garage floor tiles - help needed!
Old Jan 29, 2005 | 12:53 AM
  #81
Snidley's Avatar
Snidley
Originally Posted by DaBoz
Snidley... I'm installing a VCT floor this next week.... how long before I can park cars on it???? I live in So Cal so cold in not a problem.
Thanks!
Depends on the adhesive, but any of them should be ready to go in 24 hours.
Old Jan 29, 2005 | 07:26 AM
  #82
69's Avatar
69
Cruise-In VI Veteran
VTC tile users, I have a new house and the garage floor has expansion joints (required by code in my area of Michigan). These expansion joint measure ½ inch wide by a ½ deep. Did you just lay the tile over these expansion joints?
Kevin
Old Jan 29, 2005 | 07:32 AM
  #83
NAVY8N's Avatar
NAVY8N
Kevin, you need to seal your joints before laying the tiles otherwise they will eventually crack. Just get some concrete sealer and level it out in the cracks and you should be fine, also if you have any low spots anywhere you need to take care of them as well.
Old Jan 29, 2005 | 09:12 AM
  #84
RPOZ16's Avatar
RPOZ16
Originally Posted by Snidley
Using the standard adhesives with the VCT will allow water to get under it, but there are some epoxy adhesives that will withstand the water, even the freezing. The sealer can be removed with chemicals or sanding.
Sneidley
The Tile man
Tile Man, are the epoxy adhesives harder to spread and work with? If so can you give me an estimate of the extra time it might take? I realize that they would cost more, but most concerned about the extra time, energy and DIY competence needed, if I go that way.
Old Jan 29, 2005 | 09:28 AM
  #85
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
i did mine in the morning early and had my car in it that night.
if you put the glue down and let it sit up for 30 or 45 min, then put the tiles down, they arent coming up.
Old Jan 29, 2005 | 11:02 AM
  #86
ZFORME's Avatar
ZFORME
This information was awesome!
Old Jan 29, 2005 | 12:51 PM
  #87
andy82's Avatar
andy82
2017 C7 of Year Finalist
Originally Posted by EVIL_C5
armstrong vinyl comercial tile. its like .60 cents per tile from home depot. easy to put down, easy to clean. cost me about 350 bucks to do my 20x20 garage
Old Jan 29, 2005 | 09:34 PM
  #88
ProfMoriarty's Avatar
ProfMoriarty
I'm considering a VCT garage floor.
The floor would be exposed to salt and snow during the winter months consequently, from what I've learned here, an epoxy adhesive would be indicated.
My garage floor has a area speckled with a fair amount of latex paint since I use that area to paint trim, doors, etc.
Also, when I sweep the floor a fair amount of concrete dust comes up.
I can sweep all day and I'll continue to lift dust.
How will the latex paint effect epoxy adhesion?
Can I powerwash the floors and apply epoxy adhesive given my floor description?
Old Jan 29, 2005 | 09:42 PM
  #89
12stepvette's Avatar
12stepvette
St. Jude Donor '03-'04-'05-'06-'07
Do You remember what brand/make/type of adhesive you used?
Old Jan 29, 2005 | 11:34 PM
  #90
Snidley's Avatar
Snidley
Armstrong S-515 Is the best. Generac name for that type of adhesive is "clear thin spresd." Spread it out over as much as you want to tile that day, take a 30 to 60 min beer break, and start tiling. The stuff goes on looking creamy color, and when it is ready will turn clear. At that point it is very tacky, almost like contact adhesive. Once ready to tile, you have 12 to 24 ours to put the tile down. Be sure to follow the directions on the can, use the proper notched trowel, and LET IT TACK UP!!! If you don't, it will bleed through the joints for a very ling time.
Old Jan 29, 2005 | 11:40 PM
  #91
Snidley's Avatar
Snidley
The epoxies aren't harder to spread, just a different technique to use it. Tthe tiles are set in the epoxy as you spread it, and you work from off the tile. Epoxy has no initial grab, and the tile can slide around a bit, if you aren't careful. The room has to be warm, 70* ish, or it will take much longer for the epoxy to harden. Its a chemical reaction that requires heat that the glue generates. Be sure to clean up glue smears or spots before moving on. Epoxy is a b**ch to get off later.
Epoxy will also cost alot more.
Old Jan 29, 2005 | 11:46 PM
  #92
Snidley's Avatar
Snidley
**Paint speckles won't hurt anything, although I would still hit them with a sander to make sure they aren't loose.
**Dust needs to be removed. Power washer should do a good job of it. If you don't remove the dust, you are just sticking the tile to a layer of dust. It will stick, but not as good as to a clean floor.
**not at all.
**yes
Old Jan 29, 2005 | 11:49 PM
  #93
ProfMoriarty
Thanks very much for the reply, Snidley!
Old Jan 30, 2005 | 12:46 AM
  #94
RPOZ16's Avatar
RPOZ16
Old Jan 30, 2005 | 02:11 AM
  #95
RainJ's Avatar
RainJ
From: Biloxi MS Theres something happenin' here, What it is ain't exactly clear.....
Old Jan 30, 2005 | 01:50 PM
  #96
ProfMoriarty
A white powdery substance forms on my garage floor.
Is that indicative of moisture "seeping" thru to the surface?
If so, is there an effective sealant that will prevent it or does that shoot the VCT idea all to hell?
Old Jan 30, 2005 | 01:55 PM
  #97
12stepvette
I cant wait for the weather to warm up.....I`m standing by with trowel in hand!!!
To garage floor tiles - help needed!
Old Jan 30, 2005 | 02:27 PM
  #98
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
What Snydley said
Peace
WIllfulone
Old Jan 30, 2005 | 03:40 PM
  #99
ProfMoriarty
I was referring to moisture seeping UP through the concrete pad rather than moisture seeping underneath the tile from the surface.
Old Jan 30, 2005 | 04:28 PM
  #100
Dr. Dan's Avatar
Dr. Dan
Was previously thinking of RaceDeck in 4 colors but the cost slowed me down a bit. Like the idea of the VCT, but the floor is old, has numerous stains (mostly oil based), and a few long, though not wide settlement cracks. This might prevent a successful VCT project
