Noisy engine!
Old Mar 8, 2005 | 11:35 AM
Ghost Vette's Avatar
Ghost Vette
Default Noisy engine!
Has anyone had problems with the engine sounding loud when idling after a long drive? Say a hundred or two miles. Doesn't seem to do it when driving and the preformance is not a problem. Thinking the cats system could be some of the problem. After it sets for 20 to 30 minutes, it's not there.
Old Mar 8, 2005 | 11:36 AM
yellow01's Avatar
yellow01
Describe noise please...
Old Mar 8, 2005 | 11:40 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What makes you think the CATs are part of the issue. Please describe year of C5 and MODs.
Bill
Old Mar 8, 2005 | 12:01 PM
Ghost Vette
It sounds like a diesel but not as loud. I thought maybe something in the cats because it doesn't make the sound after it has time to cool a bit. Maybe I'm over sensitive to the sound.
Old Mar 8, 2005 | 12:03 PM
Ghost Vette
Forgot the year...98 . No mod as far as the engine goes.
Old Mar 8, 2005 | 12:11 PM
7.0sc SuperVette's Avatar
7.0sc SuperVette
From: Sunny Earthquake Country, USA On the Left Coast (which is becoming more Right!)
Default Rpm?...
Check your normal idle rpm and your rpm after the long drive.
Is it higher for a while? what is you oil temp?
Also if a high mileage engine, you might try 10/40 or even 10/50 synthetic and see if that helps.
Roy
Old Mar 8, 2005 | 01:02 PM
Ghost Vette
The milage is 69 K. Don't recal the temps being high, but will check next time. I use Mobil Syn 5w30 and AC filter. I have thought about K&N. any thoughts on this? I change the oil at 3 k miles. Still have 65% life now.
To Noisy engine!
