SS brake lines
Old Dec 12, 2004 | 04:33 AM
worldtraveler's Avatar
worldtraveler
From: Proud dad of 2 responsible adults and 1 fallen warrior txtx
Default SS brake lines
Any downside to installing stainless steel brake lines on a daily driver, non-track '04 C5? Anything to especially look for when ordering?
Old Dec 12, 2004 | 04:40 AM
NSTG8R's Avatar
NSTG8R
a lighter wallet?
Old Dec 12, 2004 | 05:21 AM
worldtraveler
That's a given for anything with these babies.
Old Dec 12, 2004 | 05:37 AM
CAJUNY2KC5's Avatar
CAJUNY2KC5
I'd make sure they are DOT Approved equipment and that the package says so before putting them on.
Old Dec 12, 2004 | 06:36 AM
Z0SLIK's Avatar
Z0SLIK
Money Pit is putting it mildly. But ain't it great??
Old Dec 12, 2004 | 06:40 AM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
I have them on my car. They came with my Wilwood brake package. I've heard some people having problems with some brands of SS lines, but I've had zero problems.
Old Dec 12, 2004 | 07:00 AM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
I have Goodridge SS brake lines. Have had them on the car for 3 years with no problems and a noticeable improvement on braking response. They were a great ungrade from the rubber (expandable) OEM lines.
http://www.goodridge.net/
http://www.thelapd.com/Merchant2/mer...e_Code=thelapd
Old Dec 12, 2004 | 07:51 AM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
We are having intermittent Active Handling / Traction Control system problems. GM's official position is that it is caused by the SS brake lines.
Old Dec 12, 2004 | 08:35 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Goodridge is a good brand to get. I had the Russels and they threw codes from the second they were installed.
Sully, you should check your lines by using an OHM Meter... place one probe on the metal tab located just before the SS line and the other end of the probe to the brake caliper. If it is grounded properly, you dont have a problem with your SS line. If you dont have a good ground on one line, then replace that line.
VR
Old Dec 12, 2004 | 09:18 AM
AU N EGL's Avatar
AU N EGL
That is GMs standerd responce to any aftermarket installations. cause they did not think of it first.
Old Dec 12, 2004 | 09:28 AM
eddie44's Avatar
eddie44
St. Jude Donor '03
I've heard the same problem. I'd stick with a good/recommended brand and you shouldn't have any problems.
Good Luck!
Old Dec 12, 2004 | 09:35 AM
vetterdstr's Avatar
vetterdstr
Good Luck!
For those of you who dont know, Sully has a complete after market brake package on his car that runs a completely different SS line that you CANT get from Goodridge or Russel. I know this because he and I have the exact same brake kit. Any replacement that is needed for his car will have to be custom built. Once he gets rid of his grounding problems, he will be good to go.
VR
Old Dec 12, 2004 | 10:14 AM
WhiteC5Vette's Avatar
WhiteC5Vette
Very possible, and the only way to diagnose is to replace with standard lines and see if the problem goes away. Under some driving conditions, static can be created by the SS lines, causing inaccurate readings in the speed sensor(s).
However, I do not have SS lines, and I had intermittent problems with my ABS/TC/Active Handling system; used to periodically get the Service lights and the messages, and a recycle of the ignition would get rid of the messages and turn off the idiot lights, but set a code C1214. Usually, it would happen after one of the systems kicked in, then one-day, just cruising they messages appeared. Still canceled out with an ignition cycle. Then two-weeks ago, they came back on, but would not cancel out. Last Monday, the dealer ordered both the EBTCM and BPMV, to be replaced tomorrow morning.
Old Dec 13, 2004 | 12:16 AM
corvette dave's Avatar
corvette dave
Traveler,
I have had SS lines on 2 cars that were tracked.
Unless you like the way the SS lines look I would not put them on my street car.
Proof of a noticeable improvement in braking has not been shown to me.
Dave
Old Dec 13, 2004 | 05:23 AM
jrc27's Avatar
jrc27
Cruise-In IV Veteran
Cruise-In V Veteran
I am having the same issues
Old Dec 13, 2004 | 07:12 AM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Same here.
Old Dec 13, 2004 | 07:26 AM
Sully C5's Avatar
Sully C5
VR
If I had it to do over, I would have gone with 18" wheels on the front (I ended up getting them anyway) & Bembro Brakes. At least they are still in business.
Old Dec 13, 2004 | 07:32 AM
blazeone's Avatar
blazeone
No problems at all in 4,000 miles.
Old Dec 13, 2004 | 07:47 AM
_Redline_'s Avatar
_Redline_
Hmm, these are problems I have not heard before. I just ordered some SS Brakelines from Sportbrake.com. I have no idea what brand they are. I am getting them as a package w/rotors and pads. Has anyone been using SS brakelines from Sportbrake.com?
To SS brake lines
