MAP Sensor Problem w/Service Engine Soon
Old Mar 4, 2005 | 02:51 PM
The Yav's Avatar
The Yav
Default MAP Sensor Problem w/Service Engine Soon
I am having problem after my cam install (228/588/114) for a check engine light. I had my PCM reflashed for the different cam profile. The check engine light came on after bigger cam install, about 400 miles. The code I get is P0107 H, Low MAP (Manifold absolute pressure low voltage circuit). I have changed the MAP sensor, checked for leaks. I reset the code and I get the check engine light again at high engine RPMs 6000+. There are no other codes associated with the P0107, have anyone heard of any one else experience this? Do you need to set different parameters for the MAP sensor due to the increased vacuum from the cam?
I have tried to fix the problem myself any advice/help would be appreciated I am getting very frustrated.
v/r
THEYAV
Old Mar 5, 2005 | 09:37 AM
The Yav's Avatar
The Yav
ttt
Old Mar 6, 2005 | 02:35 PM
The Yav's Avatar
The Yav
ttt
Old Mar 6, 2005 | 05:13 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There are just 3 wires in that entire circuit! The haeness comes from and returns to the PCM. The PCM supplies a +5 VDC reference voltage to the MAP sensor and the MAP sensor scales the voltage down as to what the vacuum is. Recommend disconnecting the connector and looking at the pins inside the connector. Maybe one is damaged and too large to make good contact. Read the % volt reff signal with a meter.
Bill
To MAP Sensor Problem w/Service Engine Soon
