Help! My e-brake spring came off.
Old Mar 5, 2005 | 08:44 AM
volvette179's Avatar
volvette179
Default Help! My e-brake spring came off.
I received my new 14" rotors for the rear. When i tried to remove the old rotors it was all i could do to remove it. After pulling and pushing the e-brake spring inside the shoe came off. After two hours and looking at the other side i can still cannot get it back on. Any suggestions would be much appreciated.
Rick
Old Mar 5, 2005 | 09:29 AM
12stepvette's Avatar
12stepvette
St. Jude Donor '03-'04-'05-'06-'07
I had the very same issue when redoing my rotors. Believe it or not...the spring can be put back into place with some patience and alittle coaxing with a pair of screwdrivers.The Manual procedure for installing the parking brake shoe and retaining spring requires the Removal of the wheel bearing/hub.
Good Luck
Old Mar 5, 2005 | 11:34 AM
volvette179
The screwdrives did the trick. Thanks!
Old Mar 5, 2005 | 11:45 AM
ericdwong's Avatar
ericdwong
OH god I feel your pain, you can get them back on but they are a royal pain in the rear. I really hate the ebrake design of this car.
Old Mar 5, 2005 | 11:52 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Use a couple of long skinney flat screwdrivers and pry the spring back into the slots. IT SURE IS A PITA!!!
Bill
Old Mar 5, 2005 | 12:15 PM
volvette179
Yes it was!!
To Help! My e-brake spring came off.
