Throttle response improvements C5
Hard acceleration is a function of a the throttle under full load and under that level of throttle input there's like 100% input. Even at over 50% there's nothing to tweak in throttle response. That's also not the range most people pull away from a light at
On the other hand at low throttle and low speed inputs under load any car with DBW will experience throttle lag. The computer is designed that way. Adding gearing and/or TQ/HP only pushes a heavy weight harder. It doesn't remove lag. Just masks it. Put the car in neutral, tap the gas from idle. It will still rev as slowly as a lower geared, less powerful car. They all employ the same DBW system. Think of how fast it revs quickly from low to mid. Not how fast the whole car accelerates. Acceleration is a function of all out HP and gearing
Perhaps further replies might be best in Scan and Tune Section
More air in & out and less rotational mass with a gear that puts you higher in the RPM band... because faster acceleration is what matters most either way.
GM optimized this car to be easy to drive and hard to stall for rank amateurs who have bad habits and refuse to learn. You can knock off 30+ pounds from the rotating assembly and improve breathing and end up with a car that's a lot more engaging, at the cost of being weirder to drive for anyone who's not used to it.
Its not like the C5 with 2.73 gets 15 more miles to the gallon than a C5 with a 3.42. So going from 3.42 to say 3.90 or 4.11 isn't all of a sudden going to cost you a massive amount of MPGs. That's just not true. Fact of the matter is ...the MPGs go down when people have more fun driving their cars.
We've done 3.90 gears, 4.10 gears, stock clutch and flywheel, light clutch and flywheel, assorted heads, assorted cams, different exhausts, 12+ different sets of tires, ported TBs, 6 or 7 different cold air intakes, prochargers, different shifters etc..
Not one of us struggled to drive one another's cars. In fact...my 74 yr old dad (RIP) enjoyed driving my H/C/I, 4.10 geared, light weight clutch and flywheel set up more than any of the other cars we had. Including an axle back, otherwise stock '99 coupe and a 97 Viper.
Making most of these upgrades don't all of a sudden render these cars difficult to drive or terrible on gas. Yes "extremes" can and will do this, but there are countless directions one can go in to improve fun factor 2 fold without sacrificing any of that driveability whatsoever.
This string started based on the debate over throttle devices to "improve" throttle response. Which in my opinion making my throttle more like an on/off switch is counter productive in every way. I want linear acceleration at all times. It's easier to control at launch, more pleasurable to drive leisurely, and it's easier to drive at speed.
Go on YouTube and look at videos where throttle devices were tested against draggy times. Not one driver gets a better time with the device installed. They now struggle to find that linear throttle control and can't launch their cars without spinning. All things that you can still more easily control with a linear throttle.
This string started based on the debate over throttle devices to "improve" throttle response. Which in my opinion making my throttle more like an on/off switch is counter productive in every way. I want linear acceleration at all times. It's easier to control at launch, more pleasurable to drive leisurely, and it's easier to drive at spee.
I suspect most or all of the people complaining have auto transmissions and part of the issue is how the transmission tuning/shifting reacts at various throttle inputs.
Fact of the matter is...there is no quick fix for under $200 for the A4 C5. Especially with a 2.73. You need to tune the car at a minimum. But if you did both the TB p&p and tune with a 3.42 diff swap your car will be exponentially more fun to drive. All without breaking the bank, completely molesting your car, or making your C5 a gas guzzling monster.
No need to go with an expensive after Market TB in my opinion. The OEM TB with p&p is very capable. I've used my p&p OEM TB on all of my builds. Including H/C/I and procharged. It's still on my car as of this very moment.
Acceleration matters but how it's developed is gold. A computer that electrically opens a throttle is always going to slower to rev than a cable. That's what I meant when I said put it neutral. Independent of ratios. It's the ECU/DBW throttle that doesn't respond as efficiently as a cable throttle is more the message
The idea of response and flat out acceleration is kind of being blurred, partially misunderstood. Also the big Gorilla in the room is Torque. Torque spins the tires and moves a heavy car. But, take V8; try and make more HP. 9/10 guys add power by stealing usable TQ and pushing more air and fuel at higher RPM's which is also where and why A LOT of guys go for the 4:90's. You end up forcing the car to rev higher and sacrificing power it used to make at the normal range.
Sure a high geared car will use the mechanical benefit to accelerate harder more easily but it still won't make an identical geared DBW car accelerate as fast as cable throttle. The ECU is stealing faster response from any motor that the motor is capable of producing, IF it were allowed to open the throttle faster,wider and sooner than it is programmed. That's all
It’s very possible there’s throttle response improvements to be had with tuning, but not because of dbw
This isn't just a single Company attempt. There are others out that help with DBW Throttle lag
Absolutely don't take just my word on this
11-01-2013 #4
"99 Corvette with the stock ECU. It has had this throttle lag "
Owners own post
https://forum.hptuners.com/showthrea...ottle-Response
Owners own post
“99 Corvette with the stock ECU. It has had this throttle lag every since I built the 6.2L race motor with the 90mmTB and 233/239 cam”
Sounds like no lag before
I understand throttle responsiveness. I've owned 20 or so two stroke dirt bikes 125, 250 and 500 cc. Nothing responds like a two stroke.
So now you've agreed that the gears will in fact "mechanically" (as if semantics matter) accelerate your car faster. You can test my gear theory yourself with a geared pedal bike. Same rider, same physical capability, which gear will allow you to propel yourself forward with more acceleration under the same power?
I never said there isn't a lag with DBW. I'm saying there are absolute ways to improve upon this with the correct modifications that don't include a pedal device. All of which play a role in making the stock C5 a better performer.
We aren't comparing cable vs. DBW with the C5. The C5 is only DBW. Therefore we are determining how to get the DBW handicapped C5 to accelerate faster. Gears will 100% have a positive impact on ET's. Pedal devices have yet to prove to be able to do this.
You have and do own both an MN6 and A4. What modifications have you made to improve the performance of your cars? Were they mild, wild or mostly stock? After these changes were made was your car still as lacking in responsiveness? If the answer is yes, you need a better tuner, more go fast parts, and a gear. Otherwise your basically stuck until you or someone invents a C5 pedal device.
