. Fluids. plugs, wire and labor around $400. Headlight motors replaced around $350. How do you get to $31K?
All of these things are very common repairs made on any C5 for sale with around your mileage, although my "99 did not have these issues. BTW, the 2000-2001 C5's had the most expensive problems of that generation followed by the 2004.
Any pictures of your 2001 and C6 ZR1?
Ill try and help you out with prices. Let me know if you want me to cut and paste anything else from my spreadsheet. I have a lot more for you. Im glad you help you!! We all need to learn from others and it looks like you need a lot of help!
Ac compressor - 89018958 332
Condensor (52470569) 265
pressure hose (19213199) & Accumulator (1132765) (Rockauto) 120
AC Hose (10229474) 70
Orifice tube (524477004) 14
GM AC Schrader valves (3041827, 10245619) 20
GM O-rings back of compressor (2724577) 10
Serpentine tensioner pulley (12568181) 80
Serpentine idler pulley (12564401) 43
Serpentine belt (19244950) 54
AC Belt (19172680) 50
AC tensioner (12560345) 90
AC idler (12557334) 50
Brake pads (12530681, 12530688) and rotors (10445856-9) 513
Stainless brake lines (Doug Rippie Motorsports) & fluid 195
Brake fluid reservoir (18M2441) 80
Powder coating calipers and brackets (Mesa Powercoaters) 300
Front Calipers (88875128, 88895129) 245
Rear Calipers (88895130, 88895131) 171
Front Brackets (12455799) 104
Front Caliper overhaul kit (12530687) 76
Rear Caliper pins (19138105) 54
Rear Brackets (12455800) 37
Rear Caliper overhaul kit (12530686-Disct.) 36
Front Caliper pins (18039204) 25 One GM rear caliper pin 18
Exhaust hangers (10429800) 75
F/R O2 Sensors (19178933, 19178930) 196
Corsa Sport Exhaust + installation + gaskets (10276792) 955
Dewitts Radiator (32-1139097M) 557
Lower radiator support (vettenuts) plus painting 390
Radiator cooling fan motors (22104439) 166
Upper radiator hose (10229479) x 2 67
Top surge tank inlet hose (10408463) 25
Radiator rubber mount (10188023) 20
Left side pump hose (10229491) 20
Dexcool coolant (12346290) x2 50
Steam line and small hose under throttle body (12602544) 40
Left water pump heater hose (10407026) and clip (11570616) 40
Lower radiator hose (10229480) 38
Thermostat 30
Throttle body hose (12557352) 30
Bottom surge tank back to fire wall (19329002) 10
Top radiator, drivers side clamp (11516234) 10
Top surge radiator hose tank clamp (ebay) 9
Coolant tank (10430189) 91
Sac City Corvette front radiator support Fangs 57
Old Feb 13, 2022 | 05:49 PM
  #82
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Originally Posted by vettedays
You’re way off with all of your numbers. $1000 balancer replacement? Lol. The ATI was $500 alone. Come on man! Also, you’re way too high with the ac replacement. But hey, how about you try to go through the list and for every guess you get right I’ll post the receipt. LOL. Moreover, the list posted is about 1/8 of the actual list. That’s how I got to $31k. New NOS clear top and new NOS painted top was $5k alone. Try and keep up with me!
Pretty smug aren't you. How about you try and keep up with me!
Like I said before, NO WAY $31K, not even close.
Suddenly both tops are in you estimate. Aftermarket exhaust and your two tops are not maintenance. But it doesn't matter in the retail value of a 2001 C5 Coupe with 72K miles.
Enjoy your ZR1. What year is your ZR1? Is it a C6 or C7? What color how many miles?
Old Feb 13, 2022 | 06:26 PM
  #83
Yello95's Avatar
Yello95
St. Jude Donor '11
I think everyone in this thread would like to see pics of the OP's Corvettes....that is if he even has a Corvette ???..not sure at this point.....he refused to post any pics...what's up with not posting pics
OP...please please, please send me some pics of your Corvettes and I will post them for you no charge...
Old Feb 13, 2022 | 07:20 PM
  #84
o2bnkc's Avatar
o2bnkc
And that's why this is the last place I would ask what my vettes are worth.
Old Feb 13, 2022 | 08:09 PM
  #85
vettedays's Avatar
vettedays
Exactly. These old guys are just angry and out of touch with the market. 😂😂😂😂
Old Feb 13, 2022 | 08:10 PM
  #86
vettedays's Avatar
vettedays
Im not smug. I’m just educated. Let me know if you need help with your car.
Old Feb 13, 2022 | 08:13 PM
  #87
vivasantana's Avatar
vivasantana
I hinted hard at that in post #53.
I am not buying an unseen purchase & a day before he gets a C6!
Might be wrong but that's the way it looks.
Rock on Santana! Rock on!
Six decades strong!
93 Vette
​​​​​​​74 Capri MK1 Modified
Old Feb 13, 2022 | 09:37 PM
  #88
DebRedZR1's Avatar
DebRedZR1
Moderator
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'17, '21
