Revers lights not working.
Old Mar 5, 2005 | 11:07 AM
rockgt302's Avatar
rockgt302
St. Jude Donor '05
Default Revers lights not working.
MN6, I replaced the switch, still no worky. They come on with the key fob.
Old Mar 5, 2005 | 11:19 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Are you sure that you replaced the correct switch??? Try this: Remove the connector from the switch, install a jumper wire between the two pins on the wiring harness connector that plugs on to the switch. When you turn the ignition switch on the reverse lights should be on. Remove the jumper and see if they go off. The reverse switch is on the passengers side of the tranny. When you remove it there should have been a ball bearing type actuator on the tip of the switch.
Put the ohm meter leads on the terminals of the old switch and press the ball bearing in. If the switch is good, the meter should show cllose to ZERO onms.
Bill
Old Mar 5, 2005 | 11:41 AM
rockgt302's Avatar
rockgt302
St. Jude Donor '05
Its the right switch, I will have to borrow an ohm meter. I will give it a shot.
Old Mar 5, 2005 | 11:59 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You can still do the jumper wire test. You could have gotten a bad switch.
Bill
Old Mar 5, 2005 | 12:14 PM
rockgt302's Avatar
rockgt302
St. Jude Donor '05
Would I be able to use any type wire (stereo) as a jumper?
Old Mar 5, 2005 | 01:38 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yes, even tinfoil will work! anything to short the terminals together for testing.
Old Mar 5, 2005 | 06:16 PM
jmzvet's Avatar
jmzvet
I replaced my trans switch also and reverse lights still don't work. It's at the dealer now for some other stuff so I'll see if they can fix it.
Old Mar 5, 2005 | 07:53 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
O.k. folks.. The switch is just one component involved here.. There is also a 10a fuse is the passenger-side floor board panel that typically blows when the switch fails..
My money is you'll find the blown fuse, replace it, and whala, backup lights.. Don't ask how I know!
Old Mar 6, 2005 | 01:10 PM
jmzvet's Avatar
jmzvet
Any idea which fuse it is? It is not listed on the fuse diagram in the owners manual?
Old Mar 6, 2005 | 02:51 PM
rockgt302's Avatar
rockgt302
St. Jude Donor '05
Old Mar 6, 2005 | 03:44 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The fuse that you are looking for is in the Instrument Panel Electrical Center. It is Mini fuse# 15. (HAZT/SG)
Old Mar 6, 2005 | 06:02 PM
jmzvet's Avatar
jmzvet
I'll check it out.
To Revers lights not working.
