best air intake
Blackwing is good, don't get me wrong but won't be cold air. That ambient air is heated up, even infront of the radiator.
I know you really like your blackwing, but you should be honest with yourself.
Tape a thermometer to that radiator shroud, see how "cold" the air is down there?
Outside air temperature is the coldest your engine's air is going to get (without spraying Nitrous) and blackwing doesn't use outside air.
You think when it's 50-70 degrees outside that the air under your hood is 50-70 degrees (by the radiator shroud) while you running the car??
Pop your hood sometime after it's been running for a while.Think about it.....
Before installing my cold air mod, I would drive home from work, pop open the hood and feel the air bridge - VERY HOT. In addition, a scan tool told me that intake air temps exceeded 140F at times. After the cold air mod, I did the same thing, only this time, the airbridge was cool to the touch. Granted, the OEM placement of the airbox is much better than the old air filter-on-the-carburator setups, but the stock C5 filter placement (even with Blackwing) is NOT considered a cold air system.
but the stock C5 filter placement (even with Blackwing) is NOT considered a cold air system.[/QUOTE]
Good information.
Ambient air is140 degrees around the radiator shroud.....
That's pretty cut and dry.
,......................the twin flow system lays down, right in front of the cold air intakes, witch you make active any number of ways it may not be the very best but,.........your car wont blow up in flames
The air going through the Vararam ducts is from outside the nose of the car and is sent straight back to the throttle body after entering the duct. The air the Vararam intake system captures is at outside temperature.
The Blackwing draws in air which has made it under the hood and has had a chance to rise in temperature.
Take a look in front of your radiator shroud which is where the Blackwing sits. You will see that there is not much of an opening in front of the Blackwing for it to draw cool air from.
You got cold air and ram air. You just put the supercharger industry out of business. What amazes me is the number of people that actually believe this crap.
Bob
Bob
As mentioned,I have run both Vararam and Blackwing. You can sit there and naysay as someone who has no first hand experience with both, but the fact is the cold air intakes are a little quicker, as exidenced by 20+ Blackwing and 20+VR runs. The feel is noticable. I'm not saying the ram air works or not, but I can say it's faster. Blackwing is still a good piece, just not the best anymore. After Iwas sure there was no hydrolock risk with the Vararam, I made the change.
Bob
If cold air does not amount to a hill of beans, then how come people run faster times in cool weather than they do in hot weather?
When people say "cold" air they (should) mean relative to underhood air.
No one is saying that a Vararam is more effective than a supercharger, but some are touting it as the best bolt on intake system out there. There may be some validity in that.
I have the Vararam on my car now after removing the Blackwing, and so far so good. I fully expect a documentable performance increase.
And if you're going to quote what I said, get it right. I said "That cold air you keep talking about". They were talking about the difference in air temp between the Blackwing and the Vararam.
I'm outta this one.
Bob
I'm outta this one.
Bob
Oh, I quoted you right, its word for word. I pressed the "quote" button on your post before my reply. I'd rather look at Cartek and some of the others.
I'm outta this one.
Go over to the drag racing section go over to Z06Vettes.com and see what everyone running the really good numbers is using. More often than not it ain't the Blackwing.
The funny thing about the "Cold air does not mean a hill of beans" and that the " Blackwing takes in the same temperature air" folks is that if this is true then by extension they have to say that:
1. All of the people who have cut their radiator shrouds to let in air have done so for nothing. Thats whether they are using Blackwings, Halltechs, or Vortexs. If the radiator shroud was cut, it was a useless endeavor because any intake sitting on top of an uncut radiator shroud with uncut foglight shrouds is taking in cool air anyway..... air that is every bit as cool as the Vararam takes in.
2. Anyone with an underhood intake who has drilled holes into, or gone with, perforated foglight shrouds has done so for nothing. If you already have a Blackwing, then there is no point in putting holes into your foglight shrouds.
3. When the Blackwing was offered by vendors here, with a cut radiator shroud and airbox lid modification a few years back, but fell out of favor due to frequent reports of surging issues....... well this was really bogus anyway...... as there was never any potential gain to be had with a Blackwing covered by a lid over a cut radiator shroud in the first place.
http://www.conceptualpolymer.com/corvette_c5_corner.htm
