Header Question for 03 Coupe
Old Mar 4, 2005 | 09:46 AM
EStreeter's Avatar
EStreeter
Default Header Question for 03 Coupe
I have recently (1 month ago) purchased an 03 coupe. The car is primarily an every day drive. I bought it for my wife for her birthday and she uses it as a commuter. I am looking for a little more bottom end response but don't want a lot of noise or make it something she will not be comfortable driving.
The first mod I am planning is LT headers. I have been shopping the forum sponsors and web sites as well as used parts. Too many choices and opinions and too many $$$ for complete system from headers to X pipe.
Does anyone make a LT header that will terminate in front of the stock CATS? The car has pre cats and the large main cats. I want to use the existing system from the large cats back, eliminate the small pre cats and just cut the pipe, weld on a flange in front of the main cats and attach to the headers. The stock manifold and pre cat section can go back in if needed by adding a flange later to the cut ends.
Will change the air breather for a Halltech in near future as well.
Any help?
Old Mar 4, 2005 | 11:37 AM
vettenuts's Avatar
vettenuts
There are likely several you can go with. Most will require some professional help with cutting the stock system, etc. I know the Bellangers are made to mate with the stock system and they are a Tri-Y design, which I personally favor but there are differing opinions here as well. You probably need to decide which header you are looking for and then contact the vendors about connecting to the stock H pipe. The stock H pipe might limit your gains compared to high flow cats and an X pipe.
Old Mar 4, 2005 | 06:26 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Lots of choices out there if you are going to use your stock cats, but get ready for some cutting and welding.
One drawback to that is that should you wish to return to stock, the stock system has already been cut.
Old Mar 4, 2005 | 07:39 PM
Dark-Knight's Avatar
Dark-Knight
Sounds like you may be better off doing shorties and not cutting the cats. The cutting and welding your talking about is going to drive up the price.
If you really want long tubes and not a lot of noise check out Z06 ti back end, with x-pipe and high flow cats as the enter section. Quiet, execept at WOT, will need a LS1 edit to correct air/fuel mixture. Whole package will run about 2 grand installed; you'll pick up about 30 rwhp.
Hope you find what you want!
Old Mar 4, 2005 | 10:45 PM
nwdanner's Avatar
nwdanner
So, you said you bought the car for your wife, for her birthday, and now you think it needs more bottom end power? Being that it was her birthday gift - is she okay with you modding for your tastes? Now, I don't know your wife, but from this side of the computer screen it would seem that you really bought the car for yourself and used her birthday as a cover. Be careful!! Maybe you should buy another C5.
Old Mar 5, 2005 | 12:30 AM
shurite44's Avatar
shurite44
Old Mar 5, 2005 | 12:37 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
My thoughts exactly, what kind of headers does your wife want.
Old Mar 5, 2005 | 11:16 AM
90 droptop's Avatar
90 droptop
When my wife and I decided we needed a pick up, she demanded one with a supercharger. So I had to buy her a Lightning. Same with my D.D. vert. She swore up and down about me needing a H/C job on it.
Old Mar 5, 2005 | 01:05 PM
towercontroller's Avatar
towercontroller
Default wife
About time a MAN stands up for himself around here.
Old Mar 5, 2005 | 10:03 PM
Dr. Dan's Avatar
Dr. Dan
I try to avoid trouble by knowing what dogpoop looks like, and not stepping in it. This has DOGPOOP written all over it.
Be careful!
Old Mar 5, 2005 | 10:31 PM
H82GOSLW's Avatar
H82GOSLW
Would you mind introducing your wife to my wife? Every time I buy something for the car, her response is "what do you need that for?" My repsonse is usually "if you have to ask you don't understand."
Old Mar 6, 2005 | 08:31 AM
vettenuts's Avatar
vettenuts
I went with a front to back system so that if the need ever arises, the stock system is a simple plug in. I try to do that with all my mods. This can help with resale as well if someone wants a stock car. Mods turn off a lot of Corvette shoppers.
To Header Question for 03 Coupe
