Throttle response improvements C5
Old May 30, 2022 | 12:54 AM
  #61
dainon's Avatar
dainon
Originally Posted by lt4obsesses
Yeah, in my search for a C5, I had two major requirements, a coupe and a manual trans. I had looked at an '01 that was bone stock, 116K miles but in reasonably good condition. When I drove it, well, it was less than exciting. coming from a Dodge with 485 HP, and having owned a 455 HP Camaro and a 423HP Camaro before that. It did indeed feel slow. Then I drove the modded one and it was night and day. Looking back, I think I would've been better off getting the stock one and building it from scratch. But, oh well, lesson learned.
I read the attachment. In his first graph of the stock accelerator, it shows clearly the factory designed lag between pedal position and throttle position. As far as the claim about just pushing harder on the pedal, there are two things. First, is that the MB had the adaptive dbw, which adjusts according to how the driver is using the throttle. I'm not so sure that many of the other car makers were using this technology, and he did mention that it depended on how deep he pushed the pedal and how quickly. My second point is strictly from my experience with the LS3 Camaro, which was a manual trans. The lag was horrible until about 50%. However, if stabbed it to 50%, the throttle then acted exactly like an on/off switch. At that point, the thing would take off like a rocket, which wasn't good in every situation. That said, after the last time the booster sent the car into limp mode, I just took the damn thing out.
My Silverado has a laggy throttle feel compared to the F150 I had before it. Over the years, I have come to realize that Chevrolet has done this to attempt to decrease fuel consumption and prevent jack rabbit starts. Even though my L83 has much more power and torque than my old Triton, it sure doesn't feel like it off the line. I looked into a Pedal Commander for it, but am now thinking.. Is it really safe putting this thing between my throttle body and my foot? If it goes berserk and sticks open or sends full throttle signal when I don't expect it, how many people get hurt, etc. Or what happens if there is an accident and the insurance company finds that thing installed..
After weighing the options, I have chosen to just live with the heavy throttle feel.
After reading your experience, I think a tune and some mods are much safer and more effective. Is that your conclusion, too?
Old May 30, 2022 | 03:51 PM
  #62
Speedy007's Avatar
Speedy007
Clean it real good spotless hit the flap control ends with some 3in1 . Cleaning the maf and most importantly make sure that air filter is clean …throttle response could lag also from some clogged up cats / bad plugs wires or coils going bad
Old May 30, 2022 | 07:02 PM
  #63
c5arlen's Avatar
c5arlen
Originally Posted by Johnny Hardcore
The Volvo C30 has a 1st gear drive ratio of 4.66. The C5 3.06. Ever stop to think that maybe that chirping you are getting is coming from that low geared 1st gear in the Volvo?
Johnny... Oh for sure I've "stop to think"!... Ever since I started driving this GM product!... Lots of stop to think! Got to admit though, 4.66 ratio 1st gear in this here C5 would chirp ... But would it Fix the discussed C5's GM designed foot felt accelerate lag or would it be "smoke and mirrors"?.... Like... "Let's fool em" 🤓
Old May 31, 2022 | 07:41 AM
  #64
lt4obsesses's Avatar
lt4obsesses
I don't really know what all this controversy is about. If someone wants a little more linear response from the pedal without cracking open the engine or swapping gears, a throttle controller is good tool to use.
They're safe, inexpensive, keeps warranty intact, and can be easily removed.
Of course, on a C5, warranty concerns are long gone, but then apparently no one makes a controller for the C5, so this is really all kind or moot point.
Old May 31, 2022 | 09:57 AM
  #65
Johnny Hardcore's Avatar
Johnny Hardcore
I bought my first C5 23 years ago ('99 MN6) when I was 25. So I don't particularly recall any lag, but I do recall finding the car to be pretty darn slow a short while after ownership (within the 36 month warranty period). I've owned two other '99 MN6 C5's along the way. They all needed something to wake them up. Gears, CAI, LS6 intake, p&p TB at a minimum in my opinion. The 3.90 or 4.10s are a must for me in NA C5s.(3.42 for the A4).
C5's are lazy because their tuned to be lazy, and their legs are too long for low speed and typical highway driving. (the Z06 M12 with 3.42 gear is equivelent to MN6 with a 3.90. Which should tell folks something about gearing relevance. No Z06 owners jumping in here supporting throttle lag comments. Same DBW stock TB's and intakes. Hmmmmm makes ya think)
Just with a tune and a gear swap the C5 becomes noticeably more responsive in every way. Making them truly fun to drive (and how they should've come from the factory...at least option wise). Without molesting the sh*t out of them or dropping big $ a tune and gears is the way to go. So no...not "smoke and mirrors".
I'm looking forward to Hary's update once his 3.42s and tune are added. (I think he should p&p his TB at the same time so the tune accounts for it). I'm willing to wager that he finds his C5 to be like a totally new car to him and it no longer is lazy with laggy throttle response.
Some of us learned this lesson over 20 yrs ago. But there is still hope for some of you others that are late to class.
Old May 31, 2022 | 10:54 PM
  #66
tombrammer's Avatar
tombrammer
Originally Posted by Hary Gahtoe
Throttle response; isn't related to gearing at all. It's due to ECU controlled throttle input. You could install 5:90 ratio and the engine will still rev from low to mid range exactly the same rate as 3:42, 3:15 or 1:1. The car itself may accelerate faster (0-60) but a car with 5:90 will still rev just as slow as car with a 2:10 rear end ratio in neutral. Gearing and the rate a throttle revs are independent of each other. Completely.
Hard acceleration is a function of a the throttle under full load and under that level of throttle input there's like 100% input. Even at over 50% there's nothing to tweak in throttle response. That's also not the range most people pull away from a light at
On the other hand at low throttle and low speed inputs under load any car with DBW will experience throttle lag. The computer is designed that way. Adding gearing and/or TQ/HP only pushes a heavy weight harder. It doesn't remove lag. Just masks it. Put the car in neutral, tap the gas from idle. It will still rev as slowly as a lower geared, less powerful car. They all employ the same DBW system. Think of how fast it revs quickly from low to mid. Not how fast the whole car accelerates. Acceleration is a function of all out HP and gearing
Perhaps further replies might be best in Scan and Tune Section
Throttle response relative to what? Engine speed or vehicle speed? If there is traction the vehicle with a 4.10 gear will rev and accelerate much faster than an otherwise identical car with 2.10 gear, it feels like the throttle response is much better in the faster car, the car with 4.10 gear will feel much more "responsive".
Old Jun 1, 2022 | 02:06 AM
  #67
Kingtal0n's Avatar
Kingtal0n
1. Perform all maintenance and cleaning, pull apart the easy to access items and wash them out for example I would wash the intake manifold, replace pcv hoses, wash the throttle body and then OIL the throttle body so it can move easily and lubricated nicely while clean.
A new OEM air filter. Possibly new plugs, at least look at one or two of the old ones if you are a good mechanic and able to do so.
New plug wires, new pcv valve, it all adds up. Clean, new. Wash the engine. Clean the maf if it has one. Consider an Speed Density tune to get rid of the maf sensor... that is #2
2. Tune the engine properly. Get HPTuners and start learning how to tune it. Don't rely on other people. There are several perhaps 20 different things in the ECU which can improve throttle response. Some of the most important are injector phase and throttle movement sensitivity for DBW conditions. Also getting rid of the MAF is usually a great way to increase engine response and feel. It depends on the engine mods how bad the maf can influence the running condition but I always get rid of it for performance applications. Make sure you are using OEM style intake tract. There is kinetic energy of fluids to consider and the OEM does a great job designing their intake systems, this should not be overlooked.
3. You cleaned it, tuned it, maintained it. What else is there? Light weight rotating parts will help the engine feel lighter and rev easier. If auto there is some incredible difference when using a proper Yank 9.5" converter. No need to get a high stall, just the light weight 9.5" unit does wonders by itself, removing rotating mass will free up power and increase economy. Lighter wheels and lighter tires and light driveshafts all would help the car accelerate more quickly. Too quickly sometimes. If using a manual trans I would keep the normal weight flywheel, don't reduce rotating mass in front of the transmission. After the transmission however, is fine to reduce the weight of rotating parts.
These 3 things are the key to response, efficiency, 'feel' in the way the engine delivers power and handles it's fuel and air. It goes for all engines, all vehicles.
Old Jun 1, 2022 | 05:59 PM
  #68
c5arlen's Avatar
c5arlen
Or... Live with it.... GM's methods of LS1 acceleration Is what I'll do, and NOT reluctantly!... It's been knowingly developed from the informitive guys on This discussion.... Smart guys.
Old Jun 1, 2022 | 07:35 PM
  #69
c5arlen's Avatar
c5arlen
The throttle controller is really simple device that increases the voltage reading sent to the pcm and the throttle body. It simply compensates for the factory designed throttle lag, making the throttle response more linear (like the old cable days) at lower throttle. Because you know, mashing the pedal to WOT all the time on the street is never really a good idea.
Bingo.!... good one lt4....
Old Nov 24, 2022 | 12:59 PM
  #70
???'s Avatar
this thread gave me brain damage to read. but from what I handle of it I take it there's no pedal commander style box out for the c5.
a buddy was asking so I thought I'd take a look around. shame if not.
Old Nov 24, 2022 | 06:42 PM
  #71
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
I had the CoW Booster from Chuck at Corvettes of Westchester - woke my car big time! Especially with the throttle.
Old Nov 25, 2022 | 01:17 AM
  #72
Hary Gahtoe's Avatar
Hary Gahtoe
Originally Posted by tombrammer
vehicle with a 4.10 gear will rev much faster than an otherwise identical car with 2.10 gear,
it feels like the throttle response 4.10 gear will feel much more "responsive".
Puppycock. Clearly the definition of throttle response has been misunderstood and the mechanical advantage of gearing also never has any bearing on throttle response.
Let me put this in terms more plainly understood.
A riding mower with a bigger pulley (read higher mechanical advantage AKA 4;10) will change direction more easily than a lower original gear. That does Not mean the engine will rev faster At All. This is the point lost to many here. Gearing won’t effect the rate of the Engine’s ability to rev faster relating to throttle response. Only what that engine has to struggle to move.
Prove me wrong. Take two cars. One with 5:90 gear set
One with 2:10
Start the cars. Push in the clutch. Rev up both. The car with a 2:10 will rev up just as fast
Old Nov 25, 2022 | 01:30 AM
  #73
Kingtal0n's Avatar
Kingtal0n
They are talking about in gear, not neutral. Who would rev the engine in neutral and complain about that not being fast enough and desire to change the gearing in the rear end to make the engine rev better in neutral.
Protip: don't rev your engine in neutral.
Protip#7: set your neutral rev limiter around 2800 to 3200rpm so you can smack the limiter in neutral without damaging the engine. Plus it sounds cool, gets there fast and people can't tell your safely settling down at 3k and not bouncing off the limiter at 7k or whatever.
Old Nov 25, 2022 | 12:46 PM
  #74
Hary Gahtoe
Protip#7: set your neutral rev limiter around 2800 to 3200rpm so you can smack the limiter in neutral without damaging the engine. Plus it sounds cool, gets there fast and people can't tell you’re safely settling down at 3k and not bouncing off the limiter at 7k or whatever.
It’s not a matter of what gear you have. That’s why I mentioned revving not in gear. Gears have absolutely no bearing whatsoever on throttle speed
An analogy here would be;
if you have a race car that already has max gears you can still gain benefits from engine management allowing for quicker throttle speeds that allows for Quicker response. That’s the point
Old Nov 25, 2022 | 04:03 PM
  #75
Kingtal0n's Avatar
Kingtal0n
Ive never heard the term throttle speed. Movement rate of the throttle? That is computer controlled for DBW and foot controlled by DBC. Why mention revving the engine at all to determine the rate something is moved by the computer? Im just trying to understand what you are saying and you are using words I haven't seen in 25 years across 25 difference automotive forms over 100,000 posts nobody ever talked about throttle speed rofl sorry
Old Nov 25, 2022 | 10:34 PM
  #76
Hary Gahtoe
Ftf!
Because the ECU handles the DBW tipin of the electric motor on the throttle body and the % of total throttle amount and the ECU can be remapped to operate at a rate more instantaneously with less rubber band effect
Guilty as charged about the age thing. I’ve had involvement in motorcycles and cars for half a century
Old Nov 26, 2022 | 03:38 PM
  #77
c5arlen's Avatar
c5arlen
Well hell 🤔... I've just finished a 3 day drive from Palm Desert to Vancouver with my foot firmly (and loosely!) operating the C5 throttle on the Eye 5 for 3 days.. and at the common 80-90 hiway speed. It was extremely comfortable and with occasional bursts with the go fast peddle in getting clear of many those "amateur" drivers not uncommon at holiday time. I've got to admit.. very comfortable operating the C5 throttle as designed AND understandable with my new found C5 throttle knowledge obtained here!... You guys are so smart, and are the LS1 designers. 👍
To Throttle response improvements C5
Old Nov 26, 2022 | 07:24 PM
  #78
Supercharged111's Avatar
Supercharged111
As far as fixing it with a tune, from what I understand, this particular fuel table is separate and nearly impossible to adjust, to the point of bricking a pcm if you try.
I tried my hand at remapping the throttle via PCM tune a few months ago and I'm in love with the results. It was EASY EASY EASY to find in the tune and make the changes. You only brick it if you go HAM. I wouldn't dream of using some gimmicky device that lies to the car to an unknown extent when the correct way is so simple.
Note: I pretty much stopped reading at this post, so if in pages 2-4 this was covered don't hold it against me. I just wanted to weigh in on favor of the PCM tuning method.
Old Nov 27, 2022 | 12:24 AM
  #79
vette4fl's Avatar
vette4fl
So I can have a tuner adjust the throttle response?
Old Nov 27, 2022 | 10:36 AM
  #80
Supercharged111
What year are you? For sure on the P01/P59 cars.
