Velocity stack?
Old Feb 18, 2005 | 01:43 PM
RacrX's Avatar
RacrX
St. Jude Donor '08
Default Velocity stack?
Does this really work?
Old Feb 18, 2005 | 01:50 PM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
Do you mean the velocity stacks that sat on top of a carb (or several like Webers) like in a hot rod? They did work but not for a fuelie...
Old Feb 18, 2005 | 01:55 PM
RacrX's Avatar
RacrX
St. Jude Donor '08
this one is a plastic insert that goes in the throttle body...
Old Feb 18, 2005 | 01:58 PM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
Oh the thing that claims to straighten your air flow..... No it does not - and actually the C5 has a square mesh screen at the MAF that is supposed to do that exact thing. Save your 19 bucks....
Old Feb 18, 2005 | 01:59 PM
rudolph schenker's Avatar
rudolph schenker
I don't think there are any dyno numbers to prove it. However I put one in when I did my Vararam, just for the he** of it!
Old Feb 18, 2005 | 02:49 PM
C5JONNY's Avatar
C5JONNY
Dont waist the cash, if your gonna mess with the throttle body just have it ported.
Old Feb 18, 2005 | 08:36 PM
big hoss 98C5's Avatar
big hoss 98C5
Old Feb 18, 2005 | 10:24 PM
LoneStarFRC's Avatar
LoneStarFRC
I don't think it's designed to straighten air flow, but rather to increase air velocity through the throttle body somewhat. Not sure on the actual performance of the piece though. HTH
Old Feb 19, 2005 | 12:47 AM
carnut108's Avatar
carnut108
Old Feb 19, 2005 | 01:04 AM
Vette#2's Avatar
Vette#2
Seems to me that it helps keep the air flow "smooth" inside of the TB.
But I've been told it's "snake oil". We need a dyno test to nail this one down.
Old Feb 19, 2005 | 05:18 AM
naturalgas's Avatar
naturalgas
don't know if it is any good but did see them on c5r
Old Feb 19, 2005 | 07:19 AM
USA-VET's Avatar
USA-VET
Old Feb 19, 2005 | 12:55 PM
corvettebob1's Avatar
corvettebob1
HMMM, lets see last time I looked to increase velocity you had to add a restriction.
So if we just take a flat metal plate and drill a small, say .060 dia hole and cover the throttle body with it it should go really fast
You will get a lot more gain/not loss from adding a low restriction air filter and ZO6 screens.
Old Feb 21, 2005 | 08:42 PM
ebluevette's Avatar
ebluevette
There is a small increase in power. I have had one on my car for some time now, and the last time I was on the dyno, we ran it several times with it, to get the tuning correct, then ripped it out and ran it once to see what kind of difference it made. We found that it lost 2 ft-lbs across the entire rpm band with it out. Although it is not a significant power boost, not even enough to register on the assometer, there is a small gain.
To Velocity stack?
