Cats
Old Jul 11, 2004 | 10:52 AM
madmustang's Avatar
madmustang
Default Cats
Am getting ready to buy some long tubes for 98 C5 and would like to hear from those who have removed Cats altogether. What are the pro's and con's of not having cats? thanks mm
Old Jul 11, 2004 | 11:09 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Pros:
Car becomes much louder.
Exhaust has the sweet smell of an old musclecar.
You'll pick up a few hp if tuned properly.
Cons:
Exhaust smells like an old musclecar.
You need to buy 02 sims or use a programmer like LS1-Edit to eliminate throwing codes from the rear 02 sensors.
It's illegal, and you'll have a tough time passing emissions if you have to test in your area.
Old Jul 11, 2004 | 11:21 AM
CAPN17's Avatar
CAPN17
Sorry, I thought you were looking for a recipe for cooking cats walking on or messing up your car.
Old Jul 11, 2004 | 11:30 AM
madmustang's Avatar
madmustang
Default Y2Kvert4me
thanks for the feedback and actually where i'm going with this is why do people rush out to buy low flow cats. my exhaust people tell me that there is little difference between stock and low flow cats and they contunue to be surpised that people continue to buy the low flows. If there's not much difference between the two, then seems like staying with stock ones or just eliminating altogether are the two best options. but what do i know.
Old Jul 11, 2004 | 11:44 AM
andy82's Avatar
andy82
2017 C7 of Year Finalist
I'm sure you mean HIGH FLOW cats
Old Jul 11, 2004 | 11:47 AM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
I'd say the choice mainly comes down to which header system you decide to go with. There's so many options and choices out there now
Some headers like the TPIS or Stainlessworks will mate to the stock cats.
Others such as LG and FLP are complete systems, that come with either hi-flow cats/no cats or both...but neither are compatible with the stock cats.
Just simply replacing stock cats with hi-flow cats on a given system is probably not worth the effort. I'd suggest researchng the many header options out there, and decide what's best for you, as they do vary quite a bit in pricing. I personally have the FLP system, and can switch out my cats and straight pipes in a matter of a half hour...plus I have my entire stock system uncut and intact should I decide to return the car to stock one day. These were the key factors in why I chose this system. A little more expensive, but worth it to me.
If you just want to put headers on as cheap as possible, I'd probably retian the stock cats and get headers that connect to them...you should be able to do that for under a grand. If you don't want the cats, you can always get an off-road X-pipe that will replace the cats.
Old Jul 11, 2004 | 11:57 AM
AU N EGL's Avatar
AU N EGL
I use TPIS ceramic long tube with Random Tech High Flow cats and x-pipe. GHL exhaust.
Great sound - if there is a loss of power with cats, it is minimal.
Old Jul 11, 2004 | 12:21 PM
BHP's Avatar
BHP
You will get a few HP with say Random Tech cats but the real difference is the weight reduction.
Old Jul 11, 2004 | 07:28 PM
madmustang's Avatar
madmustang
Default andy82
yes, I did meam high flow. thanks. mm
Old Jul 11, 2004 | 07:40 PM
Mike Mercury's Avatar
Mike Mercury
high flow - low restriction... we knew what you meant to say.
To Cats
