Nitrogen
Old Nov 18, 2004 | 04:03 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Default Nitrogen
Is anyone running nitrogen in their EMT’s?
I was told that there is less leakage when nitrogen is used.
Regards.
Old Nov 18, 2004 | 04:09 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
It is a topic that has been discussed before, but my impression was that not many people were doing it - I know I'm not...
Old Nov 18, 2004 | 04:10 PM
ALLEGRO's Avatar
ALLEGRO
Too much trouble for me.
Though you get less temperature variation with N.
Old Nov 18, 2004 | 04:18 PM
AU N EGL's Avatar
AU N EGL
Um you have Nitrogen in your tires. Air is 97% Nitrogen.
If you mean 100% Nitrogen, not really nesscarly for street tires. SOme race cars Nitrogen so there is less air pressure change when the tires hear up.
Old Nov 18, 2004 | 04:24 PM
Benpup's Avatar
Benpup
Thanks I appreciate it.
Regards.
Old Nov 18, 2004 | 05:49 PM
No, haven't heard of any place around here that you can get 100% nitrogen and it would be too much hassle anyway.
Old Nov 18, 2004 | 05:52 PM
14U2ENV's Avatar
14U2ENV
From: Lino Lakes, MN _________________________ I Figured out how to do this!
It isn't worth the trouble.
Old Nov 18, 2004 | 08:16 PM
Old One's Avatar
Old One
Only for the gullible.
Old Nov 18, 2004 | 10:59 PM
VERYSOON's Avatar
VERYSOON
Well, 81% anyway. Military and airlines use it. Can't imagine where you can get it except at offshore hardhat diving companies, maybe some welding places, but i would try it for north central texas if available just to see what happens. 40 degrees in the morning and then 75 by noon. seems it would be good for highway driving.
g
Old Nov 19, 2004 | 12:33 AM
jrose7004's Avatar
jrose7004
Don't hear of many folks running it!
Old Nov 19, 2004 | 04:16 AM
Lancer033's Avatar
Lancer033
it's only worth it if you are racing professionally or for tires on aircraft. Under extreme conditions it's good.
The only benefit for a street car is that if you keep your wallet in you back pocket it'll will be thinner, and probably more comfortable.
Old Nov 19, 2004 | 07:37 AM
SlideRulz's Avatar
SlideRulz
Mabye try helium, make your car lighter
Old Nov 19, 2004 | 08:16 AM
jojog's Avatar
jojog
Our Costco store offers it free with new tires and repairs!
Old Nov 19, 2004 | 12:30 PM
5150 BRD's Avatar
5150 BRD
I discussed this with a person very high up in the Goodyear organization. It does, as others have stated, reduce the change in air pressure. He also said that because the molecules are larger there is less leakage and less corrosion of the steel belts. In other words it is beneficial but may not be worth the trouble.
Old Nov 19, 2004 | 12:35 PM
Benpup's Avatar
Benpup
Appreciate it.
I will continue to use good old fashioned air and my so far so good accurate tire gage.
Regards.
To Nitrogen
