Help valuing this one owner car
Looking to sell my one owner C5. Please let me know your thoughts on value.
2001 6-speed coupe
72,000 miles
One owner with all books and records since new
Mag red with new Ridies tan napa interior (new foam)
Recent 70k service included the following (ALL OEM GM PARTS unless otherwise noted; no aftermarket parts):
ATI harmonic balancer
Dewitts radiator
Steering rack rebuilt by Turn One Steering
New fan motors
New belts
New AC condensor
New AC compressor
New coolant hoses
New steering hoses
New water pump
New alternator
Melling oil pump
C5R timing chain
Front motor resealed
New valve cover gaskets
New valley pan gaskets
New lower radiator support
New front and rear pads and rotors
Powdercoated gloss black calipers
New C6 Z06 front and rear shocks
New C6Z06 sway bars and bushings
New sway bar end links
New front tie rod ends and boots
All new pulleys including tensioners and idlers
New diff fluid
New transmission fluid
New fuel pump
New fuel level sensors in both tanks
New power steering cooler
New plugs/wires
New oil pressure sending unit
Two new headlight motors
50k mile service
Upper and lower oil pan resealed
Trans and diff resealed
New MAF sensor
New coolant reservoir
New brake fluid reservoir
Michelin AS+ tires with 6k miles on them
Corsa sport exhaust
Comes with both tops clear and painted (no signs of fading on clear; was only used twice then stored inside since new)
EBCM fixed by ABS Fixer
New steering wheel position sensor
AC controls LED lighting fixed by ABS Fixer
Thanks for the help!
2001 6-speed coupe
72,000 miles
Dewitts radiator
New fan motors
New belts
New AC condensor
New AC compressor
New coolant hoses
New steering hoses
New water pump
New alternator
Melling oil pump
C5R timing chain
New diff fluid
New fuel pump
New plugs/wires
50k mile service
New MAF sensor
Corsa sport exhaust
19k. My answer. I purchased an M6 (99) car last fall w/ 75k on it for $14,700. Car is very nice. I'm the third owner. One guy had it for ten years and put 2k on it. The LS1 is bulletproof.
I think that's what your car will fetch. Just my opinion obviously. GLWTS
Good grief you've maintained that car well. But, it's worth what it's worth.
Accident or flood? No. Im the original owner. I would have put that in the original post if that were the case. A majority of the repairs are typical of a harmonic balancer replacement.
All of these repairs are pretty common with C5's and/or preventative maintenance and/or repairs with the "while youre in there" mentality.
Regardless, I wish you GLWS!
Sounds like you almost have a new Vette. That would be a nice Vette for someone looking for one that has been pretty much refurbished...
PS...
I think with all the stuff you have done, you should be able to sell it for way more than a regular 70K similar Vette
PS...
That's a lot of work for only 72k miles. But IMO it would give me confidence those items have been addressed.
Assuming the car needs absolutely nothing, no matter your advertised price I'm thinking $20k minus anything I can see that needs repair. I'd be pretty happy to get you down to $18k
(personally I'd be looking for a 03-04 and would give a little higher price accordingly)
C5 Corvettes were produced at a clip of about 35,000 per year from '98 to '04 . . . .
So about 175,000 in were produced . . . .
Yours with 72,000 miles is in the grand scheme of all things C5 is on higher end of the milage spectrum . . .
The number of Drivers still living that know how to drive a Manual Transmission is shrinking day by day . . .
The Service History and Added Louder Exhaust Mod can scare off Buyers looking for an Original Low Milage Garage Queen that aint gonna scare off their Wife's logical fun car input . . .
Your Target Demographic for your C5 is gonna be a Younger Single Redneck wanting more Horse Power the his Fart Canned 4 or 6 Cyl Winged Atrocity . . .
Can this Kid get a $16,000 Loan on a 21 year old Sports Car . . . Not very likely . . .
C5s with Tan Interiors don't really age well . . .
OK - We got some of the Glass Half Empty Elephants in the Room factored into the equation . . .
Let's look at some Glass Half Full Selling points . . . .
Fresh Tires means the new owner aint gonna have to pop another $1,200 into the car for a while ( provided they don't spin the rears down quickly )
Resale Red will help a tad
and lastly . . .
a Picture is worth a thousand words and helps the experts here determine a legit value on your 1 owner cared of C5 . . .
Blind Best Guess on Value . . . .
A Stealership will offer you about $9,200 to buy outright ~ $9,700 Trade in Value . . .
You can try asking $17,500 and sell Private Party ~ but be prepared for aggravation and lots of unqualified kids dreaming
Be real - Price it at $15,000 Firm - and hope a qualified buyer has the cash in hand to make the car go away . . .
or . . .
Just hold on to the car knowing that the C5 is going to be the next C4 once the Electric C9 comes out . . . and value will most likely just stagnate over time . . .
Hope this evaluation based on a sight unseen description helps in your quest for a value
and lastly . . .
a Picture is worth a thousand words and helps the experts here determine a legit value on your 1 owner cared of C5 . . . Blind Best Guess on Value . . . .
or . . .
IMO you have a very desirable Corvette....a late model one owner C5 with a complete documented service history, 6 speed manual transmission in Mag Red.
Provided that the paint and interior are near perfect and given the current market for used cars especially Corvettes, I would start at $19,900. But you could start higher if you don't mind waiting for the right buyer who can appreciate all that you have done. Personally, I would keep it and enjoy it for another 72K miles. I look forward to seeing some pictures.
