QTP C5 Tri Y Header Special
This is our famous Tri Y Headers.
Power out of the box with out tuning!
Easy install and retails all 4 O2 sensors.
Torque On Demand.
100% 304 Stainless Steel!
Tri Y Headers and 2 3/4 Off Road X Pipe-$1375.00
Tri Y Headers and 2 3/4 Cat X Pipe-$1650.00
Tri Y Headers and 2 3/4 Off Road Dual QTEC X Pipe-$1775.00
Tri Y Headers and 2 3/4 Cat Dual QTEC X Pipe-$2050.00
Choose from:
1997-2004 Race Style Headers (No Air Fittings)
1997-2000 W/ AIR Fittings and Dip Stick Mount
2001-2004 W/ Air Fittings
GM Header Gaskets $20.00
Stage 8 Header Bolts $40.00
Any questions feel free to call us.
If so - pricing and expected dyno gains?
I'll admit the Tri-Y is tempting - that set-up generally makes as much more torque as HP.
Thanks.
The installation of this system was very straight forward, no need to even pull valve covers. The front O2's are straight up and down and the wires reach and install with no problems. The rears route and attach the same as stock so no problems there either.
Good luck with your decision.
Oh well, maybe a summer sale will get me in!
Thanks.
Gains are 30-35 HP/TQ in the midrange and 25-30HP/TQ peak. This is also with cats not off road pipes.
You will feel the tri y's when your driving. Gives an instant throttle response. You will need new tires from going sideways
I've been reading about your headers for some time. I was wondering if you might have an explanation for why a tune is not required for the use of your headers while still achieving excellent hp/tq gains. Sounds like the AFR stays the same as the factory tune? I find not needing to go into my computer appealing if my understanding is correct.
verysoon
These really look like a viable alternative - love the thought of LG's, but these seem stealthier for CA smog visual check.
A few final questions - how much HP from headers to stock cats? Price on that? And, anyone in Socal you recommend for installation? Or, do you have a how-to to see if I should do this in the garage?
Thanks again.
verysoon
The headers by them selves are $1250.00 retail. We do not have a kit to bolt up to stock cats. But they can be made to fit like the TPIS headers. Call me if you are just interested in the headers.
My belief is that if the computer can read the 02 sensors as GM designed along with the benefits of the try-y design... you get great results without the need for tuning.... the computer is able to do all the work it was designed to do! IMO.
R.P.
P.S. I tried to post my QTP dyno results (dyno charts with summry) waaaaay back before the holidays but was unable to do so due to "major computer problems/virus", which I am still experiencing! The virus keeps consuming all of my memory the moment I purge my files (it appears to be at the server level), anyone have any ideas how I can still post my results?
Thanx for any suggestions you may have. R.P.
R.P.
In response to your inquiry regarding canyon driving.... yes, your QTP headers performed even better than I was hoping, specifically torque under the curve and throughout the rev range that I use during canyon driving (1,500rpm-5,500rpm).
Previously with just the Borla cat-back set up the car felt under-powered apexing/exiting turns (aka:anemic), with your headers/cats the car now pulls "real hard" through the apex and rockets out of turns!
Recently I attended the SCMR #18 run here in San Diego (aprox 18 cars attended), mostly country/canyon roads. Running your headers I noticed that I had to back off several times when exiting turns to avoid sucking up too quickly to the car in front of me, includung Z06`s. This is a perfect example of the benefits gained from using the tri-y set-up.
Oh, by the way, still no engine light/code issues!
Keep up the good work, R.P.
